Author Subject: E46 BMW 330CI
mattgti6phase2
Hi guys.
My missus has just brought the above named car and there seems to be a problem with the passenger seat it has no function at all. First thing i checked was the fuse and to no surprise it had blown (30 amp).
Anyhow i replaced the said fuse and the seat worked for a few mins then the fuse blew again without even operating the seat at the time the fuse blew. Tried another one didn't touch any buttons on the seat and it went bang again.
Any ideas as to what could be causing this? I'm not too clued up on beemers.
Many thanks Matt.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 19th Oct 2013 at 23:18
rallyeash
Sounds like a break in the wire somewhere and it's shorting out against bodywork?
309 3dr K20 Type R
Posted 20th Oct 2013 at 10:12
mattgti6phase2
Sounds possible. And it looks like a right ballache to access to! If wiring is at fault I don't really fancy it as the wires look impossible to access!
5 x a 306 owner!
Posted 20th Oct 2013 at 11:00
honestly3k
Should have got her a 6 mate LOL
Posted 20th Oct 2013 at 11:20
mattgti6phase2
Shoulda done there quicker for starters LOL
5 x a 306 owner!
Posted 20th Oct 2013 at 14:03
jord294
have you tried asking on a bmw forum?
bound to be more knowledgeable on there
Posted 20th Oct 2013 at 15:55
mattgti6phase2
I've had a brief look and the threads i found were the back and forth movement doesn't work but the rest of the seat does.
Plus you guys are knowledgeable.
5 x a 306 owner!
Posted 20th Oct 2013 at 20:15
6waysforward
Are they heated seats?
Posted 20th Oct 2013 at 20:21
mattgti6phase2
Yes sir
5 x a 306 owner!
Posted 20th Oct 2013 at 23:33
6waysforward
If you can disconnect the heated part 1st from under the seat, then put the fuse back in. If the fuse does not pop, then its a heater problem which is more common than the seat motor wiring.
If it does still pop.......Get the multimeter out and start swearing Smile
Posted 21st Oct 2013 at 00:41
mattgti6phase2
I think the heater is seperate as it still works even though the seat doesn't.
5 x a 306 owner!
Posted 21st Oct 2013 at 08:19
