Author Subject: Cylinder head
Curtains
Anyone got a cylinder head preferably complete and not a tapper? Must be in good condition.
Got a feeling mine has been over skimmed !!!! ( Im aware of the step that shows its been over skimmed but it was already back on before i knew that :-/. )Gonna take it back off as have checked and double checked the timing after gasket change and it still locks up when trying to turn it by hand
What kind of price would i be looking at??
Thanks in advance
Posted 8th Sep 2013 at 21:31
tarret
What car you need the head for?
Posted 23rd Sep 2013 at 23:07
fatlapit
Ive got a 6 head
Posted 24th Sep 2013 at 08:08
fatlapit
Ive got a 6 head
Posted 24th Sep 2013 at 08:09
Your bottom pully is probably f**ked so your not timing it up correctly! Lock the flywheel with an 8mm drill bit or bolt then pin the cams up you'll find its probably out.
Posted 24th Sep 2013 at 09:23
dcc
there is no 8mm hole in an XU10 flywheel for locking purposes.
on the left, XU10, on the right, XUD.
205 GTI
Xsara HDI
Posted 24th Sep 2013 at 10:38
jimmyrallye
Think dcc is the new welsh pug
Posted 24th Sep 2013 at 13:21
ryangti6
jimmyrallye wrote:
Think dcc is welsh pug
EFA Thumbs up
Ryan
Posted 24th Sep 2013 at 13:25
ryangti6 wrote:
EFA Thumbs up
I'd hope not. Permaban for both if so according to the admin team after the owain/gilesy/buzz etc incident.
  • Posted 24th Sep 2013 at 13:34
    dcc
    Oh the three knobennds episode?
    205 GTI
    Xsara HDI
    Posted 24th Sep 2013 at 13:42
    So I must have imagined using it yesterday to time up a 6 engine I just put a head on and imagined doing it many other times lmao
    Edit: Also used it on the phase 2 Diablo 6 I used to own when I was doing the cambelt at home without any air tools and the crank pully bolt was sized solid. Pulled the starter off and locked it with an 8mm drill bit that ended up very bent as the puly bolt was so solid.
    I only regret not taking a picture of the one I did last week with the timing tool on the flywheel to show all the people that say there isn't a flywheel lock that there is.....
    Posted 24th Sep 2013 at 13:57
    I'm intrigued if mine has the hole. If it does - I'm f**king it.
  • Posted 24th Sep 2013 at 14:02
    right, we need 10 photos of flywheels to solve this once and for all
    is that one on the left in dcc's photo even a gti6 one? mine has cutouts all around the edge [3 of them]
    Posted 24th Sep 2013 at 14:05
    http://www.rikky.net/upload/lump_flywheel.jpg
    Posted 24th Sep 2013 at 14:10
    superchargedblack1997gti6
    You can see the hole in you're pic Rikky top left of the flywheel.
    Posted 24th Sep 2013 at 14:25
    dcc
    wrong side of the flywheel for the hole LOL that's a clutch pressure plate dowel hole.
    100% an XU10 215mm flywheel vs XUD9TE
    205 GTI
    Xsara HDI
    Posted 24th Sep 2013 at 14:34
    they're the dowel holes aren't they for the clutch?
    edit> was checking old photos before he beat me to it
    Posted 24th Sep 2013 at 14:37
    http://www.306gti6.com/forum/showthread.php?id=131672
    Welshpug says it had one too! Dunno
    Posted 24th Sep 2013 at 15:17
    dcc
    no he did not, look at the OP....
    205 GTI
    Xsara HDI
    Ah for hdi my bad.
    Posted 24th Sep 2013 at 15:23
    http://www.306gti6.com/forum/showthread.php?id=120387&page=1
    But in this thread he says it is there ?
    Posted 24th Sep 2013 at 15:40
    he says it's the same casting, for the block, and that it's only used on the XUD LOL
    i want a photo now of a gti6 flywheel with the hole, i literally won't sleep until i do
    Posted 24th Sep 2013 at 15:46
    2nd post he says it would be there but shouldn't be used other than to time it up?
    Posted 24th Sep 2013 at 15:48
    dcc
    quite right, you should not use any of the timing pins to lock the engine for the purpose of loosening any bolts.
    205 GTI
    Xsara HDI
    Posted 24th Sep 2013 at 16:01
