TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread
| Author | Subject: Uprated 3rd & 4th Gears for Supercharged/High Torque/Track C |
russbez
Post #101
no its not easy to pull gearbox apart?________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
superchargedblack1997gti6
Post #102
Think to fit its a bit of a pain and you'll need gear pullers?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Post #103
Thought so.________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
russbez
Post #104
superchargedblack1997gti6 wrote: Think to fit its a bit of a pain and you'll need gear pullers? ahh? someone put gearbox together for you mate? just picturing pulling a gearbox apart and everything pings off in different directions ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
hugovox
Junior User Location: Lima Registered: 29 Mar 2011 Posts: 95 Status: Offline |
Post #105
Well, my mechanic said he doesnt had any problem. Im going to collect the this afternoon. |
Post #106
Guess it's fine to do if you know what your doing and have the correct tools ? Standard socket set is not gong to cut it me thinks |
Post #107
Sledge hammer Should take the box apart________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Post #108
bigbadbowen wrote: Guess it's fine to do if you know what your doing and have the correct tools ? Standard socket set is not gong to cut it me thinks actually, you'll get quite far with just a socket set and a small pointy screwdriver a hammer and some punches, as long as said socket set has a 12 sided 28mm socket in it. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
hugovox
Post #109
Well, i have collected my car today and i have to say that the kit its amazing, the sound and the gearchange its very fast, the only thing im worried about its a clicking sound when the car its in neutral, like something is loose, but my mechanic said thats normal.I have tested the car at the main avenue in here, and everything is normal. In a few days ill put a video in youtube so the forum can have an idea of my happiness. Thanks ASH!! |
Post #110
Video of the gearkit in action________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
hugovox
Post #111
Hi everyone, sorry for the delay in hanging the video but I've been kind of busy with flights. I can say for the moment that the gearshift can be made with the clutch but have to be quick, so the engine dont lose to much Rpms, the more delay the more damage to the dogs, the faster the best, just slight pressure on the lever and when the clutch enter the gearshift will enter very easily. To make the shift without the clutch you have to remove the engine load, this is to remove the pressure on throttle just a moment and shift to the next gear, fast and accurate, then accelerate. Here you can also make a slight pressure to the lever and just when the engine drops Rpms the next shift will enter fast. To downshift you need to give it a little pressure to the accelerator just a dab to increase the rpms and at that moment move to the next gearshift.I have used the car a couple of times and no worries, the gearbox works fine. Well guys, i dont have time this week to record the video but I have free weekend so I hope to do the recording this sunday. Best regards from Peru and sorry for the bad english. |
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
Post #112
Nice review May be a silly question but it sounds like normal shifting through the replaced gears is not advised? ![]() ________________________________________ Just Drive It |
hugovox
Post #113
rallyestyle wrote: Nice review May be a silly question but it sounds like normal shifting through the replaced gears is not advised? ![]() Hi mate, if you make the shift quickly and accurately you'll hear a light clunk (using the 2 methods, using the clutch but doing the gearshift very fast and the other method lifting the throttle pedal just a moment allowing the engine load to be removed, make the gearshift and accelerate) but if you use the clutch and make the shift in the normal way, or very slowly allowing to decrease the rpms too much you'll hear and feel like something is going to break down. I recommend a quick shifter, solid gear links and a lightweight flywheel. Greetings |
pebbles167
Seasoned Pro Location: Melksham. Wiltshire. Registered: 08 Dec 2009 Posts: 2,516 Status: Offline |
Post #114
Was there ever any interest to make more of these?________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
rallyestyle
Post #115
pebbles167 wrote: Was there ever any interest to make more of these? I would think after a bit more feedback there will be. Wetehr Ash can get any more made im not sure ![]() ________________________________________ Just Drive It |
Post #116
anyone can get them made, just depends if you can afford the costs of a one off.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pebbles167
Post #117
I could probably afford it, but id rather not ![]() How much does a used dog gear kit go for roughly? Didn't a 6 speed one sell recently for around £1700? ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
Post #118
not sure on 6 speed, but a drenth dog gearset is about £2500________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
Post #119
The Sadev one on ebay went for £2k which was pretty cheap I thought, but they are only rated to around 180lb/ft so a SC engine would obliterate it. Theres a vid here> https://www.youtube.com/watch?v=rYwAIs8Bwpo of me using my dog box but its not very clear, and it looks like I am using the clutch occasionally too. Main thing with dog boxes is to be firm and positive in the gear change, don't dilly dally because the dogs aren't forgiving at all like a syncro is. If you crunch the gears you'll knock the dogs off which will inevitably end up mashing the rest of the box. If you're going to do clutchless down changes then do all you're braking before changing down so the load on the dogs is minimal. You can even left foot brake then a dab of throttle to unload the dogs and drop it down a cog although it'll take a lot of practice! Up changes are much easier and less likely to destroy your dogs, just load the gear lever then off the gas and back on again and the gear should change nice and positively. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pete_rallye
Post #120
I know a man thats been trying to get hold of a new final drive for his but Drenth won't make one so not sure they are still making the dog gear kits. Only people I know is Sadev but they are limited in there strength and you can still buy the original Pugsport ones like I use but they aren't cheap and I don't know what torque they are rated too, Avanti motorsport do a kit also but not sure if its a dog kit or not. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pebbles167
Post #121
Thanks for the info guys I was thinking of getting either a dog gearset or complete box to start hill climbing late 2014/early 2015. The rallye id use is a standard engine with PT80 cams, unlikely to have any more than 170bhp so torque shouldn't be an issue. If another group buy for the 3rd and 4th started Id be intetested. Seems like a good compromise. ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
Post #122
bacci romano do 6speec kits________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pebbles167
Post #123
Good shout on the Bacci Romano, £4500 will get you a full set by the looks of it. ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Post #124
The gear company made a few spare sets so if you speak to ash he will be able to get you a kit |
pebbles167
Post #125
Thanks for the heads up ________________________________________ 2005 Peugeot 206 GTI 1802008 BMW K1200R |
