Any suggestions as to how i can fix it? Going to get in touch with anyone that deals with KW to see if it can be repaired
Not a great pic but you get the idea
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
What is that wet stuff on the hub? From inside the damper or just some WD40 or something?Depends whether it can be re-welded without overheating hte damper internals seals etc. I'd see if you can deal with KW directly. ________________________________________ Cherry Rallye SOLD |
JWP EFi
its WD40 mate, ive put a straight edge on the damper and it is still straight, no leaks to speak of. I will make some enquiries on monday to see what can be done. Ive got a few contacts who could weld it for me but as you say the heat may just cook the seals or even explode |
Get it welded back on. It's far enough away not to damage any rubbers if you make sure the rod is fully extended. Chuck a wet towel round it top and bottom to keep the heat from travelling if you're worried.Pop it in a box and send it here if you haven't got someone up there you want to do the job. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Better off just taking the insert out and draining the casing, there's oil behind it there.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
phillipm wrote: Better off just taking the insert out and draining the casing, there's oil behind it there. I know, but two quick tacks wont do the oil any harm. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Probably, but it doesn't take much to block the valving in those, the ports are tiny.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Looks like a strip down is the only safe answer, but if they were mine I'd chance it.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
It's one of those where 99% of times you'll be fine.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
JWP EFi
daveyboy wrote: phillipm wrote: Better off just taking the insert out and draining the casing, there's oil behind it there. I know, but two quick tacks wont do the oil any harm. So do we agree that this is doable? really dont want to have to buy a replacement damper |
JWP EFi
also, without having them in front of me right now, can they be stripped down? ie by myself? |
Big nut at the top, undo that, drain the oil out of the casing, recover the o-rings and lift the internal tube/shaft out in one piece (and make sure you keep it spotless, especially on the bottom), viola, empty casing.edit: ![]() ![]() Keep this bit as close to surgically spotless as you can, dirt in there can jam a shim open = no damping. ![]() You need to measure exactly how much oil comes out/where it was up to in the casing, the correct oil level is vital. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
JWP EFi
what and where do i get buy oil from?Very helpful info btw. |
Rock Oil's 7.5wt or RSF 5w are relatively close in viscosity IIRC. Or save what you drain out and put it back in, you'll only loose a couple of ml in the container.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
Suspension oil shop ![]() Not sure for cars. But for bikes we use motorbike shops as its the same stuff in the same weights. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
cheers boys. If i get spare hour or 2 tomorrow i will take off dampers and see if i think i'm capable of stripping them down so i can have lug welded back on. |
jamiek_uk2000
The only thing with changing the oil in one, is that I would personally change it in the pair. New oil has a much better viscosity then old. If you use the old oil and put it back in then you'll be fine ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
JWP EFi
i would do both as a matter of course |
I would man up and get the welder out to save you hours of hassle and potentially incorrect damping afterwards ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
