| Author | Subject: Xsara 5 speed |
scottycollard
Junior User Location: Totnes Registered: 27 Sep 2010 Posts: 85 Status: Offline |
Just wanted to know would a be 3 5 speed fit straight in my 306 gti 6 or is there any modifications to make this fit ie clutch gear linkages shafts or speedo thanks |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
It fits, i'm running one on my Rallye.No special mods. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
scottycollard
Is it worth it in the end |
scottycollard wrote: Is it worth it in the end I would say not on a standard Gti6 eng Had one fitted in my 309 I converted to Gti6 eng,and once I drove a Gti6 with 6 speed I realised how much nicer/better geared they are Not a sniff I would ever go to a VTS box Why are you thinking of fitting one? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
To balance things out (for now, until the rest of the forum disagrees with me), I MUCH preferred the 5 speed VTS box in both the Xsara VTS as standard and when I had the RFS engine in my 309 GTi. These engines have a fairly broad power band and in a car that tops out at 140mph it really doesn't need 6 gears to keep the engine on song.Even out on a spirited drive the ratios are too close in my '6, so for the rest of the time when I'm driving normally they're incredibly annoying! I often find myself skipping gears just because it's easier than changing all the funking time! ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
stan_306gti6
I really can't see where you are coming from with this business of the gear ratios being "annoying". They are one of the *best* things about the car IMO. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
24seven
They're just too close and annoyingly so when the 5 speed box is spot on for this engine. It's a marketing gimmick, otherwise the Xsara would probably have the same gearbox as well. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
24seven wrote: They're just too close and annoyingly so when the 5 speed box is spot on for this engine. It's a marketing gimmick, otherwise the Xsara would probably have the same gearbox as well. The 5 speed is not perfect for this engine, the revs drop too far between shifts and takes the engine out of it's powerband. It's not awful but if you want to make rapid progress and aren't a lazy big girls blouse who doesn't want to shift so often then it's the 6 speed box that wins everytime. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
daveyboy wrote: 24seven wrote: They're just too close and annoyingly so when the 5 speed box is spot on for this engine. It's a marketing gimmick, otherwise the Xsara would probably have the same gearbox as well. The 5 speed is not perfect for this engine, the revs drop too far between shifts and takes the engine out of it's powerband. It's not awful but if you want to make rapid progress and aren't a lazy big girls blouse who doesn't want to shift so often then it's the 6 speed box that wins everytime. As above Just couldn't be arsed writing it all! ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
24seven
daveyboy wrote: 24seven wrote: They're just too close and annoyingly so when the 5 speed box is spot on for this engine. It's a marketing gimmick, otherwise the Xsara would probably have the same gearbox as well. The 5 speed is not perfect for this engine, the revs drop too far between shifts and takes the engine out of it's powerband. It's not awful but if you want to make rapid progress and aren't a lazy big girls blouse who doesn't want to shift so often then it's the 6 speed box that wins everytime. If you're dropping out of the out of the ideal range when you change gear with the 5 speed box, you're shifting too early. I promise you. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
stan_306gti6
Where's that popcorn smiley gone...![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Horses for courses Steven, but I think you're wrong.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
stan_306gti6
daveyboy wrote: Horses for courses Steven, but I think you're wrong. +1 on that opinion. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
24seven
Steven? ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Guy then, I've been mis reading your forum name for years ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
daveyboy wrote: Gay then, I've been mis reading your forum name for years ![]() EFA |
24seven
Someone else decided my name was Steven too. Soulman I think. I forget. ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
stan_306gti6
LOL @ Jim, what a plonker! ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
who's jim? ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
welshpug! wrote: who's jim? ![]() Daveyboy. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
I think you mean Dave ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
I think you'll find it's "Best Price Dave"Strange parents. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Get stuffed baldy.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
