displaying posts 51 to 75 of 123
Pages (5): first .. 2 [3] 4 .. last
Author Subject: Project 6' (Ph1 Cossack)
chrisd306
Post #51
I love phase1 Cossack 6's good progress with this
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 15th Apr 2014 at 01:46
RetroPug
Post #52
gretsch-drummer wrote:
Hmmmmmmm strange that it worked absolutely bang on for 2 week after it being in storage for 4months and now playing up...
Mine broke on the way home from buying it, and had apparently only done it once or twice before.
Bloody Peugeots... LOL
Posted 15th Apr 2014 at 10:41
gretsch-drummer
Post #53
Well after going for a good boot I decided to give the dash another go.
Well, looky here:
Repairable?
Edit: Well after putting a multimeter to it, it still seems to let current through so not the problem....bugger.
Ph1 Cossack 6'
Posted 18th Apr 2014 at 18:09
gretsch-drummer
Post #54
Had clutch cable changed which was great for about 10 clutch presses....then adjusted it self back up to being stiff again ha! But is better than before.
New gearbox oil and seals to go on next weekend along with a couple of these for the rear:
Toyo R1r's;
In other news, rev/oil guage is still being a dick. Handbrake light also.
Ph1 Cossack 6'
Posted 27th Apr 2014 at 13:22
pebbles167
Post #55
R1R's, very good Cool
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 27th Apr 2014 at 16:13
RetroPug
Post #56
What did you do to your rear exhaust silencer?
Did you pretty much just prep and paint with silver VHT paint?
Considering refurbing my std. exhaust.
Have you checked the loom along the bottom of the rad?
Posted 28th Apr 2014 at 13:19
russbez
Post #57
LOL LOL
typical eh!
My Rallye project thread
Posted 28th Apr 2014 at 13:38
gretsch-drummer
Post #58
I just prepped, primered, silvered and lacquered it. Didn't use fancy high temp paint and it's holding up great.
(Haven't checked the loom yet. The dails work for a whole 2 seconds! at the weekend when turning it on.)
p.s having the 'reset' button so god damn frigging close to the 'Submit' button when replying is annoying. Yeah, I've written this reply twice now.
Ph1 Cossack 6'
Posted 28th Apr 2014 at 19:13
RetroPug
Post #59
Hmm. I've already got some silver VHT paint.
Glad to hear it is holding up well, might give it a go myself.
Yeah mine are still being funny.
Posted 28th Apr 2014 at 20:25
gretsch-drummer
Post #60
Had a bit done at the weekend by Chris at 'Carwurx': gearbox oil changed, rear tyres swapped for Toyo R1r's and just this morning had https://www.puredents.co.uk (Leeds based) out to sort the boot dent:
Sh1t on a blanket springs to mind:
Before:
After:
Will be getting quotes for pass' door to get sprayed and order a couple more R1rs for the front in the next couple weeks. Also swapped clocks from my 1.6 to see if rev counter would work but it didn't, but putting 6' clocks in the 1.6 didn't work either so these type of clocks mustn't be interchangeable.
Ph1 Cossack 6'
Posted 7th May 2014 at 20:44
tvrfan007
Post #61
Feck that's a good dent repair!
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 7th May 2014 at 11:07
gretsch-drummer
Post #62
Took a trip to Chris at CarWurx again this afternoon. He changed boths tyres, wishbones, droplinks and did the tracking. Now eeeeeevery suspension part on this car has been changed so nothing to worry about for a while then:
Might take a drive out tomorrow and get some decent pictures (of its good side).
Dropped the passenger door I picked up a couple weeks ago to the body shop and it's ready to pick up on Monday. Only wanted £80 to spray the whole door, inside and out. Carter & Browns in Leeds city centre.
Ph1 Cossack 6'
Posted 17th May 2014 at 19:16
gretsch-drummer
Post #63
Well had the door fitted and innerds' changed, it's not the best respray in the world i.e primer sanding marks visible under the lacquer but I didn't expect perfection for £80.
Anyway, I had a spare hour to have a go at wet sanding the door to try get rid of the orange peel:
Before:
During: (2000, 2500, 3000 grit)
After a couple passes of Meguiars compound stuff. (Will be trying G3 compound because some sanding marks are not fully buffing out.):
Will be finishing tomorrow.
