displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: SC'ed with aftermarket management
Anyone running Omex/DTA/Emerald etc with a charger?Smile
If so, what are they like?Thumbs up
Posted 22nd Jul 2013 at 18:30
yippeekayay
Ohhh heading that way miserable???
x box "yippeekayaymofo"
Posted 22nd Jul 2013 at 18:17
Just wondering what they are likeWink
Miserable will be you when your getting up in the middle of the night changing nappies!!!Yes
Posted 22nd Jul 2013 at 18:29
pugheaven
IIRC Ash is running his c30 94 charger setup on aftermarket management if that helps, don't think many other people have as its cheaper to run it on standard management
Posted 22nd Jul 2013 at 18:31
pete_rallye
Rich_w's is on DTA. From what I've been told Wayne Schofield can make the standard ECU perform like an aftermarket one without the need for re-wiring etc. Only downside is that he seems to be the only person who knows how to do it so if you're not local it could be a big trip to see him.
Lap of the 'ring
Posted 23rd Jul 2013 at 22:51
midlife
I've seen a post somewhere saying Wayne has stopped running chip wizards, if that's true some of us will have no option but to go for aftermarket Doh
Cool
Team 330™Cool
Team "no front end or engine"
Posted 23rd Jul 2013 at 23:00
I've got a dta s60
Don't ask me what it's like as all I know about it is it runs and works.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 23rd Jul 2013 at 23:34
Rich W's car, Andy's car and mine all run the DTA S60 ECU'S.
What exactly did you want to know Kev?
Posted 24th Jul 2013 at 00:08
allanallen
How are they mapped on the standard ecu as I imagine they don't use the map sensor? Is it done on throttle position like you'd map throttle bodies? I imagine an aftermarket ecu to run them equally as good as the standard ecu and obviously much easier to map.
Facebook
Posted 24th Jul 2013 at 05:13
Mapping on the standard ECU is done wih guestimated figures. Yes
As the ECU doesn't have the facility to see positive boost, it's mapped by adding a lot more fuel than normal using the TPS as you mentioned and guessing what you will need compared to the throttle opening. Yes
Not very accurate but good enough. Aftermarket is 1000% better as you can map it properly and to the correct values. Smile
Posted 24th Jul 2013 at 09:35
pete_rallye
From what I've been told the standard ecu can be told to read positive boost using a MAP sensor from a turbo'd motor, ie a VAG 1.8T or similar. The ecu won't read it as standard but you can basically recalibrate the scale it works from so instead of reading 0>-1 bar as an eg, you can tell it to read 5bar>-1bar
Lap of the 'ring
Posted 24th Jul 2013 at 10:05
I thought you couldn't change it and it can only read vacuum not positive boost which is why low and high boost use the charger in a draw through setup after the throttle body and map sensor instead of charger then throttle body on the inlet like a turbo or stans silly boost.
Posted 24th Jul 2013 at 10:23
superchargedblack1997gti6
I spoke to RichW yesterday and Wayne still is with chip wizards he is just mobile now so obviously is not at the same premises.
Pete i think you're right on that one! Thumbs up
Posted 24th Jul 2013 at 10:46
Got a DTA in garage and seeing sc parts for sale I was just wondering as you do....Wink
Was thinking it should be a better map on aftermarket ecu for each individual carThumbs up
Posted 27th Jul 2013 at 19:08
I don't think the benefit is worth the cock around. as you'd need differrent set up you'd have to run it like a c38 with throttle on end of inlet rather than on the end of charger. in my opinion you'd be better off buying leegti6 superhighboost system and restricting the bigger charger.
Posted 27th Jul 2013 at 19:15
Id love to try it on a standard engine if Takedown can run 450bhp turbo then it must be possible to run a c38 supercharger in much the same way. wouldn't mind giving it a test! just keep boring out the restricting until it went boom!
Posted 27th Jul 2013 at 19:26
rallyestyle
Im tempted to see how much the rallye can take before it blows with C30 Yes
Just Drive It
Posted 29th Jul 2013 at 13:53
rallyestyle
Got a DTA in garage
Which one? Let me know if you sell ;-)
Just Drive It
Posted 29th Jul 2013 at 13:54
Standard rods are supposedly good for 300bhp, although how long they would last at that power level is another issue.
Posted 29th Jul 2013 at 19:10
pete_rallye
Who said that? And exactly how did they come to that conclusion? I'm assuming thats forced induction and not NA?
Lap of the 'ring
Posted 29th Jul 2013 at 19:15
Yes, what a component can take, and what it can take reliably, are two very different things
Posted 29th Jul 2013 at 19:23
pete_rallye
Indeed but I'd love to know who decided the rods are good for 300bhp and what they based their conclusion on...
Lap of the 'ring
Posted 29th Jul 2013 at 19:24
What their mate down the pub told them.
Posted 29th Jul 2013 at 19:35
heliosphan
Was it possibly post #564 in this thread?
http://www.306gti6.com/forum/showthread.php?id=152563&page=23
Specifically:
Takedown wrote:
Fact is why go forged if youre looking for around 350BHP, when the stock engine with a sandwichplate will take this night and day.
Posted 29th Jul 2013 at 20:14
Yeah definitely forced induction up to that power level, not sure about NA. There have been members who have run low boost supercharger setups but opened up the restrictor ring slightly and recorded very near to 300bhp, although it's not advisable.
When Rich first developed the low boost setup, it was running about 290bhp, but it was suggested to detune it to around the 260bhp mark for bullet proof reliability. Yes
Posted 29th Jul 2013 at 20:32
Pages (3): [1] 2 3
