displaying posts 76 to 100 of 123
Pages (5): first .. 3 [4] 5
Author Subject: Project 6' (Ph1 Cossack)
luke89
Post #76
This looks fantastic, great work on the paint, I'd love to have the knowledge to get mine looking that good.
Posted 31st Dec 2014 at 23:06
gretsch-drummer
Post #77
Cheers Luke. I'll be even happier with it if it keeps idling like this from now on:
Ph1 Cossack 6'
Posted 1st Jan 2015 at 22:29
luke89
Post #78
What do you think was the issue in the end mate.
Posted 1st Jan 2015 at 23:33
gretsch-drummer
Post #79
I think the TPS plug might have played a part. I removed the plastic wire shroud as this really kinks the wires and removed the rubber shroud from the top of the plug and there were traces of oil inside. Removed the wires and plug and gave everything a good clean. Then left the battery disconnected over night for an ECU reset. Took a while to get the bloody alarm to turn off after reconnecting the battery though.
But looking through my cars history I got with it, there is a piece of paper which reads:
"TPS fault- Open circuit"
Will be getting it down to the garage to get wiring checked next week.
Ph1 Cossack 6'
Posted 1st Jan 2015 at 23:55
luke89
Post #80
Interesting, I'll be in Leeds the week after next if you're knocking about.
Posted 1st Jan 2015 at 23:59
gretsch-drummer
Post #81
Yeah I'll be about. If you need someone to have a look over your car as well, I use someone who was Pug master tech when 6's were about so he knows his stuff.
Ph1 Cossack 6'
Posted 2nd Jan 2015 at 00:27
luke89
Post #82
That would be brilliant mate, I really need someone to look at it as I've never so much as seen another in person to make sure mine runs right.
Posted 2nd Jan 2015 at 02:53
walker_texasranger
Post #83
Glad it's running now mate Thumbs up
That stalling issue is one of the most frustrating things on these cars!
Hilux InvincibleX daily
306 No.13 Doh
Posted 2nd Jan 2015 at 11:27
gretsch-drummer
Post #84
Didn't last long....Starting it 30mins after coming home from a perfect run it's being a c*nt again:
http://vid60.photobucket.com/albums/h19/gretsch_drummer/20150102_210948_zps6kf3qrbr.mp4
There's a clio 182 Trophy that's caught my eye.
Ph1 Cossack 6'
Posted 4th Jan 2015 at 10:37
Stuwee
Post #85
Have you checked the wiring loom under the thorttle body has not got a spit wire ?
Seen that cause eratic idling before, oil tends to leak from the throttle body to inlet pipe union on to that part of the loom which connects to the tps and map sensor and eventy causes the wire to go hard and then fracture.
Hope that helps.
Ph1 Cossack 6
Posted 3rd Jan 2015 at 21:07
gretsch-drummer
Post #86
Cheers Stu, there are traces of oil under the TB so you're right. Will remove the inlet piping and have a look at the wiring. Has GOT to be the only problem now.
Oh the joys of il-heat shrinked wiring.
Ph1 Cossack 6'
Posted 3rd Jan 2015 at 21:25
Stuwee
Post #87
No worries.
It can be an arsehole considering where the wiring loom is, it only a short length of loom before going into the main part of the loom.
You can also test the continuity with a multi meter which will also prove if there is a break or not. Sounds like wires are still making contact with each other as you said it comes and goes.
Ph1 Cossack 6
Posted 3rd Jan 2015 at 21:36
gretsch-drummer
Post #88
I wonder what the previous owner had done when he had the 'Permanent fault- TPS short/open circuit' found on the diagnostics. Non of the TPS wires looked chopped/repaired when I cut off the plastic shrink etc.
Strange.
Ph1 Cossack 6'
Posted 3rd Jan 2015 at 21:46
Stuwee
Post #89
Not sure on that tbh. Might have been a fault code stored, sometimes the fault will be stored but the light will not come on.
