Author Subject: suspension kit
dazzy6
lookin for advice on what suspension kit yo put on my rallye , had a quote off demon tweeks for weitec or ytec kit for around 400 pounds and would lower the car by 40 mm , would it be wise to lower by this amount if its only for fast road use ? or does anyone know of a better setup ?
darrenevans
bianca white rallye t706wox
Posted 16th Feb 2013 at 21:10
jord294
Search is your friend Yes
Don't bother with Tweeks recommendation!
Get yourself some eibachs for the front and lower the rear to suit.
Ideally, fit solid mounts to the rear aswell
Posted 16th Feb 2013 at 21:15
dazzy6
ok cheers mate so what shocks would u recomend ? jst renew the standard b4s? any ideas best place to source everything ?
darrenevans
Posted 16th Feb 2013 at 21:30
B12 kit Thumbs up
Posted 16th Feb 2013 at 21:59
jord294
Depends on your budget.
The cost of fitting eibachs to the front and lowering the rear is dirt cheap to do. But what condition is your axle in to start with?
Just under £1000 gets about the best set up there is for fast road. b8s, eibachs, roller bearing wishbones, b6 rear shocks, solid mounts, vts bars
Posted 16th Feb 2013 at 22:07
Just under £6000 gets about the best set up there is.
EFA
Razz
Posted 16th Feb 2013 at 23:02
Within reason Roll eyes
Posted 16th Feb 2013 at 23:06
I still wouldn't go solid rear mounts on the road.
Posted 17th Feb 2013 at 08:57
jamiek_uk2000
Jord trying to get some more work "What condition is your rear beam in"
If your going to use it every day don't use solid rear mounts and lower it as you will have no teeth left in your head. Depends on what compromise you want between performance/drivebility
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 17th Feb 2013 at 09:08
jord294
I know it sounds like that, but the slightest sign of seizing or camber makes a considerable amount of difference to the handling.
Dirt cheap set up I personally would just use new o/e mounts
Posted 17th Feb 2013 at 09:11
jamiek_uk2000
Every single 306 should have their rear beam rebuilt if you are thinking about any kind of performance out of them, they just don't like 15 years without being rebuilt! There is no point putting tidy shocks on something that is all over the shop.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 17th Feb 2013 at 09:14
All depends what you want really, Personally of you do this kind of level of work its becuase you want the best out of the car and plan on keeping it for a while.
So to me its always worth doing the beam too, these cars are slowly working into the "pretty f**king old" territory, they dont necessarily look it though.
Im a fine one to talk though as my suspension is shafted (mainly becuase i thought i had more time and was buying everything at once. If i could do it again it would be slightly more logic and likely id have had a fresh setup for a number of months now, but you live and learn.)
That kit sounds like cheap and nasty **** to me so id avoid.
Posted 17th Feb 2013 at 17:32
dazzy6
so i can fit the eibach springs to my standard shocks ? the shocks could do with replacing as its done a fair few miles where is the best place to source the standard shocks and what price ? sorry to keep goin on jst want her to be a proper rallye again
darrenevans
Posted 17th Feb 2013 at 18:55
jord294
Yes. The eibachs fit standard struts.
About £120 should get you a new pair delivered.
Personally I'd fit new genuine strut top kits. But they're about £65 a side inc rest cups
Posted 17th Feb 2013 at 19:05
