displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: Aux belt whistling????
mattgti6phase2
As above my aux belt likes to whistle as and when it pleases and it's got to the point that it now annoys me! It normally occurs when I've not long been driving and then it'll disappear.
The belt is a dayco belt and hasn't long been on the car (3k) as far as I'm aware it's tight enough and I even tightened it a little more today. Could it be too tight? Or does it still need tightening?
Any advice welcome.
*edit* I have the rallye belt set up and the tensioner is also only 3k old.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 21st Jun 2013 at 02:12
how much ply do you have in you're belt?
I run the non air con set-up and it is pretty tight I guess trial and error is key here!
I was once told of and old trick by and Ex's dad to run a piece of chalk along the inside of the belt and that's supposed to shut them up,.. but be very carefull if you do this while the belt is running personally I'd take it of and run chalk around the inside,.. that's if this works?
Posted 21st Jun 2013 at 03:30
It's very easy to overtigthen the rallye tensioner set upYes
And it knackers the bearings in the tensionerThumbs down
Posted 21st Jun 2013 at 06:19
rich306
I was always taught the same as with a Cambelt, if you twist it and its goes more than 90degrees (too loose) and if you can't twist it then its too tight.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 21st Jun 2013 at 06:52
Yep, should be able to twist it around 75 degrees on it's longest run. Yes
Posted 21st Jun 2013 at 07:22
mattgti6phase2
Thanks guys. Well it's pretty tight but there is no whirring from the alternator or the tensioner so I'm still not 100% sure.
I can't turn it 90 degrees on its longest run either I'd say it wasn't much more than 75 if that Dunno
5 x a 306 owner!
Posted 21st Jun 2013 at 09:28
LOL I bet everyone with a rallye setup now runs out to check they can twist the Aux belt 75 Degrees
Posted 21st Jun 2013 at 09:34
Matt_rallye
Haha everytime I read it I go check lol
Posted 21st Jun 2013 at 14:22
mattgti6phase2
So just to add to this I've tightened it further and it still f**king whistles but as before only for 5-10 mind max.
Any other suggestions?
5 x a 306 owner!
Posted 15th Jul 2013 at 19:56
7057sam
I've just supercharged and using the gti aux getting a whistling aswell I am going to replace belt though.
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 15th Jul 2013 at 20:02
mattgti6phase2
The strange thing is my aux belt is OE and only 4k old. Maybe I could pass the noise off as it being charged Dunno LOL
5 x a 306 owner!
Posted 15th Jul 2013 at 21:02
jimmyrallye
Could be aux belt tensioner bout to pop had same thing on my 6 changed pulley job wos a gooden
Posted 15th Jul 2013 at 21:43
It will most likely be a pulley bearing Matt. Yes
Posted 15th Jul 2013 at 22:51
mattgti6phase2
It's a brand new tensioner fitted by CG. It's confusing the s**t out of me! I WANT TO SET FIRE TO IT!!!!
5 x a 306 owner!
Posted 16th Jul 2013 at 00:05
7057sam
Mine also brand new aux tensioner.
Rallye dead Sad
Posted 17th Jul 2013 at 23:09
ryangti6
I would of tried loosening it not tighten, whistling is usually too tight where as you get more of a squeel if loose.
By what you said above of struggling to get past 75 ish that sounds too tight in the first place.
Ryan
Posted 17th Jul 2013 at 23:17
swiftyboi006
Im voting bearing, if it does it when cold but not when hot then that to me is a bearing. Hsd this on my p1
Black p3 Love
Posted 17th Jul 2013 at 23:23
mattgti6phase2
Which bearing would this be? The guide bearing? As the actual tensioner is new.
5 x a 306 owner!
Posted 18th Jul 2013 at 00:20
swiftyboi006
Have u put a bit of chalk on the belt yet?
Black p3 Love
Posted 18th Jul 2013 at 07:02
You have a tensioner and an idler. I'm voting the idler. Yes
Posted 18th Jul 2013 at 08:08
swiftyboi006
Matt where abouts are you? If your near maidenhead at any point then pop over.
Black p3 Love
Posted 18th Jul 2013 at 09:57
  • Posted 18th Jul 2013 at 10:38
    mattgti6phase2
    Thanks stan. Easy to replace? Are they expensive?
    I'm only in aylesbury bud which isn't far from Wycombe. Just wanna sort it as its ebaressing, need the cambelt replacing again to its done 4.5k now and i still suspect its too tight from the whirring I get from it. Not major so it's not massively too tight but too tight none the less.
    5 x a 306 owner!
    Posted 19th Jul 2013 at 01:25
    They're not too expensive Matt. If you want, I'm only near Bedford myself I can change it for you and do a cambelt at the same time if you need to get it done.
    Posted 19th Jul 2013 at 08:07
    mattgti6phase2
    That sounds good Stan. It's literally just the cambelt as the water pump and tensioner has only done 4k so I will just deduct 4k off off the life off of the new belt to be safe.
    I will get a price for the aux guide pulley from pug today. I didn't no you were blessed with cambelt changing skills.
    5 x a 306 owner!
    Posted 19th Jul 2013 at 09:14
    Pages (3): [1] 2 3
