displaying posts 1 to 25 of 44
Author Subject: Highboost running rich
kroged
Hi all!
Last winter I took a trip over to the UK from Sweden and bought Greenbelts Highboost 6.
At first I thought it was crazy fast but now when I'm slowly getting used to the power I also notice it's a little down on the original power from when I first started using it.
After a run in a dyno I got about 300hp on the crank wich is a little bit to low for my liking as it's a highboost.
I installed an Innovate lc-1 and started monitoring it and got down to about 9.7 afr wich is way to rich.
Does anybody got a clue about what might be the problem?
Posted 3rd Sep 2013 at 10:40
Rich W would be the best to ask as he made the kit/conversions
Posted 3rd Sep 2013 at 10:42
kroged
I've tried to email him a couple of times since I bought the car but no answers Sad
Posted 3rd Sep 2013 at 10:49
running the correct fuel pressure?
Posted 3rd Sep 2013 at 10:55
Hes been busy lately.
He'll get back to you i'm sure
Posted 3rd Sep 2013 at 11:01
kroged
I was told the highboost should have an 4bar regulator but mine's fitted with a 3bar wich should make the engine run lean?
Posted 3rd Sep 2013 at 11:07
Yeah well that wrong for a start,
Should be 4 bar.
Check this
http://www.lynxpowerengineering.co.uk/sckitguidelines.pdf
Weird its running rich though.
Posted 3rd Sep 2013 at 11:28
birk
Interesting thread :popcorn
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 3rd Sep 2013 at 13:50
superchargedblack1997gti6
How does it run from cold? is it very lumpy?
Posted 3rd Sep 2013 at 13:55
+1 Wink
roland rat wrote:
+1 Wink
Bout as interesting paint drying really...
Posted 3rd Sep 2013 at 13:57
eliotrw wrote:
roland rat wrote:
+1 Wink
or your constant updates of "i'm gonna do x,y,and z to my car but havent got the pocket money to do so" Flip
Posted 3rd Sep 2013 at 13:59
to be fair sounds like a boost leak. engine is mapped for x amount of boost not enough pressurised air =more fuel than air and rich mixture? when was the traction fluid last changed?Dunno
Posted 3rd Sep 2013 at 14:04
roland rat wrote:
eliotrw wrote:
roland rat wrote:
+1 Wink
In my defence it was X (Suspension for ages I.e years) Charger (Y) I haven't really decided when or even if.
I think I know when but it depends on a few things, I'll either sell up for an m3 or charge it and keep it for a while longer.
Posted 3rd Sep 2013 at 14:30
allanallen
Boost leaks the obvious one
Facebook
Posted 3rd Sep 2013 at 14:46
I thought that
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Sep 2013 at 15:09
or a loss of compression within the engine? have you checked the compression of the engine?
Posted 3rd Sep 2013 at 15:18
kroged
I will look for boostleaks and try the 4bar fpr. Hopefully it will make some difference.
Maybe the lc1 is not calibrated properly
Posted 3rd Sep 2013 at 19:10
birk
Boost leak is an easy one to check up on with a boost gauge.
Lambda sensor could be one to look at as well.
Be interested if you find the fault then put it back on the dyno, was it a hub dyno by any chance?
07889376885
Dan
Posted 3rd Sep 2013 at 19:36
yes you need a boost gauge, would be better if you had one allready fitted while it was running good, you may see a drop in boost then., it can be a bas**rd finding them unless its deisel and then you can just follow the oily sutty s**t that comes out.
Am I right in saying that the ones running standard ecu don't/cant use the map sensor to adjust fuelling based on the manifold absolute pressure?
if so that could explain why it's running so rich, on mine with the dta management, when I have a boost leak, the map sensor adjusts the fuel to suit boost so it doesn't effect the af ratio a great deal.
Posted 3rd Sep 2013 at 21:54
the intercooler and pipe setups on these is s**t, I can't wait to rip mine out and get a more professional intercooler and pipe work setup.
Posted 3rd Sep 2013 at 21:53
kroged
I replaced the fpr with a 4bar and did a boostleaktest and found nothing so it is not that I'm afraid.
I recalibrated the lc1 to and now it shows a little bit better afr (about 10-11 now) but I dont know if it is becaus of the recalibration or the fpr
Posted 5th Sep 2013 at 21:06
Does it feel any differrent?
Posted 5th Sep 2013 at 21:10
kroged
Not really.. All I could feel was that it would have a little more power the first lap before the temperatures went up..
Side-question: What oil/water temperatures do you guys with highboost's get when you push them on the track? Mine gets up to 140c on the oil all to quickly wich is way to hot to be good..
Posted 5th Sep 2013 at 21:56
I have a 19-row oil cooler on my super high boost and on track it doesn't go over 100c which is good.
When I had a 13-row oil cooler it got up to 120c on track.
Posted 5th Sep 2013 at 23:01