Edit:
Alot better after some G3 compound:
Ph1 Cossack 6'
Posted 8th Jun 2014 at 15:27
thegatekeeper
Post #64
Looks good!
You need to update this over on .net.. lol
GTi6 - 164.6bhp @ 6300rpm and 152.3ft-lbs Torque @ 3650rpm
Audio - Alpine ida-x313 HU, Sony XM-2002 Amp powering a Hi-Fonics Titan TXi12S4 Subwooder, with Alpine SPG-17CS components powered by a Ground Zero GZIA2130HPX Amp
Posted 9th Jun 2014 at 12:20
gretsch-drummer
Post #65
So have a couple C5 steelies int' shed so decided to get one of em powder coated to use as the spare. Wheel and carrier done for £25, bargain.
Now using as my daily, can tell already it's better on fuel than my 1.6 POS.
Ph1 Cossack 6'
Posted 13th Jun 2014 at 13:24
gretsch-drummer
Post #66
Big Update!:
I have..........a working rev' counter!!!!!!!!
After 2 months of not working, it decided to fix it self this morning.
French Electrics....just magic.
Ph1 Cossack 6'
Posted 21st Jun 2014 at 13:55
gretsch-drummer
Post #67
So the underneath is done:
Next I'm wanting to get my top engine mount looked at as I'm getting a squeak/creaking on and off throttle (but seems only when cold though....hmmmm)
Ph1 Cossack 6'
Posted 7th Jul 2014 at 00:45
gretsch-drummer
Post #68
Well just to keep things alive:
She's still going strong. Just been running it as a daily doing 100+miles a week. Just this week I've replaced the ICV, MAP and Coolant temp sensor as it went a bit dodgy during the cold weather. It's also just had a full service down at Carwurx (where he found a damn screw in my tyre, luckily it was repaired.) Had to use it as a removal car a few weeks ago as I've moved house:
Plans:
Remove and clean the throttle body (sounded a bit scratchy when having a look around)
Ph1 Cossack 6'
Posted 15th Dec 2014 at 23:53
RetroPug
Post #69
This is my inspiration to restore mine, absolutely gorgeous car.
Do wish my rev counter would magically fix itself though!
Posted 16th Dec 2014 at 12:14
mik
Post #70
Looks great, lovely car. If you are using a C5 'steelie' alloy as a spare, I'm pretty sure you would need to carry 4 C5 wheel bolts as they are not the same as Cyclone bolts?
Cherry Rallye SOLD
Posted 17th Dec 2014 at 05:59
gretsch-drummer
Post #71
Yeah Mik, I've got a set of tapered bolts in the boot. Hope I don't ever need to use them though.
Ph1 Cossack 6'
Posted 17th Dec 2014 at 20:53
orta
Post #72
Love phase 1s! And this one is minty! Every consider sitting it on some black 205 speedlines?
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 20th Dec 2014 at 20:59
Stuwee
Post #73
Looks mint.
Would love mine to be this cosmeticly clean. One day i might get round to sorting mine.
Ph1 Cossack 6
Posted 31st Dec 2014 at 18:12
Post #74
Before:
Edit:
No excuse for the sanding marks, you payed for it done , they priced it up they should if done it right.
I did the same I had bonnet and bumper done and it looked a total twat and that was before I noticed the sanding marks everywhere,trouble is when you first see it you don't notice as much you just see the Dents and chips gone and think it's ok.
ive since had to pay again for it redone and it looks perfect now and wasn't any dearer than the first time, I'd of rather given them extra the first time round for it done right and it would of been cheaper than paying twice anyway, if your not happy take it back, if I wasn't so far away I would of.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 31st Dec 2014 at 18:41
gretsch-drummer
Post #75
Yeah I could have taken it back but I tend to stay well away from places which turn out shoddy work. If I want the car perfect I'll have to spend £2k on a full respray which ain't going to happen. This is my daily work horse.
But recently the start up and idle has been playing so I've replaced the:
ICV, MAP, CTS, TPS and lambda and has still been playing up so now I've left the battery off and will try and ECU reset tomorrow. Determind to get the problem solved.
Ph1 Cossack 6'
Posted 31st Dec 2014 at 19:54
