Author Subject: brake line
chris1987
Hi guys dos any one know where i can get good quality brakes line from as my o/s rear line has gone any input would be appreciated.
Posted 28th Apr 2013 at 08:46
Dunno peugeot, motorfactors, citroen...
Posted 28th Apr 2013 at 09:02
jord294
I can make one up for you, unless you prefer to pay main dealer
Posted 28th Apr 2013 at 09:19
chris1987
That sounds good how much do you reckon .im after the pipe work from the calliper o/s rear to where it bolts behind the fuel tank i hope this makes sense.Thumbs up
Posted 28th Apr 2013 at 10:38
jord294
You mean, to the bottom of the shock absorber?
Posted 28th Apr 2013 at 11:02
Rich E Forum Admin
The pipes from the rear beam are still available from Peugeot pre-moulded to the correct shape for £15 per side.
Posted 28th Apr 2013 at 11:07
chris1987
I will upload pic of where im talking about .
Posted 28th Apr 2013 at 16:56
chris1987
Posted 28th Apr 2013 at 18:40
jord294
i'm afraid it's not the clearest picture, and to do a proper job, it means fuel tank off iirc. as it feeds up and along side
maindealer price for that pipe is approx £30. it's quite lengthy aswell.
Posted 28th Apr 2013 at 19:13
chris1987
Just looking for the best price
Posted 28th Apr 2013 at 19:20
jord294
According to servicebox, the length of pipe is about 3000mm long. So it's not a 5 minute job.
Posted 28th Apr 2013 at 21:16
Rich E Forum Admin
Are you sure you need everything from there to the caliper?
On a phase 2 that would be 3 (possibly 4) metal lines and a flexi hose.
The reason they are split up into smaller lengths is so that you don't have to replace the whole lot if one pipe or hose fails.
Posted 28th Apr 2013 at 21:33
chris1987
No i don't need that much the pipe i need go's. From the o/s rear calliper then along the bottom of the boot to the opposite side then tucks around for about 20 cm where its joined with a bolt . Its about a meter .i will take some better pics and post .thanks for your help guys
Posted 29th Apr 2013 at 08:49
jord294
The pipe directly from the rear caliper is just over 700mm long, and from the caliper, joins to a flexi, then to another short piece, which goes into the brake compensator. Or has someone done away with the compensator?
Posted 29th Apr 2013 at 09:19
chris1987
from the calliper
ive had to but some hight presser pipe over the leaks
Posted 29th Apr 2013 at 09:29
WHAT THE f**kIGN f**k?!
am I right in saying I see some rubber pipe jubilee clipped on there?
Posted 29th Apr 2013 at 09:47
chris1987
Something like that its high presser fuel rail pipe with fuel filter clips its over the cracked pipe that's leaking . Tho im not diving it like it that would be mad .
Posted 29th Apr 2013 at 09:57
heliosphan
This is by far and away the best bodge I've ever seen! Laugh my ass off
Unbelievably, properly dangerous.
Posted 30th Apr 2013 at 12:13
jamiek_uk2000
There are no issues with this braking system and I can see it passing the MOT
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 30th Apr 2013 at 12:18
chris1987
Had to stop it leaking everywhere as i didn't want a fine from the council. Thats why im trying to get a replacement pipe its to dangerous to drive and i will need the car soon for work.
Posted 30th Apr 2013 at 13:30
Laugh
Posted 30th Apr 2013 at 14:21
get it towed to the local garage Thumbs up.
Posted 30th Apr 2013 at 14:34
chris1987
Cars book in to hawkins motors for £120
Posted 30th Apr 2013 at 15:28
Laugh my ass off
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 30th Apr 2013 at 21:42
How much?Shock
About 30 mins labour and a couple of £££ for the pipe and fittings would cover itThumbs up
Posted 30th Apr 2013 at 21:58
