Author Subject: anti roll bar pugeot 306 gti 6
prparke
What size is a standard 306 gti 6 rear anti roll bar?
Posted 1st Jun 2013 at 10:06
24mm.
Posted 1st Jun 2013 at 10:20
prparke
stan_306gti6 wrote:
24mm.
Do you where you can buy a bigger anti roll bar from for the rear
Posted 1st Jun 2013 at 11:12
atterz
Spoox do them, also, talk to Chris Harris on here as he arranged a group buy, may be able to pass on the company details so you can order a seperate one.
owain wrote:
Posted 1st Jun 2013 at 11:36
Ash arranged a group buy years ago too, he made some 30mm ones. I have one of them in my rear beam and it works a treat. Thumbs up
Posted 1st Jun 2013 at 14:06
miles
Most come from here these days, http://www.torsionperformance.com/
www.pugracing.com
Posted 1st Jun 2013 at 20:49
30mm ARB ...Miles is Spot on ...2-3 days to make & £140 inc Vat ....plus £20 carriage ...they only take Bank transfer though !!
Problem is ....this has been said to me ...what material ?.....what Heat treatment ?.....how has the heat treatment been done ...etc etc
The people ^^^^^^ above so say make them for ( Pug 1 OFF )
Posted 4th Sep 2015 at 08:16
Well Finally got the 30mm ARB fitted Thumbs up
No bull guys it's enabled me tonight with my Plate diff to power round corners with no body roll
I was have quite a bit of body roll last week with stnd 24mm ... in the dry !!!
Yes it feels 100% more planted and easier out of the fast corners also ...
My Axle was refurbed by Andy /Jord294 on here 18months ago so no machining needed went straight in there 40min job Thumbs up
All I can say is the Axle still looks like new & having the Arms powder coated & new ABS sensors fitted really did pay off ...if you want a top quality Axle for your 306 -----JORD294 is the best Big grin
Lock tight used again & two new 8mm 12.9 Ht bolts used to screw through end caps into new 30mm ARB ...
I use my car on the road as well & it feels much much better ...a great £160.00 spent
Can't wait for Combe next Sat Forge Action Day here I come LOL
Posted 6th Sep 2015 at 01:53
jord294
Hope you haven't tightened the caps tight onto the arb bar??
There needs to be a small gap
Posted 5th Sep 2015 at 21:38
Left a 1mm gap each side Thumbs up
Used thin 1mm washers each side behind plate ....then tightened up bolts with lock tight on & then 8mm HT bolt through cap with Locktight on & then removed washers both sides ....perfect 1mm end float each side Thumbs up
Thanks for all your help Jord294/ Andy you know your Axle s**t LOL
Posted 6th Sep 2015 at 12:36
demondriverdan
Glad to hear the 30mm made a difference. Think I'll be doing the same on the race car at some point.
Rallye Race Car
Posted 6th Sep 2015 at 09:59
Dan the 30mm ARB & Bilstein group A rear dampers made the car go from good at Combe to great & was even fun on the wet Combe laps.
It was more sensitive but you could tell when it was just about to let go ...
Even passed my old m8 Pebbles sideways controlled & flat out on one lap ...epic
Posted 21st Sep 2015 at 20:17
