Author Subject: a few bits n bobs
darzmat
an inlet manifold gasket preferably a ptfe one if theres any floating about.
o rings for the injectors where they go into the fuel rail.
the left hand breather pipe (on the top right of the inlet cam cover, as mine shattered when i pushed it on cos it was so cold). its just the bit about 3 inches long that i need.
passengers side hub/knuckle as my ball joint bit is ovaled.
and a drivers door wiring loom. im needing the car side of the multi plug and as much wiring as possible from the car side.
cheers
Posted 25th Feb 2013 at 21:57
darzmat
bump, added a few bits
Posted 26th Feb 2013 at 19:18
darzmat
also needing a vacuum pump in good condition as mine is fubared
Posted 26th Feb 2013 at 19:41
jmh306
I have a vacuum pump going. Can do for £15 posted.
FB: South Downs French Car Club
Diablo 6 2001 low boost
Diablo 6 2000 100% standard working air con
Vw Caddy tdi work van
Posted 26th Feb 2013 at 21:24
Can help with the vacuum pump, door loom harness and inner door loom.
  • Posted 26th Feb 2013 at 21:25
    darzmat
    thanks for the reply jmh306 but think im sorted for a vacuum pump now.
    still looking for
    Posted 26th Feb 2013 at 23:53
    davidmartin
    Ebay INLET-MANIFOLD-GASKET
    pet hate, the cat
    Posted 27th Feb 2013 at 23:22
    Can do the hub and dor loom £40 delivered
    Posted 5th Mar 2013 at 10:13
