Author Subject: Rear Anti roll bar
gareth softley
Started stripping down my rear torsion bar today. With the two 13mm bolts removed from the end caps on the ARB so it is free from the beam itself, should I be able to turn it freely??? may not be massively important but would be good to no.
Posted 13th Dec 2013 at 19:54
pugheaven
Yes it should be able to turn freely
Posted 13th Dec 2013 at 19:57
gareth softley
Thought so, am I right in thinking if this was seized solid, it would stiffen up the rest of the rear suspension? I use the car for rallycross and last few meeting I haven't been able to stop the ass end bouncing I wonder if this could have been causing it
Posted 13th Dec 2013 at 20:00
jord294
When you removed the m8 bolts, did they come out with ease, or under pressure.
As it could be a sign your trailing arm is seized in position compared to other side
Posted 13th Dec 2013 at 22:51
Continue the strip down by popping the caps off with a ford wheel bolt/head bolt or whatever you have with the correct thread and see what the inside of the shafts are like.
  • Posted 14th Dec 2013 at 08:16
