displaying posts 176 to 200 of 434
Pages (18): first .. 7 [8] 9 .. last
Author Subject: Eddy's VLR + Omex 600
eddy_gti6
Post #176
May as well get it on while he has the car all wired up save going back for a 2nd time. Need to find come coil leads. Been told to either use corsa leads or 8v turbo leads?
Posted 26th Feb 2014 at 21:28
pete_rallye
Post #177
8v turbo, thats what I used, and a coil pack from it. Bought a genuine pug one for £40ish. Don't know about corsa...
Lap of the 'ring
Posted 26th Feb 2014 at 21:37
eddy_gti6
Post #178
Yeah I already have the coil pack off my old 8v turbo engine. Should have the coil leads somewhere too. What plugs do you run pete?
Posted 26th Feb 2014 at 23:16
rallyeash
Post #179
Run BCR8ES and nothing cooler.
I use corsa HT leads.
309 3dr K20 Type R
Posted 26th Feb 2014 at 23:21
eddy_gti6
Post #180
BCR8ES £7.84 for a set of 4 on ebay. Not too bad. Fiesta 1.6, sierra 2.0 cosworth. Nothing for peugeot. I take it the ones for sierra will fit ok?
Posted 27th Feb 2014 at 00:01
rallyeash
Post #181
That's the model of plug so will fit pug and whatever else uses same size plug
309 3dr K20 Type R
Posted 27th Feb 2014 at 18:18
eddy_gti6
Post #182
Awesome. Ordered a set along with some 406 8v turbo HT leads. Thats just about everything sorted now. Just need a throttle body adapter making up for the inlet unless I can find a 70mm body that eill bolt straight on. Dont fancy spending £280 on a single jenvey body
Posted 27th Feb 2014 at 19:29
Post #183
Is this being broken for parts yet? Whistle
Posted 4th Mar 2014 at 13:32
eddy_gti6
Post #184
Maybe, what you after?
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 4th Mar 2014 at 13:56
Post #185
Nothing mate, I'm pulling your leg.
I do hope you're joking Laugh my ass off
Posted 4th Mar 2014 at 16:47
eddy_gti6
Post #186
I am joking yes LOL its going in with my mate jim next thursday while I am in spain for 4 days to have abit work done.
New exhaust cam fitted,
Cam timing set up,
Compression test,
Wheel bearings & ball joints,
Omex loom modified,
Sure there was more but cant remember off the top of my head.
Looking into new coilovers next month too as I dont rate these gaz gha's al all, not worth the money to be honest then maybe some new wheels.
Posted 4th Mar 2014 at 19:32
eddy_gti6
Post #187
I now have a nice collection of parts whats all pretty much ready to be fitted. Still needing a fuel rail and TB adapter but other than that I shouldn't be far off now.
The car seems to be running pretty well at the minute since I have started using ron 97 fuel what I take it the car must have been mapped on, tick over seems smoother too.
Posted 8th Mar 2014 at 15:59
eddy_gti6
Post #188
Not a lot been happening lately except from I had a compression test done while I was away. Came back that 1 cylinder is only making 40psi where as the other 3 were making 200psi. Jim stuck a camera in the bore to find damage to the top of piston 3. Ordered a new MLS head gasket and head bolts and have a few spare pistons lying around what I can use as replacements.
Posted 24th Mar 2014 at 16:56
rallyeash
Post #189
I'd imagine there will be more to loosing compression than just damage at the top of the piston. I'd hazard a guess that it was damage after the belt letting go at some point rather than your cause now.
309 3dr K20 Type R
Posted 24th Mar 2014 at 17:52
eddy_gti6
Post #190
This isnt the engine that the belt snapped on, its the engine I bought from C_J_M with the catcams in. That bottom end what the belt snapped on is sitting under my work bench.
Any news on an altonator ash?
Posted 24th Mar 2014 at 18:28
rallyeash
Post #191
I was referring to it potentially having a snapped belt a few years back and marks on the top of the piston shouldn't make a huge compression difference like that... might effect it by a small amount but I doubt 160 psi difference.
Not as of yet mate. I haven't actually been to the depot yet. Will be there tomorrow. I start work from home and can be anywhere.
309 3dr K20 Type R
Posted 24th Mar 2014 at 18:56
eddy_gti6
Post #192
Jim said it looked more Like the ctown of the piston had melted a little bit.
Thumbs up thanks ash let me know
Posted 24th Mar 2014 at 20:03
Post #193
Any update on this?
Posted 31st Mar 2014 at 13:49
eddy_gti6
Post #194
No head gasket and bolts are here and now just waiting to see when I can drop the car off to have the damaged piston replaced ect... so engine is running 100% also need to look into somewhere that can make me up a fuel rail for the VLR and a throttle body adapter.
Was watching touring car legends yesterday and in sure this is a VLR on the 406
Posted 31st Mar 2014 at 16:16
eddy_gti6
Post #195
All sorted for getting my compression fixed now. Cars going in friday morning. Offered to stay and help so shouldnt take too long. Fingers crossed it will all be up and running 100% come friday afternoon then next month can focus on having fuel rail made up and throttle body adapter than that should be the inlet pretty much ready for fitting. Need to figure out weather I can lower the standard alternator or weather its too big. Looking like I am going to have to get rid of the pas pump.
Posted 31st Mar 2014 at 19:50
Post #196
I wanted to fit the standard alternator where i've fitted my smaller one but gave up on the idea as there wasnt enough space if mounting it to the sump iirc.
Posted 31st Mar 2014 at 20:00
eddy_gti6
Post #197
Thats where I was planning on trying. I need to get everything stripped back and fit the VLR to what room I actually have. I think it just slightly catches the alternator, may be able to alter it a little but will find out soon enough.
Posted 31st Mar 2014 at 20:05
Post #198
I cant remember if the crossmember or the rad was the cause of my clearance issue with the standard alternator, maybe both. I wish i did have such a terrible memory! Doh
Posted 31st Mar 2014 at 20:25
eddy_gti6
Post #199
Laugh my ass off I will see how I get on with my engine on friday and have a mess about while I have access to the ramp. Bottom of the radiator looks like it will be in the way from where I can see.
Posted 31st Mar 2014 at 20:29
Post #200
It could also have been to do with mounting the alternator to the sump, it rings a bell slightly that it wouldnt be as straight forward as making a bush for the lug on the sump and a spacer between the sump and alternator.
Posted 31st Mar 2014 at 21:28
