displaying posts 26 to 30 of 30
Pages (2): 1 [2]
Author Subject: Noise from base of gearstick
The bushes are brass in the bottom, not nylon. Thumbs up
Where's the rubber selector your on about?Dunno
Posted 10th Jun 2013 at 18:21
mocinim
So in reflection should I grease my ball or change my brass have same issue also gear linkage rod sounds clunky any idea suggestions on which parts to change repair grease etc 😆
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 7th May 2015 at 16:46
mocinim
So to cap i have short shift linkages these rattle far to much the rattle sounds like it came from the gear stick but was the cup n nuckles so greased them got a small syringe and injected the cup n knuckle that sorted one rattle the other rattle was the brass bushes at the base replaced these with new bolt also second rattle fixed still had a faint rattle very quiet it was but still annoying so i pulled out the stick took the rubber covers off and used white lithium grease on the pivot nylon ball now its lovely no rattles niggles or other
So in the end i needed to grease my ball change the bush and lube my links and now shes a hole new land feels younger and fresher Smile
Posted 23rd Sep 2015 at 09:31
psjunkie
Got the same rattles as you I'll give these a go!
1997 P1 Gti 6 Charged
Posted 23rd Sep 2015 at 13:00
mocinim
Going to try some silicone on the knuckles if the grease fall out to quick just a little then press the cup on see if that holds
Posted 23rd Sep 2015 at 14:14
Pages (2): 1 [2]
