displaying posts 1 to 25 of 30
Author Subject: Noise from base of gearstick
gilesy
I have a rattling noise, can't immediately see what the problem is. Sounds like a plastic type noise, doesn't sound like metal on metal. Where and what should I be looking for?
Thanks in advance forum friends
Posted 31st May 2013 at 08:37
Niall
Heat shield that covers the base of the gear stick. I snapped a stud on mine a few weeks back and now it sounds exactly like this!
Posted 31st May 2013 at 08:59
Does the gearstick feel as normal, or loose etc?
Lift the gaitor up and have a look at base is prob easiest place to startThumbs up
But it's prob one of your exhaust heat sheilds imoWink there are two which overlap above the cat protecting the base of gearstickSmile
Posted 31st May 2013 at 09:02
had the same thing on my china 6, was heatshield, could only feel it coming off a certain sliproad banking to the left and it was very annoying
Posted 31st May 2013 at 09:08
Niall
Rikky did you just get rid of the heat shield? It's obviously there for a reason but want to know if you had any bad effects with out it
Posted 31st May 2013 at 09:13
Another vote for the heatshield Carl, start looking underneath first. I can't imagine you're going to find anything wrong inside the car unless the gear stick feels different from normal in any way.
Posted 31st May 2013 at 09:39
I had this.
Was a large moth.
  • Posted 31st May 2013 at 09:43
    i just took heatshields off underneath and put them back on after having a look behind, that sorted it. i broke the car up for spares shortly afterwards
    Posted 31st May 2013 at 10:10
    gilesy
    It's def gear stick related, if I put my hand on it whilst its making the racket it goes away. And it's a constant noise that gets louder with speed.
    I know what the heat shield sounds like, I have that noise too LOL
    Posted 31st May 2013 at 14:22
    Take the gearstick out and look for signs of wear and contact.
    If that doesn't reveal anything obvious, break it for spares.
  • Posted 31st May 2013 at 15:01
    Then I would imagine the actual gear stick base is worn or loose then if you can make the noise go away just by adding pressure on the stick itself.
    Posted 31st May 2013 at 16:07
    May just be loose fixings to the stick. Get dismantling and update us with pictures ASAP.
  • Posted 31st May 2013 at 16:28
    Could be gear rods, and the sound is travelling down selectorThumbs up
    Posted 31st May 2013 at 17:50
    gilesy
    I might get under it again over the weekend. c**t
    Posted 31st May 2013 at 18:44
    everytime i read s**t like this and then drive my car im SURE i have the same thing as what i just read.
    Posted 31st May 2013 at 21:04
    footah212
    I have same noise as this. It also goes away when a wee bit of pressure is applied to the stick. I initially thought it was the miles linkages but I think it's actually a bush thing underneath. Can't hear it as much since the car got stripped. All the other racket drowns it out now
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 1st Jun 2013 at 13:21
    Shall we document that as the appropriate fix then? Laugh
    Posted 1st Jun 2013 at 14:30
    Well I bet you would Razz
    Posted 1st Jun 2013 at 21:37
    davedgti6
    Its the plastic ball around the gearstick, take the gearstick out, grease the ball and the noise will go away,
    I.E. grease your ball Thumbs up
    Posted 1st Jun 2013 at 22:35
    beez_neez_gt
    That shouldnt be hard to do, he has enough boyfriends to help him out Ninja
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 1st Jun 2013 at 23:45
    footah212
    Ear plugs ftwThumbs up
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 3rd Jun 2013 at 10:35
  • Posted 3rd Jun 2013 at 11:16
    gilesy
    Oh hey dan. Can I do this job from inside the car?
    Posted 4th Jun 2013 at 00:19
    I believe you can. Yes
    Posted 5th Jun 2013 at 08:53
    iplay
    I would advise against this because you will end up with a floppy gearstick. The grease peugeot use is quite specialised for this and gives a certain resistance.
    Probably not related but useful info ... The gearstick connects into a long gear lever with a hole in it for the rubber gear selector lever to engage. Inside these holes should be a rubber sleeve. Over time this wears out and I suspect if anyone can not get 2nd gear easily this is the cause. Problem is peugeot do not make this part anymore but there is a small company that makes to order.
    I would recommend greasing just the base pivot ... sometimes the spring washers partly break and they can cause a noise. Or one of the nylon bushes in the geat lever base could be broken.
    Posted 10th Jun 2013 at 14:56
