displaying posts 1 to 25 of 63
Pages (3): [1] 2 3
Author Subject: Engine won't start
tony1991
I have just had a engine rebuilt for me new pistons liners Ect an top end all checked and new seals ECt. I have a spark I have fuel. I turned it over a few times with the coils unplugged to get the oil pump around. It wants to start almost firing on say 1 out of 5 turns of the key
Anyone any ideas
The only thing I noticed which I haven't previously is I don't have a plug on my loom to plug in the grey sensor on the right hand side off the block il try get a picture of my old block I checked all 3 looms that I have should I have a plug for this
Posted 18th Nov 2013 at 17:52
allanallen
What engine is it for starters? Gti6s don't have liners!
Whenever you re-fit an engine and it won't run whereas it did before its usually your fault (no offence Razz). Can't think off the top of my head what the grey plug is, I'm guessing its the oil sensor at the back of the oil breather pipe?? If so don't worry about it.
Are the coils and injectors plugged in the correct order, difficult to do wrong but not impossible.
Is the engine timed up properly? All cam/crank pins line up and the bottom pulley hasn't slipped?
Al
Facebook
Posted 18th Nov 2013 at 18:34
tony1991
It could be my fault but took my time fitting it as I have spent a fortune on it. But I'm no mechanic . I had my mechanic time it all up, it has a richw bottom pulley. I'm thinking would the green temp sensor have had it?
Posted 18th Nov 2013 at 18:54
allanallen
It'll still start with a fooked green temp sensor. What does your 'mechanic' think it is? Or has he washed his hands now he's had your money?
Facebook
Posted 18th Nov 2013 at 19:00
No I'd say you have missed some earths on the gear box or have put them all together which you can't do either ! Check your earths !
Posted 18th Nov 2013 at 19:01
tony1991
No he is coming round in a bit to take a quick look. It could be the earths tho I will try that when I get back. I'm right in saying two cables which then go to the chassis. Then the negative to the battery ?
Posted 18th Nov 2013 at 19:04
Yup they must be on separate earth points ? - battery earth separate to the other 2 ? Defo got fuel ?
Posted 18th Nov 2013 at 19:07
tony1991
Yer this one has fuel haha. Yer I have them bolted al together I do remember them been separate. Thanks for advice il let you no how I get on in a wile
Posted 18th Nov 2013 at 19:10
That will be the problem
Posted 18th Nov 2013 at 19:17
tony1991
The earths didn't work still no closer il see what my mechanic says when he gets here
Posted 18th Nov 2013 at 19:59
Crash switch pressed down ?
Posted 18th Nov 2013 at 20:15
Map sensor and Icv plugged in ?
tony1991
Yer I tried another map sensor an I had cleaned the icv before I fitted it
Posted 18th Nov 2013 at 20:17
A good call and easy to check. Yes
Check the crank sensor is plugged in also. Thumbs up
Posted 18th Nov 2013 at 21:39
And the tdc sensor
Posted 18th Nov 2013 at 21:40
Hmmm how did you clean it ? If you mess around with them they are easily fvcked up Yes
Posted 18th Nov 2013 at 21:41
tony1991
Yer crank sensor was plugged in we just changed it for another one I had the car is a lot closer to starting after the swap I have a brand new one coming tomorrow. My mechanic plugged it in an couldn't seem to get a rpm reading so changing cam an crank sensor if no joy he is having it in at the garage
Posted 18th Nov 2013 at 21:43
tony1991
I sprayed icv with carb cleaner that was all. Am I right in saying it would fire up with dodgy icv but just won't idle
Posted 18th Nov 2013 at 22:02
allanallen
What's with the separating earth cables thing? Why does that cause issue?
Tried bumping it??
Facebook
Posted 18th Nov 2013 at 22:14
tony1991
I haven't put the drive shafts back In yet I wanted to just get the engine running I will start putting them in tomorrow night if I get time along with trying new crank and cam sensors
Posted 18th Nov 2013 at 22:18
Tried bumping it??
No idea it just needs to be done separately
Posted 18th Nov 2013 at 22:22
tony1991
Fitted new cam an crank sensors still no joy so I think it's going to have to go in to the garage an have the mechanic have a look over it
Really bugging me after just spending a fortune on it
Engine rebuild with rich w head gasket an flywheel
2 New sets of wheels
Suspension.
Harnesses
Engine mounts
So just want it running now
Posted 19th Nov 2013 at 20:33
tony1991
Sounds abit silly as the richw flywheel has a pick u point but there is only one possible way it can go on isn't there my mechanic was wondering if it was out of time if that makes some kind of sense. With the crank sensor getting the signal at the wrong time
Posted 23rd Nov 2013 at 15:14
Nothing to do with the flywheel, it'll still work fine. Thumbs up
Posted 23rd Nov 2013 at 15:41
Unless you bashed a tooth off the flywheel when it went on?
Posted 23rd Nov 2013 at 15:56
Pages (3): [1] 2 3
