Author Subject: Cavity waxing sills
mik
I'm about to cavity wax inside my sills. At the rear there seems to be some sound deadening in there. I'm not sure how much there is - is it necessary to remove the sound deadening to get good coverage with the wax on the inside of the sill? Or can I just shoot it in there with the 60cm lance and hope for the best. Do I need to remove the rear interior side panels and remove the sound deadening while I wax it?
Anyone done this? Any tips appreciated.
Cherry Rallye SOLD
Posted 4th May 2013 at 00:23
Just take it out, it'll only soak into the sound deadening anyway, and you might spray a load on the interior panel - get it in the wrong place and it'll soak through.
Posted 4th May 2013 at 00:27
jamiek_uk2000
Well there is certainly some sound deadening in there, when I was grinding out the rust on mine, I nearly set the car on fire after the sparks hit it!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th May 2013 at 03:58
As above,pull the rear trims off and remove the sound deadeningThumbs up
Posted 4th May 2013 at 11:11
mik
OK thanks guys, sounds like a plan.
Cherry Rallye SOLD
Posted 4th May 2013 at 11:24
