Author Subject: Tie rod end put my mind at ease or advice appreciated
Pug bazza
Right lads, I'm putting new track rod end in this week, and whilst looking at the old one I was twisting the track rod (long bit that the track rod end attached to) I did move it back to where I thought I was,and whilst still driving it with the old track rod end in,still feels the same, my question is that would me twisting it made difference cause I really don't want problems from it, thanks guys and this forums on suspention has helped me get Idea how I will be putting it in this week I Am only putting in the track rod end, not the track rod itself thanks guys and advice is appriciated
Posted 17th Jun 2013 at 20:28
No it won't have hurt or done anything, it's designed to move, it's like a ball in knuckle thing inside
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 17th Jun 2013 at 20:34
Twist it as much as you like!!!Big grin
Won't change anythingThumbs up
For the cost of £15 odd I'd get it aligned after.
Posted 17th Jun 2013 at 20:35
Yes
Posted 17th Jun 2013 at 20:50
Pug bazza
Thank fellas, would sleep better tonight, guys do you mean tracking when you say get it aligned cheers fellas, should I replace both or doesn't it matter, as long as I replace the knackerd one and get it tracked should be fine, this puggy pug pug has driven me mad, since I had it I spend more than I got it for but it's my puggy pug pug Yes Thumbs up
Posted 17th Jun 2013 at 21:14
footah212
Might aswell replace them both , then get the tracking done
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 17th Jun 2013 at 22:45
Pug bazza
Is it nessary to do both, or would I still be ok just to do the knackerd one and do the tracking cheers guys
Posted 17th Jun 2013 at 23:15
Pug bazza
So lads, is tracking or alinement, the same thing and which will I need after I do I have done my track rod end, just confused as, looking on Internet, and it tells me they different, cheers guys
Posted 18th Jun 2013 at 06:07
It's the same thing mate,
Although tracking a modern vehicle with 4 wheel adjustability is generally called allignment.
Posted 18th Jun 2013 at 08:24
Well for another track rod end at £5 would it not be worth doing both and having it tracked once and be done with it?
  • Posted 18th Jun 2013 at 08:42
    Puggie
    What dan said
    I think its something stupid like £ 31.60 for both inner tie rods and track rod ends
    Posted 18th Jun 2013 at 08:59
    Pug bazza
    That ok, il get the other one ordered and then of to tracking thanks guys
    Posted 18th Jun 2013 at 09:20
    Pug bazza
    Anyone know someone to do tracking, rang up few and they charging 45-50, I'm in Buckinghamshire so someone local would be good cheers
    Posted 18th Jun 2013 at 09:36
    gman
    Eurocar parts or GSF are likely to be cheaper, although that was about the price I paid for them on my 205.
    1992 Onyx Black 205 GTI-6
    2005 Honda S2000 (Sold)
    2002 Audi S3 (Sold)
    2005 Clio 182 Trophy (sold)
    Posted 18th Jun 2013 at 09:38
    Did you tell them it's a 306?
    Also tell them both track rod ends are new, was copper slipped before fit ment and will be free and easy to adjust.
    Posted 18th Jun 2013 at 09:42
    Pug bazza
    Gman, I mean like getting the car tracking done, like 4 wheel alignment, I rang up STS tyre pros, and the guy said £44.95 and any adjustment at rear will be extra £20 per adjustment, I also rang up BLACKBOOTS and they said £40 + vat so it comes to £48? Told him its 306 and he's like it's normally just front that need doing, is this pricing right cause I'm sure should be like half what they told me cheers guys and if you lot know someone close to Buckinghamshire or Hemel Hempstead, way give me a shout
    Posted 18th Jun 2013 at 09:46
    There is no adjustment at the rear.
    Posted 18th Jun 2013 at 09:47
    Pug bazza
    Cheers buzz, I will call them again, telling them that they are new track rod ends, hope they do better than what they said, but is it good to get it done or would I be ok, cause I have experienced vibration like up steering at like 60mph, so would this been down to the track rod end and tracking, cheers guys you lots really are helpful my first car and first 306 you lot are like god sends cheers again appriciated all advice Thumbs up
    Posted 18th Jun 2013 at 09:53
    Get it done mate, chances are its out!
    Posted 18th Jun 2013 at 10:26
    Pug bazza
    Will do buzz thanks mate, by the way lads are FIRST LINE parts good quality
    Posted 18th Jun 2013 at 10:27
    No they will last a year at best before the rubber boots split and the ball joints wear out. Better off with Lemforder or Delphi or TRW. Don't go for Q-drive from euros either their not worth a w**k.
    Posted 18th Jun 2013 at 10:31
    Pug bazza
    Ok, il get the TRW from gsf they like 11.00 but once they one peace of mind cheers guys off to the day job now so il get I'm sorted, thanks for all your help guys approximate it
    Posted 18th Jun 2013 at 10:48
    LOL
    Posted 18th Jun 2013 at 11:27
    jord294
    Lend order Thumbs up
    Posted 18th Jun 2013 at 11:30
