displaying posts 1 to 25 of 54
Pages (3): [1] 2 3
Author Subject: Cannot remove disc!!
jamiek_uk2000
I've been trying to remove the front disc from my car but with absolutely no success, the drivers side came off no problem at all. Undid the two grub screws and it fell onto the floor, the passenger side is having none of it, I've tried hitting it (quite hard) while spinning it to get the force all the way around, I've pumped it full of releasing agent for days and still nothing. I wasn't sure on giving it any heat because of the bearings in the hub, the only piece of advise I have heard is to pee on the hub as apparently this will break down the rust. I don't want to p**s on my car, especially since it is on the drive at the front of my house. Any ideas??
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Feb 2013 at 22:19
rich306
Just give it some heat buddy and whack the disc, the hub builds up a huge amount of heat anyway when running so it shouldn't make a difference.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 4th Feb 2013 at 22:21
Pee in the privacy of your house into a pop bottle then go outside and release onto the disc.
jamiek_uk2000
Is the p**s thing actually true then, I heard it off a guy on site today but didn't believe him. I always knew that the brakes got the temp but wasn't sure on the hub itself, should I be trying to heat it from the rear of the disk where the disc joins the hub?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Feb 2013 at 22:28
Get a lump hammer and hit it properly you big fvcking wet girls blouse
Yes
Hit from behind the disc HARD
Posted 4th Feb 2013 at 22:37
jamiek_uk2000
I was swinging like a monkey in a tree at it, it just didn't want to go. At one point I thought I was going to hit the car off the axle stands!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 4th Feb 2013 at 22:42
Hit it harder.
They come off easily with rounded off screws still holding them on, so not sure why you are still struggling.
Perhaps run the car on axle stands and step on the brakes. If that doesn't loosen it then affix a passenger airbag to the disk and attach a wire to the battery.
  • Posted 4th Feb 2013 at 22:47
    birk
    Man, do you even lift? Lol
    I forgot to take the grub screws out I've time and still managed to whack a disk off haha
    Dimma + Gt35 turbo = Ninja
    Solid rear beam mounts £130
    07889376885
    Dan
    Posted 4th Feb 2013 at 22:50
    jamiek_uk2000
    I've got no front end at all at the moment, so running it isn't an option. So basically I need to just keep hitting it, I'll chuck some heat on it first and if it doesn't come off I need to get someone with an actual pair of real arms, not these stringy things that hang out of my T-shirt to hit it for me?
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Feb 2013 at 22:51
    Posted 4th Feb 2013 at 22:53
    dendle89
    I've got some man tablets if you need them......Smile haha
    Team 6 Cylinders
    Posted 4th Feb 2013 at 22:54
    Please video you hitting it with commentary and we can advise if you are doing it right.
  • Posted 4th Feb 2013 at 22:54
    gilesy
    Have you taken the wheel off yet? LOL
    Maybe your bra is restricting your swing? Put your handbag down slacken off you're blouse slightly and just hit the f**king thing!
    I smacked off a 306 diesel disc with 2 seized rounded off grub screws the other day... Use a bigger hammer it'll get the job done Wink. Worst ones I used to do all the time working for mitsubishi were about 10 year old shogun ck ones with warped front discs. By the time I had finished hitting them the disc would split in 2 through the vented part all the way round and would often pretty much disintegrate by the time they came off.
    Posted 4th Feb 2013 at 23:02
    jamiek_uk2000
    Do you have to then?
    But seriously, I've changed enough discs and pads on cars to know what it should be like. Even ones that have been tough have come off much easier than this. I think I may put some copper grease between the hub and disc to stop this ever happening again. Or just don't leave it off the road for 18 months without a cover next tim No
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Feb 2013 at 23:04
    Big armzs
  • Posted 4th Feb 2013 at 23:06
    Video please.
  • Posted 4th Feb 2013 at 23:07
    binkagti
    14lbs sledge hammer and smack the fcuking thing, it will come off, at a rapid rate of knots lol
    TEAM Supercharged Rallye
    jamiek_uk2000
    I will be on the case tmrw straight after work. I shall update on the situation. This could either work, end up injuring myself almost fatally or I will be phoning Roland for the hub for the other side of the car LOL
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Feb 2013 at 23:09
    dangti6 wrote:
    Big armzs
    Armzs He's a bit of a distance away... Although he could probably blow from there and get the disc off.
    OP this isn't a bad dream you are having is it? Like when running but getting nowhere or naked.
    You're not using a toffee hammer are you?
    I jest yet I kept the one that came with a slab of toffee for Christmas. You just never know when you might need a small hammer. I thought it may be useful to knock the trailing arms off my beam.
  • Posted 4th Feb 2013 at 23:14
    jamiek_uk2000
    It could well be..... It may even turn into a nightmare if tomorrows little exercise turns out not to work. Anyone want to buy a nice GTi6? Whistle
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Feb 2013 at 23:15
    midlife
    It took some doing but I got the fecker off in the endWhistle
    Cool
    Team 330™Cool
    Team "no front end or engine"
    Posted 4th Feb 2013 at 23:19
    jamiek_uk2000
    There will be more blood than that...
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 4th Feb 2013 at 23:22
    rich306
    Lol, 'smashes himself in leg whilst giving a big swing'
    - Top Tip!!!
    Posted 5th Feb 2013 at 08:01
    Pages (3): [1] 2 3
