Author Subject: c5 'steel' wheels and tyres
Kengti6
For sale is a set of four c5 'steel' wheels and tyres, in good condition without any damage/curbing. The wheels have been painted silver and will come with a set of tapered wheel nuts and four locking wheel nuts. The rear tyres are eagle f1's and are 195/50/15 and the fronts are toyo proxies and are 185/55/15 (originally for my 205). All tyres have plenty of tread left.
£150 collected from york area or i can pack them for you to organise your own courier.
Posted 7th Apr 2013 at 20:33
Which ones are they and are they the correct floating washer bolts?
Thanks
Posted 7th Apr 2013 at 20:52
beez_neez_gt
You dont need washer bolts as you can use standard bolts with added washers as they are only there for protection when doing them up.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 7th Apr 2013 at 22:27
Explain? The correct ones from Peugeot have the floating angled washer. Are you saying use a standard bolt?
Posted 7th Apr 2013 at 22:47
spiky
you cant use flat bolts/nuts
but can use washer or washerless tapered bolts/nuts
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 7th Apr 2013 at 22:58
beez_neez_gt
Yes use tapered bolts with a seperate same 45 d iirc tapered washer, thats all those oe ones are but attatched together. So when people dont get the oe bolts its best not to go citroen and spend loads on them when they are cheper from rally design for instance, getting the above type not oe ones.
I meant standard as in not attatched to a washer, but being tapered the same as oe bolts.
Pug fee`ver,
Posted 8th Apr 2013 at 00:07
Kengti6
Thanks
Hi, the standard wheel nuts that come with them are the 'floating' type but the locking wheel nuts are just standard tapered wheel nuts.
And the numbers on the wheels are 6j15h2 et18 ps815011 n21 2n25 060310018, if that helps?
Posted 8th Apr 2013 at 13:24
braymond
Thanks
I can confirm this is the correct code for the light magnesium alloy ones, in case anyone was looking for confirmation.
Rallye-R
Nurburgring article
Posted 8th Apr 2013 at 15:30
they aren't mag LOL
Posted 8th Apr 2013 at 15:56
braymond
they aren't mag LOL
As I understand it, its an alloy that contains some magnesium. Hence "magnesium alloy". Perhaps you know better, so by all means eductate me.
The point is, they're the light ones.
Rallye-R
Nurburgring article
Posted 8th Apr 2013 at 16:20
Kengti6
braymond wrote:
they aren't mag LOL
Cheers Thumbs up
Posted 8th Apr 2013 at 16:30
Magnesium alloy would be mainly magnesium + alloying components, C5's are aluminium alloy, that probably contains traces of mag. Not the same thing.
Posted 8th Apr 2013 at 17:14
