displaying posts 1 to 25 of 34
Author Subject: Breaking race/rally car PRICES!
pete_rallye
The following bits still left-
Complete front end with seam welded subframe, rose jointed tubular wishbones, inverted bilstein shocks, springs, arb with rose jointed drop links, adjustable top mounts, gear linkages and lever (specific to subframe..), hubs. Complete and ready to bolt on! £1300
Omex 500 series ECU and loom, mapped for gti6 on throttle bodies and cams £450
Seats- 2 x Sparco Pro 2000 seats, one has small tear but other than that both are in very good condition. £200/£250
Harnesses- TRS Harnesses, 5 point 3 inch wide, in black, still in date for race use until end 2015. £150/set
AP racing 4 pots with 315mm discs mounted on alloy bells, come with performance friction pads with lots of life left. £750
AB Motorsport gearbox, 5 speed syncro with Tranx diff fitted. Most excellent box with nice close ratios. £750ono
PTS Tarmac spec box, 6 seed syncro with 4.8fd and uprated internals to cope with extra load on track use. £800ono
Manifow manifold with motorsport cat welded in. £400ono
Proper PTFE fuel lines, 2 lengths, enough to go from standard fuel pump to drivers side inner arch through the cabin. The hose is called ProGold and its the proper stuff! Includes fittings to connect to standard fuel pump flow and return connections, can included additional fittings as required at extra cost. £80
Sparco steering wheel, quite a deep dish on it. £50, or with boss £65
Unlocked standard ecu, I have 2 of these £45 each
Lap of the 'ring
Posted 16th Aug 2013 at 11:45
demondriverdan
Might be interested in the fire extinguisher system if you do decide to break it.
Rallye Race Car
Posted 16th Jul 2013 at 08:23
vts_tibi
If you break it I want the first dibs on the PTS/Bilstein suspension please! Smile (depending on the price)
VTS
best 60' : 2.272
Team Trackday™
Posted 16th Jul 2013 at 19:50
pete_rallye
Ok, but there is no mounting point on the shock body for the normal ARB as it links to the wishbone so to make the most you'd need to weld some on, but i'm not sure there is room, could be possible welding them on lower down the body and using shorter ARB links.
Personally I'd prefer to sell the whole front end as one piece, that way I know it'll be good for you.
Lap of the 'ring
Posted 16th Jul 2013 at 20:23
pete_rallye
Lots of interest in this but not as a whole car, so looks like it will get broken down.
Lap of the 'ring
Posted 16th Jul 2013 at 23:20
yippeekayay
Got any photos as it is now??. I take it this was the car built for phil morgan by gal ral just before he went the whole hog with his uk spec maxi??* phil may well be interested in it complete. Send me photos and will forward.
x box "yippeekayaymofo"
Posted 16th Jul 2013 at 23:26
pete_rallye
Theres some photos here- http://s109.photobucket.com/user/pete_rallye/library/Goldie?sort=3&page=1 but unfortunately it is not as clean and tidy as it looks there. Between the 2 times (this been the second) I owned it, it was owned by a guy who did single stage rallys. I bought it back because it was such an ace car but was a bit dissapointed when I saw it, nothing like when I sold it. Its all cosmetic and it still drives brilliantly but it does need some paint and a new door and wing and a lot of general tidying.
Don't know who Simon built it for, but I bought it from Simon Galliford, of GalRal.
Lap of the 'ring
Posted 16th Jul 2013 at 23:38
superchargedblack1997gti6
presumably has an Id and v5 Pete is it the one in the photos?
Posted 17th Jul 2013 at 15:28
blandy
Would be interested in quite a bit if you do break it I.e complete front suspension etc
Posted 17th Jul 2013 at 15:31
pete_rallye
Think I'm almost certainly going to be breaking it... and yes the shell has a chassis plate and I have the V5 for it...
Lap of the 'ring
Posted 17th Jul 2013 at 15:40
pete_rallye
New list of whats left at the top...
Lap of the 'ring
Posted 31st Jul 2013 at 00:28
Phil white
i'll take the windows please if still available!
Posted 17th Jul 2013 at 22:21
demondriverdan
Out of my price range on the fire extinguisher, thanks anyway Smile
Rallye Race Car
Posted 18th Jul 2013 at 08:12
elpatron
Interested in 30mm rear arb and solid mounts if you split and shipping to switzerland is possible?
Also interested in gear linkage with shifter assembly if 6 speed?
Posted 18th Jul 2013 at 08:27
pete_rallye
Fire Extinguisher is a lifeline zero 2000 system, 4 litre and it was new in 2012 at a cost of around £600. Includes all the pipes and everything so worth every penny of £350!
Lap of the 'ring
Posted 18th Jul 2013 at 11:43
got pics of where the pas pump sits and how pipes are routed? std git6 rack?
Posted 18th Jul 2013 at 11:46
demondriverdan
Difficult to install? Have never put one in the car.
When's the expiry on the system?
Rallye Race Car
Posted 18th Jul 2013 at 12:24
just seen the pics, that'll suit me I think, but can you get some of where its routed across the subframe please Smile
Posted 18th Jul 2013 at 11:55
vts_tibi
I understand! Smile
Although I may be interested in the rear shocks if you could tell me where can I get a matching front set!
VTS
best 60' : 2.272
Team Trackday™
Posted 18th Jul 2013 at 11:58
rallyeash
Passengers foot rest please
309 3dr K20 Type R
Posted 18th Jul 2013 at 12:27
pete_rallye
Will get pics of the power steering setup and footrest tonight.... The fire extinguisher system is straight forward to install, it runs off a 9v battery so no need to wire into the car. The tubing is alloy so you just bend it, ideally with a proper bender which is only a few quid, fittings are push fit, and the rest is just mounting a button inside and outside the car...
Lap of the 'ring
Posted 18th Jul 2013 at 13:14
demondriverdan
YHPM Smile
Rallye Race Car
Posted 18th Jul 2013 at 16:10
pete_rallye
Footrest has sold, sorry!
Lap of the 'ring
Posted 18th Jul 2013 at 18:23
fordygti
I've txt you pete. Smile
98 onyx black 306 Rallye
58 black Volvo c30 sport
blandy
Would be interested in that power steering set up if it hasn't sold already
Posted 18th Jul 2013 at 20:50
