Author Subject: Re-angled manifold 205 gti6 conversion
daipugralio
Looking for the above, where can I find them and how much?
d james
Posted 2nd Jul 2013 at 19:48
i was gonna buy one but after seeing how easy it is to do from doing mine at weekend, i'm glad i didn't
DIY FTW
Posted 2nd Jul 2013 at 19:50
How much did you cut out to get the right angle ?
And where did you cut it out ?
Posted 2nd Jul 2013 at 20:06
JWP EFi
Turbo Legend!
sure i heard somewhere that its a 30 degree cut and reduce length by 30mm, this could be bulls**t though
Posted 2nd Jul 2013 at 20:09
superchargedblack1997gti6
bear with me i found this on the 205 forum the other day. ill try an grab the link.
Posted 2nd Jul 2013 at 20:12
I did my own. Used a thin cutting disc to go most the way through then 3 hacksaw blades together to finish. Left about 10mm holding it on and pushed it down 'til if met and had it welded up. Made a suprising difference to the final angle.
  • Posted 2nd Jul 2013 at 20:15
    JWP EFi
    Turbo Legend!
    so they are not actually shortened then? and btw, thats a clever way of doing it i must say
    Posted 2nd Jul 2013 at 20:17
    Surely Welshpug could comment on this I'm sure he was on the thread I'm trying to link!
    Posted 2nd Jul 2013 at 20:18
    Not shortened at all.
    Pics of mine:
  • Posted 2nd Jul 2013 at 20:21
    yep that's how it was shown on the 205 forum too!
    Posted 2nd Jul 2013 at 20:28
    daipugralio
    I'm thinking of heating the end flange (downpipe side) with oxy/acety and teeking it downwards, surely this would get the same result and you wouldn't get a possible build up of weld on the inside pipes by welding large gaps??
    d james
    Posted 2nd Jul 2013 at 21:03
    naah it wont work down there, as its the pipes that hit the bulkhead seam not the flange.
    you wont get large gaps as you bend the manifold to close them, and you can always get a die grinder in there to dress the welds down if they are a bit messy
    Posted 2nd Jul 2013 at 21:14
    daipugralio
    Arh right! I presumed the downpipe flange would be the problem and not the pipes, doing the conversion this weekend so will cut the pipes as said..
    cheers everyone.......
    d james
    Posted 2nd Jul 2013 at 21:21
    The flange is the problem - hence cutting the pipes to aim it down a touch!
  • Posted 2nd Jul 2013 at 21:24
    How much material did you remove after cutting ? 3 - 4mm by the looks of things ? Dunno
    Posted 2nd Jul 2013 at 21:32
    I just used a thin cutting disc (what, 1.5mm probably? - whatever the thin ones you get are) and then when the grinder bottomed out I continued with the hacksaw blades as mentioned which ended up with the same thickness.
    You don't want to take too much and have gaps. As Mei says, when you close the gap (it will NOT bend) it should meet well.
    I was lucky that my thickness of cut was enough to be bang on. I took it to my friendly fabrication place and simply said "Push it until the gap closes and then weld it up there".
    Ta da:
  • Posted 2nd Jul 2013 at 21:39
    I use 1mm discs at work but you can get different thickness blades ? 3 hacksaw blades must be a good 2mm if not 3mm ?
    Posted 2nd Jul 2013 at 21:47
    beez_neez_gt
    That's better welding than the one I got from Miles, looks better than the manifolds welds, I wish id made my own now lol. Although I think iirc I didnt have my own welder back then.
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 2nd Jul 2013 at 22:02
    on mine I did what dan did - i used a .5mm slitting disc to trim right the way through 95% of the way, then used a 2mm grinding disc to go half way through it again. angled it up with pressure and welded it shut. in the bulkhead I've now got a 10mm clearance which is just right
    Posted 3rd Jul 2013 at 00:21
    Wink They did a brilliant job for a good price too. Don't forget it's stainless!
  • Posted 3rd Jul 2013 at 07:38
    yippeekayay
    Dan can you do another one smartish??
    x box "yippeekayaymofo"
    Posted 3rd Jul 2013 at 08:25
    What are you up to again? LOL
    Posted 3rd Jul 2013 at 10:29
    beez_neez_gt
    s**t yeah I always keep forgettjng that lol, its only T 304 stainless which is why it discolours making you think its mild steel lol.
    I would.only need the correct type of wire to weld it, is ss harder to weld than mild ?
    Pug fee`ver,
    Posted 3rd Jul 2013 at 11:01
    Technique is pretty much identical, it's the shielding gas that varies. Most just use the 5% argon/co2 mix though. Other better gasses are available but for the amount your gonna use its not worth investing in a bottle.
    Posted 4th Jul 2013 at 00:27
    beez_neez_gt
    What the best gas to use then for an easier job, i have a local place that does them cheap with no bottle rentle?
    Pug fee`ver,
    Posted 4th Jul 2013 at 07:30
