Author Subject: RX-8 Renesis Rotary engine, fully rebuilt, 6 port version.
As above, engine has done zero miles since the rebuild, it's the 6 port high power version, was rebuilt by WGT Developments in Cheshire using Atkins seals, etc.
It's been stored indoors in the dry since the rebuild with all the ports blocked and just a little oil run around the rotors to keep everything fresh.
I also have our old long-branch tubular exhaust manifold, couple of RX-8 flywheels, uprated starter motor, uprated D585 coils/Magnecor leads/loom adapters, and other parts I may let go with it to make it an easier install if someone wants to make a rotary powered 306...
I also have a 36-1 trigger wheel setup if anyone wants to use a standalone ECU on it - and if you use DTA, a full engine map - which it made almost 220bhp at the wheels on the last time it was dyno'd.
Also have an adapted VW clutch/flywheel/pressure plate setup which will bolt straight on for use with the old VW transaxles, or adaptors to fit a UN1/UN5 transaxle, if you fancy rear wheel drive.
Failing that, I might be talked into mating it up to a spare S16 gearbox I have, for a serious buyer. Wink
£1500 ono
Posted 21st Jun 2013 at 00:17
Stick it in your 306
Thumbs up
Posted 21st Jun 2013 at 07:41
Need the money, run out of cash to finish the buggy with Sad
Posted 21st Jun 2013 at 13:21
allanallen
Get it on eBay Phil, you'll soon shift it at that kind of money
Facebook
Posted 21st Jun 2013 at 18:27
vts_tibi
how much for the coils/leads adaptors alone? Smile
VTS
best 60' : 2.272
Team Trackday™
Posted 21st Jun 2013 at 19:30
Yeah, probably, just thought if someone was wanting to build something mad they might take all the other custom s**t we have for it off my hands at the same time LOL
Posted 21st Jun 2013 at 19:49
£200 sound good to you? Cheaper than 4 new OEM coils LOL
Posted 21st Jun 2013 at 19:52