The ecu light is piontless on a 6, it never comes on , could be running 3 cylinders and still will not come on LOL
If it has been repaired before then it is probs the repair joint, a weak soilder joint etc.
Ph1 Cossack 6
Posted 3rd Jan 2015 at 22:21
luke89
Post #90
I might go and have a look at my wiring actually. Also the same cable that comes from the MAP sensor has another connector thats plugged into nothing, I assumed it was a spare unused connector but maybe not.
Your link doesn't work for me by the way mate.
Posted 4th Jan 2015 at 00:11
gretsch-drummer
Post #91
Fixed the link now. Cheers.
I've got 2 ununsed plugs from the MAP sensor plug I think.
Ph1 Cossack 6'
Posted 4th Jan 2015 at 10:38
luke89
Post #92
How strange,looks a completely different issue to mine.
Posted 5th Jan 2015 at 00:13
gretsch-drummer
Post #93
When the cars running crap it also has the problem like on your video with very slight throttle the revs will hang and drop slowly. Also sometimes when ever you'd set off with the slightest throttle the revs go straight to 2k. It's like the ECU can't detect the movement between 0k and 2k revs.
Any way, I've got it booked into 'Carwurx' for the week for Chris to sort it.
If not, it's Clio 182 time.
Ph1 Cossack 6'
Posted 5th Jan 2015 at 09:08
mik
Post #94
Hope you get this issue sorted, as is a really nice car.
On the paint thing, sometimes it looks OK initially as paint takes up to 6 weeks to fully dry, and there is some shrinkage as it dries which means flaws are not so noticeable initially.
Cherry Rallye SOLD
Posted 13th Feb 2015 at 17:56
gretsch-drummer
Post #95
It's been 'ok' for a week and hasn't done the 3k start idle, but it has cut out a couple times when dipping the clutch.
But it's driveable if I'm careful and drives spot on when it's playing ball.
Ph1 Cossack 6'
Posted 13th Feb 2015 at 18:38
gretsch-drummer
Post #96
Right, been on a bit of a spending spree. First bought a new CTS from pug and the car starts ALOT better, no dodgy starts or revs etc.
But also bought a set of Bilstein B4s, Eibach 30mm springs, pug strut bearings and metal drop links (thought I'd see how these are as I've only ever used plastic ones before). Got Carwurx to fit them all.
Here's how it sits just after fitting:
Think I might have to have a play with the rear beam, the front right sits 15mm higher than the left and the left rear sits 15mm higher than the right. But my driveway might have a slight slant. Also I think the metal droplinks transmit a bit more road noise.
But the ride is great on those billys and 'bachs.
Ph1 Cossack 6'
Posted 12th May 2015 at 18:01
heliosphan
Post #97
If you're experiencing increased road noise after fitting new shock absorbers, springs and drop links, it is overwhelmingly more likely that the shocks and/or springs are the cause, not the droplinks.
Posted 12th May 2015 at 20:33
gretsch-drummer
Post #98
Bugger, well I'll just have to live with it. Cheers.
Ph1 Cossack 6'
Posted 12th May 2015 at 21:11
jeffers Forum Admin
Post #99
i ran metal drop links on mine when it was standard and they never increased road noise I'd suggest it's the newly fitted dampers etc.
Team Running Engine again!
Team Negative Camber!
Posted 12th May 2015 at 21:14
gretsch-drummer
Post #100
Well not much has happened except getting the lower engine mount replaced a few weeks ago and it currently having its clutch changed. (GSF had a 41% discount code so brought Valeo kits down to £60!)
Managed to find a set of cyclones with centre holes machined out on ebay for just £20:
And now trimming down centre caps so they push right in:
Will be sending them off to the powder-coaters when done. Not messing about doing them myself when it will just cost £60 for all 4.
Ph1 Cossack 6'
Posted 24th Feb 2016 at 14:26
