Author Subject: Further to roller thread
chunder27
Right then
Had a bit of a meddle earlier and found one or two things out! Need a new rad cap as the stem from the cap into the pressure plate is broken! And I need some tools!
Tried to change the filter but coz the car is so low I couldn't get under it and I don't have a jack! And I couldn't undo the damn plug coil bits as I only have a handle bit holder not a socket set one! Doh
Anyway, I do remember someone on the roller thread mentioning throttle cable tension, check this clip out and see what you think?
Ignore the metally noise of the motor, its coz I was holding the camera too close, car doesn't tap at all as others mentioned. Actually I don't think I can send this, its a 20 meg file! Cant seem to compress so have included a pic
In fact f**k this, it wont let me upload anything larger than 256k, how bloody stupid!
Posted 26th May 2013 at 16:48
chunder27
Cant find a way to edit pics on stupid crappy phone, so not sure how I can send pics to here
To be honest if I am paying a fiver for a forum this is p**s poor guys, its kind of what this place is suuposed to be for isn't it!
Very rubbish
Posted 26th May 2013 at 16:53
stu
Best way to post pictures/videos is to use a Photobucket account or similar.
Just copy and past the [IMG] tags into your posts.
Posted 26th May 2013 at 16:58
chunder27
This one is the dyno sheet
http://www.flickr.com/photos/11026348@N03/8843054384/
Posted 26th May 2013 at 17:22
chunder27
This is a clip of the throttle cable maybe being loose as people mentioned in the original roller thread
Cant get this clip to upload sorry, flick just is s**te!
there is a pic instead, this is obviously with no throttle being applied, kind of like slack!
http://www.flickr.com/photos/11026348@N03/8842428645/in/photostream/
I will try the clip but I don't think it works
http://www.flickr.com/photos/11026348@N03/8842489801/in/photostream/
Posted 26th May 2013 at 17:25
That clip shows up as 'Page not found' on Flick. Yes
Posted 26th May 2013 at 17:29
chunder27
I thought so stan, dinnae worry flickr is not liking vid clips
Basically the throttle cable has some play in it, not sure if I can tell it makes a difference, but it might explain a few things, or it might be nothing!
We'll see
Posted 26th May 2013 at 18:57
get somebody to press the pedal to the floor (with engine off LOL) while u see if there's any more to go at the butterfly(where the cable meets to throttle body)
If there is then the cable needs tightening and if not then the cables fine.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th May 2013 at 18:59
chunder27
Lol, that's easy if you know anyone local!
Sadly I dont
Posted 26th May 2013 at 20:08
The alternative for loners - jam a bit of wood or similar in the footwell to fully depress the pedal.
  • Posted 26th May 2013 at 20:51
    ryangti6
    If you press the pedal quickly and firmly you'll hear it hit the stop even without the bonnet up, if you don't hear a tap noise from under the bonnet it isn't opening all the way.
    All you do to adjust it is take the metal clip off, hold the plastic piece that has grooves cut in it out so the cable is tight and refit the clip, literally a 2 second job and you'll know for definite that is then not the problem.
    Ryan
    Posted 26th May 2013 at 21:09
    LOL
    Posted 26th May 2013 at 21:22
    chunder27
    I don't have a bit of wood!
    Posted 26th May 2013 at 23:34
    atterz
    Any heavy object that can hold it open then?
    owain wrote:
    Posted 26th May 2013 at 23:39
    No friends, no wood, dicky engine....
    ...just stand next to the accelerator pedal and hope some of the depression rubs off.
    Posted 26th May 2013 at 23:41
    chunder27
    Well I do have friends, but its a bank holiday and most of them are tied to children and boring days out!
    Posted 27th May 2013 at 08:25
    Stuwee
    Drop me a pm, I'm in stevenage a lot. I basically live there LOL
    I can pop over and have a nose.
    Im in Chells....
    Ph1 Cossack 6
    Posted 27th May 2013 at 08:40
    Your seriously telling me you have no contact with anyone ever that could push a pedal for you for 10 seconds?
    Posted 27th May 2013 at 09:50
    chunder27
    Well of course I do, just not this weekend! lol
    Blimey
    Posted 27th May 2013 at 17:08
