displaying posts 1 to 25 of 38
Author Subject: GI: Breaking high spec cammed 6
c_j_m
Right, been considering breaking this for a while now, and a few niggley things have broke in the last couple of days and I cba fixing them especially as I want to replace it anyway.
Looking to see how much interest there will be in the parts?
Engine;
Camed engine with cat cams and mapped unlocked ecu. Cams made 195bhp in there old engine. Dyno printouts for this.
Bought the engine from Colin at pug performance, believe this engine came out of rusians old Bianca.
Has had a genuine pug water pump and dayco belt fitted 2k ago.
Complete ready to go with a white inlet, just no aux belt setup.
SOLD
Rallye aux setup with belt. Genuine pug pulleys new 2k ago. SOLD
2k old valeo clutch. SOLD
Rich w crank pulley. SOLD
Cf coil pack cover. SOLD
Gearbox with quick shift. £70
Updated gear linkages. SOLD
Gear selector arm that bolts to the subframe and gear rod with new bush. All fitted 2k ago. £35
K&N induction kit in vgc intake pipe. £50
Magnex decat. Lambda is nackered. £70
3" Magnex cat back with grp n centre. Will have the centre box rewelded. SOLD
Grp n engine mounts. £80
Suspension:
Avo coilovers. Will be refurb before sale. 250 or 275lb springs with all hardware for standard topmounts. SOLD
205 eccentric topmounts with the half moons to weld in for 100% fit. SOLD
Rich w wishbone bushes on gen wishbones with 2k old gen pug 18mm ball joints. £180
Xsara vts rack. Ph1 2k gen pug track rod arms. And lemforder tre's SOLD
22mm (standard is 21) front arb with bushes. £40
23.5mm Peugeot sport torsion bars. £250
30mm arb. £120
27mm arb. SOLD
Cambered rear beam recent rebuild and hubs. No abs sensors. Will take 30mm arb. SOLD
Solid rear beam mounts. Bbm items. SOLD
302mm brakes. £120
Exterior, china blue:
Front bumper with splitter good structurally. £60
Wings. £20 each
Bonnet, completely sent free few stone chips. £60
Doors, few car park dents. £30 each
Bootlid, with almost new rear boot lock. £40
Tinted windows medium tint. £50
Interior:
Ph1 full leather seats. Gc, with 307 rear headrests. DEPOSIT TAKEN
Ph1 door cards with conversion loom and all brackets. £50
Mint ph2 brushed alloy dash. £20
Auto dim 307 rear view mirror. £30
Ph1 top glove box with matching flocked lined lower ac glovebox. £30
S16 blue carpet ok condition. DEPOSIT TAKEN
Other bits and bobs:
Aem wideband SOLD
Saxo style rear spoiler. £30
BNIB clutch cable. £25
C5 steels 6.5x16 ET26 painted purple with 195/40 conti sport contact 2s. Almost new. £400
In sure there's load I've missed but that's the main bits.
Posted 5th Jan 2014 at 19:06
Niall
Hope your open to offers because some of that is over priced.
Is the clutch cable genuine pug?
Posted 7th Dec 2013 at 18:43
c_j_m
On some of it yes.
Cable is a ecp one.
Posted 7th Dec 2013 at 18:45
jord294
How about handbrake cables. Are they genuine?
Posted 7th Dec 2013 at 19:29
c_j_m
Sold those. But were factors ones.
Posted 7th Dec 2013 at 19:30
2052006
Pm'd re rack...
Posted 7th Dec 2013 at 19:33
2052006
Also, what make are the engine mounts and what sort of mileage have they done/how old are they?
Posted 7th Dec 2013 at 19:39
c_j_m
Baker BM items. Done around 5k in total.
Posted 7th Dec 2013 at 19:40
robthe6
Cf coil pack cover. £60 posted?
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 7th Dec 2013 at 19:58
c_j_m
Go on then.
Posted 7th Dec 2013 at 20:02
Phil white
Interested in cambered rear beam. How much has been machined? -4?
Posted 7th Dec 2013 at 20:03
c_j_m
Not sure tbh I believe they most are done to -3
Unsure of who did the work, but as it's been around the forum for a while it's most likely was Martin (cfr400??)
Posted 7th Dec 2013 at 20:05
7057sam
Would you sell cams and ecu separate? Is the rev limiter raise on the ecu?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 7th Dec 2013 at 20:06
c_j_m
Would like to sell the engine complete tbh. But if I've no joy I'll split. World be after £350 for the cams and ecu.
Limiter is raised to 7.5k
Posted 7th Dec 2013 at 20:11
jord294
I hope what I'm after is still available in a couple of weeks time Wink
Posted 7th Dec 2013 at 20:25
I may be interested in the engine without cams and ecu if that helps dude ?
Posted 7th Dec 2013 at 20:28
eddy_gti6
May have top mounts, let me get back to you Thumbs up
Posted 7th Dec 2013 at 20:50
marco gti6
What type of lambda does the AEM AFR uses LSU 4.2 or 4.9?? Are these the ones mab sold in the group buy?
Posted 7th Dec 2013 at 20:57
c_j_m
Chris. That would help yes. What sort of price were you thinking?
The lambda is a bosch one with the following part nos on it
0 258 077 366
306029 00
982/
Posted 7th Dec 2013 at 21:03
Head and block is all that is needed ? So cheap as poss bud ?
Posted 7th Dec 2013 at 21:05
c_j_m
Considering a good heads worth £150 by itself. It's gotta be £200.
Posted 7th Dec 2013 at 21:19
Roon
Pm sent cash waiting and will collect Smile
Posted 8th Dec 2013 at 00:03
7057sam
Then sell me the cams and ecu for £250 then I've had you money on it...
Did the head have any work on I.e pockected pistons?
Rallye dead Sad
Posted 8th Dec 2013 at 00:20
That would be bottom end not head bud Yes
Posted 8th Dec 2013 at 02:00
Na I was thinking more like £100 Thumbs up
Posted 8th Dec 2013 at 02:02
