Author Subject: help a.s.a.p
mike rallye
Am about to do my timing belt, but when I come to time it up, the bottom pulley doesnt line up. My questions is can I pin the camshafts up , then remove the belt and time the bottom up?
I am in process of getting another pulley but need me car on road tonight.
Cheers mike
Posted 9th Sep 2013 at 19:01
fordygti
I my small knowledge of cam belts etc, I'm pretty sure it won't time up every cycle of the engine. I'm someone will confirm.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 9th Sep 2013 at 19:03
jeffers Forum Admin
Sounds like your bottom pulley has slipped. DO NOT pin up the cams then time the bottom end up believe me it will end in tears! Personally I would source a known good pulley, then pin everything up and change the belt, I wouldn't do the belt without being able to pin everything just my 2p's worth! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 9th Sep 2013 at 19:26
mike rallye
Ok cheers Jeffers.well I got a new pulley coming .so when my new pulley arrives,what the best way to time it up then ?
Posted 9th Sep 2013 at 19:30
jord294
Fetch it up to me mate.
Or once you have the new pulley just take old one off and fit new one
schimples Smile
Posted 9th Sep 2013 at 19:42
mike rallye
So if I remove the old pulley, (and not pin it as it out). And fit my new pulley should i assume it should time up spot on?
Posted 9th Sep 2013 at 20:25
ryangti6
If the cams are pinned when you remove it all then yes a new pulley should theoretically line up. When pinned all the pistons are half way up/down the cylinders so even if you have to move it slightly it won't be a problem.
Ryan
Posted 9th Sep 2013 at 20:28
mike rallye
Just quick question guys, are these vvt? And are they floating crankshaft?
Posted 11th Sep 2013 at 18:35
No and no.
An you don't need to use the crank pulley to time up the bottom end anyway. If your doing it properly then lock the flywheel through the 8mm hole behind the starter motor then disregard what the crank pulley says anyway.
Posted 11th Sep 2013 at 18:41
You can time it up without the pulley,but if your pulley has slipped you need a new one anywayYes
If it comes apart totally it will prob take your cambelt out and knacker your engineThumbs down
Posted 11th Sep 2013 at 19:09
jeffers Forum Admin
armzs16 wrote:
No and no.
I could be completely wrong here but I was under the impression our cars didn't have the 8mm hole to time up through the flywheel?? Dunno
Posted 11th Sep 2013 at 19:27
You are completely wrong. Thumbs up
I can send you a lovely picture of a 6 engine I have the head off at work currently with a proper pug locking tool through said hole locking the flywheel as we speak lol.
All pug engines to my knowledge have this petrol and diesel. It's a pain to get to on a 6 engine others are easier.
Posted 11th Sep 2013 at 19:34
jord294
Mike
The simplest way is, remove your old pulley, fit your alloy one, then rotate till you can line up and lock the cam pulleys and the 8mm hole in bottom pulley is at about 11 o'clock
Posted 11th Sep 2013 at 20:34
jeffers Forum Admin
Hmmm fair enough, I should look for this on my engine build tomorrow! Doh!
Posted 11th Sep 2013 at 20:50
Lol the problem comes when you fit a lightened flywheel from Rich W like I have as there's no hole in the flywheel to lock with!
Posted 12th Sep 2013 at 18:49
mike rallye
Do we have to slacken the cams off to allow to get the timing belt on ?
Posted 13th Sep 2013 at 12:02
You will need the slacken the cam pulleys once you have pinned the cams up. Yes
Posted 13th Sep 2013 at 12:42
mike rallye
Right i have changed the belt few ,but still have this slight misfire when cold ,i thought it might be because i was a tooth out .but have marked it up and it times up perfect .anyone got any ideas ? I have done a video will put up in a bit
Posted 13th Sep 2013 at 13:06
mike rallye
I have uploaded video on youtube , but how do I get the link to put it on here? I think I might have found the fault, as I pulled the coil plug off one by one and one plug didnt change note. Have swopped coil pack over so will see how it goes.
The only thing I have noticed now is, it is popping a lot more than before is this normal?
Posted 13th Sep 2013 at 18:17
No,popping could suggest the timing is outThumbs down
Should run exactly the same as it did before you changed beltYes
Posted 13th Sep 2013 at 18:39
mike rallye
Even those all the timing holes line up? It use to pop before when coming off the throttle , but it just does it bit more when coming off throttle
https://www.youtube.com/watch?v=9E68D8yJ-As&feature=youtube_gdata_player
https://www.youtube.com/watch?v=_vquxTa4sic&feature=youtube_gdata_player
Couple of videos before i changed the coil pack
Posted 13th Sep 2013 at 18:59
rich306
Your videos are coming up as Private mate, can't view them!
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 13th Sep 2013 at 22:25
