Less than 24 hours to go!
| Author | Subject: Car feels unstable! |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
Now this isn't for a 6 but a CTR, the car feels quite unstable on the motorway like it doesn't want to go straight but in all directions so I'm constantly correcting it. Also I had to do an emergency stop yesterday which could only be described as frightening, the car was all over the place. Any ideas what this might be before I chuck in to the garage? I'm not sure if its brakes or suspension as a search says it could be wheel alignment, sticking caliper, worn suspension and so on. ________________________________________ Less than 24 hours to go! |
dcc
Senior User Location: Wales Registered: 24 Feb 2009 Posts: 502 Status: Offline |
bushes. also the rear dampers are known for being tired after 50-60k, but people cant undo the bolts so dont bother changing them. the other thing is if it has those stupid after market rear camber arms, they can serious f**k up the ride quality.Personally get a 4 wheel alignment done and see where you're at. ________________________________________ 205 GTIXsara HDI |
andy306gti
Regular Location: Ilkeston, Derbyshire. Registered: 12 Jun 2008 Posts: 173 Status: Offline |
Seconded on the bushes. Ours were worn at 5 years old and felt quite unstable especially under braking. |
ian7675
Ok, I'll try the alignment first and see what it's like. It's done 100k so I'm guessing everything is getting tired.________________________________________ Less than 24 hours to go! |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
Take it you've tried the basics like tyre pressures? If so take it for alignment and when It's on the ramp rotate the wheels to check for excessive resistance on any of the brakes.Seeing as you've only just had it and assuming it was fine when you had it I'd go with a sticky caliper being a likely culprit. Bushes won't usually just go from being fine to f**ked that quickly where as the soon as you have a sticky brake it makes things feel bad quickly. ________________________________________ Ryan |
ian7675
ryangti6 wrote: Take it you've tried the basics like tyre pressures? If so take it for alignment and when It's on the ramp rotate the wheels to check for excessive resistance on any of the brakes. Seeing as you've only just had it and assuming it was fine when you had it I'd go with a sticky caliper being a likely culprit. Bushes won't usually just go from being fine to f**ked that quickly where as the soon as you have a sticky brake it makes things feel bad quickly. I initially thought it could be a caliper but I really didn't think it would affect a car that much. I guess I should try the wheels first then and see if they're locking on. Does a caliper generally exert more or less pressure when sticking? ________________________________________ Less than 24 hours to go! |
ryangti6
It depends on the cause, if It's the actual caliper sticking when you brake It's usually okay but driving you will feel it pull you about especially when not accelerating. If It's the flexi collapsing then it'll do the same when driving as there will be pressure when there shouldn't be but when you brake that caliper won't get much force so will pull you to one side. If that's the case whichever way it pulls the problem will be the opposite side. ________________________________________ Ryan |
jord294
Common fault is sticking pistons in the calipers. Something that I had to address on my car ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
ian7675
Brilliant thanks. I know CTR's are prone to brake issues so I might just rebuild both front ones (backs are quite recently replaced). Does it make sense that it feels a bit better in the morning when it's cooler or am imagining it? ![]() Edit: thanks jord, just read your reply. ________________________________________ Less than 24 hours to go! |
yippeekayay
Seasoned Pro Location: wilts Registered: 27 Oct 2008 Posts: 4,144 Status: Offline |
jord294 wrote: easy to diagnose too as the offending caliper will heat the alloy wheel up considerably warmer than the freed off calipers in my experience.just feel the heat aftet 5 mins driving...it should be obvious.Common fault is sticking pistons in the calipers. Something that I had to address on my car ________________________________________ 306 less for first time in nearly 7 years. Lets keep it that way... please refuse any offers i make to buy your 306 ( doctors letter supplied by request)Marmite and cheese sandwiches anyone??? Burns and Mcrae will be forever missed. x box "yippeekayaymofo" |
jord294
Personally, I'd get refurbished calipers. Chances are you'll find the pistons rusty as hell. Iirc, I got a pair for £160 delivered and already powdercoated red. My front brake was almost seized solid. ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
ian7675
I'll do it myself jord, it's pretty straight forward.________________________________________ Less than 24 hours to go! |
jord294
No worries. I'm just advising you may need pistons aswell________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
ian7675
jord294 wrote: No worries. I'm just advising you may need pistons aswell There's some kits on eBay that come with the piston. Just rang Honda and they want £60 for the seals and £65 for a piston ![]() ________________________________________ Less than 24 hours to go! |
