Author Subject: Brake Air Ducts
Just removed my Spots & fitted with Tiger Bond ...cone air ducts with 65mm semi flexy Piping with exit in through inner arch cowling ...onto Calipers & Discs...& it works a treat ...temp down by loads with Maplins temp receiver!!!!
Posted 4th Jul 2013 at 23:45
Just got to tidy outside edges up tomorrow !!!
Posted 4th Jul 2013 at 23:55
Posted 5th Jul 2013 at 00:46
calibra306
I used that pipe work for an induction kit but it got very rusty very quick inside so stopped using it.
V6 Power!
Faster I can go the better!
Posted 5th Jul 2013 at 03:06
anth
Yes i had that problem too, nice to work with but didn't last long, ended up using large plastic vac pipe. will last longer than your car, pain to manipulate though.
Posted 5th Jul 2013 at 07:20
Got any more pics? I've had to remove my fog lights to squeeze in 13 row oil cooler so was thinking of making use of the lack of fogs with something similar to this.
Posted 5th Jul 2013 at 07:39
Got the largest Air Ducts from Merlin Motor sport up the road from me in Castle Combe...& cut them down with Dremel ..once I tiger bonded them in ....
Going to punch out some Stainless Mesh to stop debris on Road...entering & hitting Calipers & Discs ..that will match the 16 row oil protection cover then Thumbs up
Sorry no more pics !!!
A small bit of work needed though ...cutting & grinding front member either side 15mm to able pipes to miss.!!
& you have to remove washer bottle & replace with much smaller bottle now under bonnet ...instead of under R/h wing....
It's made a big difference & had it years ago on my Race Mini .!!!
Tried & tested you could say ..lol
Posted 5th Jul 2013 at 23:23
rallyeash
You can get proper scoops to fit from Merlin motorsport.
309 3dr K20 Type R
Posted 5th Jul 2013 at 15:21
I just use an ice cream scoop Thumbs up
Posted 5th Jul 2013 at 16:05
rallyeash
To spoon air in?.....
309 3dr K20 Type R
Posted 5th Jul 2013 at 16:07
I'm going to have to think of something different - thats where my induction filter sits Wink
Posted 5th Jul 2013 at 17:47
beez_neez_gt
For his weekends away lol.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 5th Jul 2013 at 17:52
demondriverdan
Thinking of doing the same thing to the track car at some point. How did you route the driver's side pipe around the washer bottle?
Rallye Race Car
Posted 5th Jul 2013 at 17:55
Here's how i did mine, didn't need to cut anything and kept the standard washer bottle.
Made quite a noticable difference with the standard calipers/discs. Smile
Posted 5th Jul 2013 at 18:39
Made quite a noticable difference with the standard calipers/discs. Smile[/quote
Do they connect to the spot light holes ?......I wanted mine straight with easy flow & my pipes are only 18 inchs long..
I didn't need such a big washer bottle & I don't have to mess about around it when removing Bumper now...& no cable ties needed ....ILL TAKE PICS NEXT TIME ITS APART Smile
Posted 5th Jul 2013 at 23:31
