Author Subject: fuel gauge vs corners
jimmyhackers
i might just be used to the phase 3 xsi here........
but when i go round corners in my 306 etc the fuel gauge likes to vary upto a quarter tank of needle movement.
is this normal? i remeber it being kinda like this in my other phase one but nowhere near as much varyance.
thanks
jim
Posted 2nd Aug 2013 at 19:48
Niall
You need a new fuel sender. There is a built in resistance on the float arm so it can be submerged under the fuel for a while to take into account corners and bumps etc. I had it on my old 106 and the arm lost all its resistance so even used to move up and down if you pulled up hard and the fuel splashed about in the tank lol.
Posted 2nd Aug 2013 at 19:55
LOL slow down
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 2nd Aug 2013 at 19:56
pugheaven
Phase one tanks are not baffled like phase 2/3
Posted 2nd Aug 2013 at 21:11
24seven
Mine is exactly the same, but its not the sensor at fault; if the tank is below 1/4 full it sometimes cuts out as well. Big grin
Posted 2nd Aug 2013 at 21:18
jimmyhackers
i see.... so its a combination of placebo effect from coming from a phase 3 baffled tank 306 to my phase 1 unbaffled tank.
and my float arm resistance being poop. probably the second more so.
i noticed my fuel light was cutting out on the first day of usuage like your 24seven but it seeme to of stopped now, being sat for a while hasnt helped it.
dont suppose i can swap them over? from a phase 3 xsi into my phase 1 gti? i think i remember hearing theres differences between the two?
Posted 3rd Aug 2013 at 01:12
When I met Farmer one time he was about to put a P3 fuel tank into a P1 and he seemed to know what he was doing, can't be sure it ever worked though.
I'll admit though Jimmy I'm a bit disappointed you're going with the easy option of changing the tank and not instead creating some kind of nuclear-powered anti-innertia device. I was anticipating a build thread.
Posted 3rd Aug 2013 at 06:29
Or maybe mount the tank on some kind of gimbal system so that whatever direction g-force affects the tank from it will effectively stay level, +1 on being slightly let down by Jimmy.
Posted 3rd Aug 2013 at 07:08
Something like this?
Posted 3rd Aug 2013 at 07:09
Drop the tank down and add some spring fixings.
  • Posted 3rd Aug 2013 at 08:04
    jimmyhackers
    that is a badass pool table.
    but still, if i can swap the sender/pump over rather than the whole tank id rather do that. will they swap or will i be fuel tanking it ?
    Posted 3rd Aug 2013 at 13:44
    Sender won't help, it's the tank.
    Posted 3rd Aug 2013 at 13:47
    Use a dipstick down the filler neck to gauge how much fuel is left Smile
  • Posted 3rd Aug 2013 at 13:50
    Or just fill the tank with foam.
    Posted 3rd Aug 2013 at 14:03
    jimmyhackers
    im not to bothered about it being bafflesless..... the problem wasnt anywhere near as bad in my other phase 1.
    as said by niall i think the resistance in my float arm has gone. hence me asking if i can pikey a replacement unit from my phase 3 xsi.
    Posted 3rd Aug 2013 at 14:11
    Expanding foam Devil
    Posted 3rd Aug 2013 at 14:12
    jimmyhackers
    and good shout phill......that foam will most probably be a lot easier than a tank swap.
    how much you reacon ill need?
    Posted 3rd Aug 2013 at 14:13
    Err, 60 litres? Big grin
    It's not cheap for the proper stuff though.
    Posted 3rd Aug 2013 at 14:20
    Don't buy the cheapo stuff, it gets broken down by petrol in a short time and plays havoc with fuel pumps and filters.
    Posted 3rd Aug 2013 at 14:38
    I was thinking this, don't use builders foam
    Posted 3rd Aug 2013 at 15:39
    What makes me laugh is the 1.4 fuel pump has baffles in the mouting caddy, but the phase 1 xu pumps don't. Not sure what pug were smoking that day.
    Posted 3rd Aug 2013 at 15:59
    What you need
    Posted 3rd Aug 2013 at 19:13
    jimmyhackers
    argh!!!! if only id of removed the fuel pump from my 1.4 phase one before i scrapped it a few years ago : )
    but still..... ill ask again, does anyone know if can i swap the fuel sender float arm over (things under the round black plastic panels under my seats) from my phase 3 xsi onto my gti?
    cheers
    jim
    Posted 4th Aug 2013 at 00:27
