Author Subject: Fuel light/guage question
DanRM
Just a quick question now that my 6 is finally on the road, When I bought the car the lad said that the gauge goes down to 1/4 and stops there. I'm not too fussed about that, but is the fuel light on a different sender? So instead of playing it safe and filling up every 3/4 of a tank I can just drive till the light comes on? I better keep a jerry can in the boot just in case.
Posted 15th Jul 2013 at 22:59
Niall
Thats bo***cks. The gauge will go down all the way unless yours is fooked. The light will come on at the top of the red and i would say you have about 30 miles left after that.
Posted 15th Jul 2013 at 23:26
dan_s16
The low fuel light and the gauge work from the same sender. when the sender reaches a certain fuel level and outputs a specific voltage to the instrument cluster it turns the light on. if the low fuel light comes on you know its the gauge playing up, if you run out of fuel before the light come on you know some things not right with the sender, its either getting stuck or just faulty.
Posted 18th Jul 2013 at 00:56
Hmm has someone had the Cluster pannel apart at some time and not put the needle back in it's proper place?
i take a picture when i mess about with the needles to make sure they go back in the right place!
here's how they should sit while off,..
try resetting yours to this pic and see what happens!
there will be a tutorial on how to get into the cluster about somewhere if you're not sure!
Posted 18th Jul 2013 at 01:28
DanRM
I'd say it's a fault with the sender then as the light doesn't come on during ignition, (assuming it should) I managed to get 396 miles before chickening out and filling up again and put 54 litres back in so I'd say I would have been near the point where the light should come on
Posted 23rd Jul 2013 at 18:46
Yes, it sound like the sender is at fault, as the light should illuminate when you first turn the ignition on. Yes
Posted 23rd Jul 2013 at 19:40
Have a look at what position your sender is set at in tankWink
Remove the big round rubber grommet from under drivers side rear seat, you will see the top of sender/pump assembly.if the petrol pipes are pointing straight forward undo the big locking ring and turn the sender unit so they point at circa 25 too the hourThumbs up
Had this on mine after refitting the sender, the float catches the tank before it gets to its lowest pointWink
Posted 23rd Jul 2013 at 22:28
Mine doesn't, only comes on when the actual fuel level is low enough to put light onYes
Posted 23rd Jul 2013 at 23:33
You've got me wondering now. LOL
It's so seldom I drive the car I honestly can't remember although I always thought it did. Laugh
Posted 24th Jul 2013 at 00:28
Niall
Also, there is a little arrow on top of the pump/sender that lines up with another arrow/mark on the tank so you know it's in the right place.
Posted 24th Jul 2013 at 12:07
demondriverdan
Fairly certain the light doesn't turn on when you turn the ignition on unless the car is low enough on fuel for it to be on. Changing the pump / sender isn't a massive job, didn't take too long when I did it.
Rallye Race Car
Posted 24th Jul 2013 at 12:19
DanRM
Ok thanks chaps, I'll have a look over the weekend, the float may just need freeing up or something
Posted 24th Jul 2013 at 19:14
this!
my fuel light only comes on when i'm low,..
but not on 1st turn or ignition if there's plenty in!
Posted 25th Jul 2013 at 19:12
stan never has any fuel in his car as it all evaporates away due to his heated garage.
Posted 25th Jul 2013 at 19:26
LOL
I think I've got between a quarter and empty at the moment.
Shockingly, the car hasn't even been touched since Pugfest yet. Shock
Posted 25th Jul 2013 at 21:48
Did you clay bar the undercarriage fully when you got home and put it away Stan? Dunno
  • Posted 25th Jul 2013 at 21:59
    rallyestyle
    Little bit of a thread revival...
    My fuel dial is stuck (i may have played around with it in the past Whistle) so that it doesn't show the current level. Just to clarify, even with the guage stuck the low fuel light should still come on independently? They work off of the same sender but one is part mechanical if you like?
    Correctomondo?
    Just Drive It
    Posted 3rd Mar 2014 at 08:46
    Yeah the low light will still come on,..
    If you want to reset the pointer use the pic above
    my light comes on as soon as the needle hits the red
    And make sure you don't press it all the way down
    Or it will stick,..
    If you turn the gage it should move freely back to
    It's original position Wink
    Posted 3rd Mar 2014 at 09:29
    rallyestyle
    Or it will stick,..
    Cheers bud Thumbs up
    I pushed it down too much previously and haven't the time to get the dils out again and reset it, just need to make sure i know when im running out of fuel LOL
    Just Drive It
    Posted 3rd Mar 2014 at 10:37
