Author Subject: 306 Longmans Btcc Cams
gti6girl
Removed from my 306 touring car engine and in fantastic condition
These are the smallest of the btcc cams that were made, 10mm lift but long duration
I run these with pistons, rods, flowed head, Solid lifters and throttle bodies
The car was mapped at track & road and it made 235bhp
I have the valve springs to go with them also
Please do not post if not interested
£210 delivered
Posted 28th Aug 2013 at 20:32
alexcrosse
Did power roll off? What was your rev limit of the engine?
Posted 29th Aug 2013 at 08:04
gti6girl
Power did not trail off and I had rev limit set to 8500
Posted 29th Aug 2013 at 12:58
rallyeash
Do you need solids with these?
309 3dr K20 Type R
Posted 29th Aug 2013 at 13:18
yes.
Posted 29th Aug 2013 at 13:51
alexcrosse
Were the cam's the limiting factor, I would expect to see around 270 with btcc cams, especially if that is infact 328 degrees (with steel crank rods pistons head etc).
I am interested by the way.
Posted 29th Aug 2013 at 14:02
rallyeash
You'd need 12mm lift for 270hp
309 3dr K20 Type R
Posted 29th Aug 2013 at 14:06
gti6girl
Yes the max power you will get with these is 235
Posted 29th Aug 2013 at 18:52
gti6girl
The 12mm lift were the 270bhp cams and there was a 13mm lift with supposedly sees over 300bhp
Posted 29th Aug 2013 at 18:54
phil b
What about pistons
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 29th Aug 2013 at 22:07
yes, you certainly need pistons, and rods.
Posted 29th Aug 2013 at 22:10
daver6
LOL Will the pistons need deeper pockets? Smile
Wishbone Polybushes available
Posted 31st Aug 2013 at 14:26
No, as the replacement pistons would have deeper cutouts as std...
Posted 31st Aug 2013 at 16:49
gti6girl
Bump
Posted 11th Sep 2013 at 20:50
gti6girl
£175 delivered
Posted 23rd Nov 2013 at 17:41
gti6girl
Bump £160 delivered
Posted 11th Dec 2013 at 20:08
jameswallace.
Are these still for sale by any chance? If so what benefits would you expect with a standard engine and a map or even without them mapped
James
Posted 14th Aug 2014 at 12:53
demondriverdan
They won't work in a standard engine without the pistons being changed as they will collide with the pistons.
WP will probably come and correct me now... Wink
Rallye Race Car
Posted 14th Aug 2014 at 13:07
jameswallace.
Oh okay that was a thought that went through my mind as I've read so many things about clearance issues
Posted 14th Aug 2014 at 13:28
pete_rallye
I've tried fitting them with standard pistons and it doesn't work by a long way. You'll need cut outs, and I'm not confident that the cut outs that are achieved by machining standard pistons would be adequate so I'd expect to need aftermarket pistons also. My engine made 240bhp with the same cams fitted.
Lap of the 'ring
Posted 14th Aug 2014 at 21:25
allanallen
These are also solid lifter grinds.....
Facebook
Posted 14th Aug 2014 at 23:00
gisangueazul
I sent you a pm.
308 THP
306 S16 (XU10J4)
Xsara VTS Restoration project
Posted 15th Aug 2014 at 00:11
Yes, and you'll need deep pockets too to make good power from natural aspiration.
Posted 15th Aug 2014 at 12:38
tom_g205
Are these still for sale?
205 GTi-6 every day motor
205 GTi-6 weekend/track car - project 230 N/A fingers crossed.
Posted 15th Aug 2014 at 23:11
