Author Subject: F*****g matrix
mattuk
Decided to have a go at replacing the matrix as mine is leaking badly. How hard can it be I thought Shock Crazy s**t what a job.
Can anyone recommend the best place to purchase a nissens matrix? is there anything else I need to replace while I'm at it?
Matt.
Posted 11th Nov 2013 at 17:14
it's mostly just removing plastic interior s**t, it's not a hard job, it's just lots of it, and looks overwhelming but it's just wires
Posted 11th Nov 2013 at 17:27
As above it's not technical, just fairly labour intensive unfortunately.
I'd do it sooner rather than later as I give it 6 days until it gets to the temperature where doing a job like this becomes a bit punishing on the fingers. Personally I'd use a large crowbar if you aren't worried about superficial dash marks. Will knock hours off too.
Don't do that.
  • Posted 11th Nov 2013 at 17:34
    mattuk
    I've got the dash off etc, just need to get a new matrix slapped in. I'm not looking forward to putting it all back together if I'm honest.
    Anyone recommend a decent matrix?
    Thanks
    Matt.
    Posted 11th Nov 2013 at 17:47
    Valeo, Behr, any decent motor factor brand
    Posted 11th Nov 2013 at 18:04
    rich306
    Gsf do a decent brand, but think this way mate... Once it's done you shouldn't have to do it again (theoretically).
    Richies Project Rallye
    jamiek_uk2000 wrote:
    - Top Tip!!!
    Posted 11th Nov 2013 at 23:34
    sixysix
    IIRC, Valeo is non Air con and Behr is with A/C.
    Was around £70 when I did mine a few years ago.
    puttng the dash back together is pretty straight forward, just remember to plug everything back in, check, and double check any wires.
    And make sure it's not leaking before putting the dash back Thumbs up
    Take a look
    Posted 11th Nov 2013 at 23:48
    It's one of them jobs that's seems such a f**king pain in the arse but yet when you've finished you look back and think that was easy what was I moaning at!
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 12th Nov 2013 at 00:00
    I'd do it sooner rather than later as I give it 6 days until it gets to the temperature where doing a job like this becomes a bit punishing on the fingers. Personally I'd use a stihlsaw if you aren't worried about superficial dash marks. Will knock hours off too.
    Don't do that.
    Posted 12th Nov 2013 at 00:01
    calibra306
    As mentioned more time consuming then anything. I did mine a bit at a time ie removed all the stereo surround and dial trims , air vents and control panel and center console.
    Next day I removed wiper motor and loosened all bolts from fire wall under hood etc
    Day 3 did the inside bolts and removed heater box and matrix.
    Day 4 painted and cure rusted the steering column and repaired heater box drain pipe.
    Day 5 started putting it all back together and day 6.
    Obviously each day I just spent a couple of hours but all during I was still driving the car except when I removed the matrix and hoped it didnt rain with no wipers! Lol
    Lot less strenuous then lol
    V6 Power!
    Faster I can go the better!
    Posted 12th Nov 2013 at 00:41
    I removed my dash and matrix, threw all the bits in the back of the car, left it a year then put it back together, I had no spare screws left either!
    Posted 12th Nov 2013 at 08:42
    5 days?! jesus christ
    i suppose it does get easier doing it a few times - it's about a 3 hour job start to finish.. first time is just scratching your head and being in awe of wiring and whatnot
    Posted 12th Nov 2013 at 09:48
    Most satisfying part of this job is the 7 self tappers you're left with to pop in your 'random screw jar'.
  • Posted 12th Nov 2013 at 09:53
    or the matrix you forgot to put back in
    Posted 12th Nov 2013 at 09:57
    i suppose it does get easier doing it a few times - it's about a 3 hour job start to finish.. first time is just scratching your head and pacing around thinking for f**ks sake.
    Posted 12th Nov 2013 at 10:06
    Did mine a while ago out of precaution while I had the dash out. GSF did me
    A
    "Hella" /behr matrix for about £45 iirc that was identicke to the original that came out. Wouldn't recommend nissens for matrix's their cheaply made and brittle plastic. This is a job you want to do once. (Though their radiators are good quality)
    Just take your time and label everything. Also don't forget To plug in the brake light switch before the dash is back in.... Lol.
    Have done loads of these now can be done in about 4 hours if all goes well.
    Did one on a 106 gti a few weeks ago with a mate. NEVER AGAIN!!
    Posted 12th Nov 2013 at 13:28
    mattuk
    This job won't be done in 4hrs that's for sure LOL
    I thought the Nissens were decent quality? I'd rather put a decent one in as mentioned, it's a job you don't want to do twice No Euro car parts sell the Hella one (Behr) for £68 - I might just grab than one.
    Just found this on ebay:
    http://www.ebay.co.uk/itm/131022569683?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    should I, or should I stay clear?
    Thanks
    Matt.
    Posted 12th Nov 2013 at 18:41
    scotzman
    Posted 12th Nov 2013 at 18:51
    scotzman
    Another thing, If you haven't already removed the hoses, be careful as connections are easily broken.
    Posted 12th Nov 2013 at 19:00
    mattuk
    Thanks for that Thumbs up
    Haven't removed the hose/connector yet "how hard can it be"....remove metal clip and pull/wiggle - should be interesting! someone is selling a hosepipe and connector on ebay, I've got it saved just in case Whistle
    do you normally replace to two rubber o-rings?
    Matt.
    Posted 12th Nov 2013 at 19:26
    scotzman
    I got 2 spare hoses here if you break themBig grin
    Once you remove the metal clip, there is another metal clip thing that needs to be pushed to the side to release it.
    Posted 12th Nov 2013 at 19:43
    mattuk
    Keep them to one side for me then Big grin I've just orded the matrix from car parts 4 less online. £1.99 for 48hr tracked courier service, not bad.
    Thanks
    Matt.
    Posted 12th Nov 2013 at 19:59
    I'd change the O rings as they swell up and go hard over time and they cost next to nothing, get them from pug tho.
    Posted 12th Nov 2013 at 22:51
    pugheaven
    Iv done s**te loads of these and are easy to do, just a tip tho... before putting the dash back in, pressurise the system and check for leaks...
    2 ways to do this:
    Make a seal around the rad filler cap and blow as hard as you can whilst blanking off the over flow
    or remove the matrix inlet outlet hose in the engine bay, block one and blow down the other until your red in the face.
    If the O-rings are not seated properly or if you nick them whilst fitting you will be able to see the water or hear the air escaping from the join
    Posted 15th Nov 2013 at 20:47
    mattuk
    2 ways to do this:
    I'll give that a try. Thanks for that Thumbs up
    Matt.
    Posted 15th Nov 2013 at 23:46
