Author Subject: 205/309 ECU stuff +more
24seven
Photos of all items can be found here!
Everything has been dry stored in a heated room (my bedroom!) for the last 3 years. If anyone wants to collect I'm located in central Swansea, or I will be travelling to/from the North Wales coast over Easter so can drop things off on the way if need be.
Motronic 8v ECU from a 1990 309 GTi 1900 with a catalyst: £30 posted
Motronic 16v (2 row) ECU from a 1900 D6C Mi16: SOLD
Jetronic 8v ECU from a 1990 205 GTi 1600: £15 posted
Multiplex ECU from a 2001 Xsara VTS XU10J4RS: (unlocked by unplugging, assuming that works on multiplexed ECUs) - Perfect if you want a spare to dissect as part of a larger plan to retrofit certain features that multiplexed ECU's control: SOLD
Motronic 8v Air Flow Meter from a 1990 309 GTi 1900 with a catalyst: Still has the tamper-proof cap fitted. Less than 80k miles on it £40 posted
Motronic 8v Engine Loom from a 1990 309 GTi 1900 with a catalyst. As pictured one of the under-dash plugs has been disassembled. I would reassemble it before selling, but I can't remember which order the wires should be so as to match the other half of the plug. In any case these are known to be arranged differently on some cars so you would only have to match it to your own dashboard plugs to use it. £50 posted
2 x Inlet Manifold mounted coils: Both were last fitted to the 205 Mi16 I used to own a couple of years ago and were bought to help diagnose a misfire, which turned out not to be the coil. £15 posted
Bosch Ignition Amp from a 1990 309 GTi 1900: Same 309 as everything else, worked fine when last used. £10 posted
Wing mounted coil from a 1990 309 GTi 1900 with Motronic management: Was working so strongly when last used that even with the electrode almost completely missing on one spark plug the engine didn't have a misfire at all! £15 posted
Mi16 1900 D6C injectors (set of 4): Working when last used - removed to fit a reconditioned set in my old 205. SOLD
Mi16 1900 D6C Idle Control Valve: Working when last used - removed because it's painted red and looked silly so I fitted a spare I had lying around. SOLD
Unknown starter motor: Came as part of an Mi16 conversion "package" bought on here as a working item, however I've never used or tested it. £20 posted
Unknown alternator: Same story as the starter, unused or tested by myself. £20 posted
306 GTi6 XU10J4RS thermostat housing: Unknown condition thermostat, no sensors. £10 posted
Blaupunkt Melbourne SQR 39 cassette player: Worked fine when last used - was fitted to my 309 GTi when I bought it. I'm unsure as to it is the factory fitted unit or aftermarket. Perfect if you want to retain a standard or period-style feel to your interior. £15 posted
Indicator stalk: Found in the boot of my 309 shortly after I bought it. Untested apart from the self-cancel mechanism which works as it should. £10 posted
If anyone is interested in the matching Motronic 8v Loom, ECU, Air Flow Meter, Ignition amp and one of the coil's as a complete set: £120 posted
Posted 25th Mar 2013 at 19:35
24seven
Xsara multiplex ECU and Motronic 16v ECU have both gone.
Posted 2nd Apr 2013 at 12:58
jord294
Mi16 1900 D6C injectors (set of 4): Working when last used - removed to fit a reconditioned set in my old 205. £20 posted
Mi16 1900 D6C Idle Control Valve: Working when last used - removed because it's painted red and looked silly so I fitted a spare I had lying around. £10 posted
will you take £25 and a cuppa when you're passing mate?
Posted 2nd Apr 2013 at 15:45
24seven
Sorry Andy, I've only just seen your reply, logging in from St Asaph. I'll do them for £25 posted together when I get back to Swansea if you'd like.
Posted 3rd Apr 2013 at 17:30
24seven
Bump
Posted 10th Apr 2013 at 22:49
beez_neez_gt
Any speedline 1.9 alloys?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 10th Apr 2013 at 23:08
jord294
Ok mate. Cheers
The unknown alternator? Does it have 5 grooves on the pulley?
Posted 11th Apr 2013 at 08:17
24seven
Sorry, only the things I've listed here, and a set of Xsara VTS wheels.
jord294 wrote:
Ok mate. Cheers
It's got 5 ridges and either 4 or 5 grooves, I'm not sure if the inner edge would be where a ridge in the belt would sit or not as it's not as clean as the rest of it. Have a look, see what you think. Smile
Do you still want the injectors and ICV?
Posted 11th Apr 2013 at 13:32
jord294
Can you put up larger pic of alternator please? As it may be the proper 405 mi16 type.
I'll have the idle valve and injectors
Posted 11th Apr 2013 at 14:14
24seven
Sorry, should have said that pic was a clickable thumbnail. On closer inspection this alternator is for a 4 ribbed belt so is meant for an 8v (nice one Baz LOL).
PM on it's way RE: injectors & ICV.
Posted 11th Apr 2013 at 19:47
24seven
Mi16 Injectors & ICV have gone.
Posted 14th Apr 2013 at 17:55
24seven
Bump.
Posted 20th May 2013 at 02:05
