Author Subject: phase 2 GTi 6 Unlocked ECU NOW SOLD!!!
moz_gti_6
as title £55 posted in the uk Thumbs up
Dont f*ck with the bear or you'll be sorwee
1999 Subaru Impreza Rb5 Wr Sport PPP
1998 306 GTi 6
2006 307 1.6 110 hdi
1992 309 Goodwood GTi
Team ~ Taliban Hunting Club ~ Be The Best Kill The Rest
Posted 3rd Feb 2013 at 21:53
Unlocked by removing ecu while ign was on, or totally unlocked ?Smile
Posted 4th Feb 2013 at 14:31
moz_gti_6
removed when engine was running, which will mean it will work on others
1998 306 GTi 6
Posted 4th Feb 2013 at 15:05
pugheaven
^ negative!!
Only if they remove the ignition barrel chip reader and the unit under the dash , if not it will lock the ecu as soon as you turn the key
Posted 4th Feb 2013 at 18:28
vts_tibi
pugheaven wrote:
^ negative!!
It can be unlocked still, by programming the TMS MCU Wink
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Feb 2013 at 19:38
moz_gti_6
right so lets get this straight before i sell it to someone, i removed the ecu when the car was running, i was under the impression this would free it up to be used for a 309 / 205 gti conversion
i'm thinking now it'll work for a 205 / 309 conversion but not for another 306 unless it is unlocked, is this correct?
1998 306 GTi 6
Posted 4th Feb 2013 at 20:02
ben25
Can someone agreed or disagreed this ? (cause If It'll work on 205gti6 conversion, I'll take it)
Posted 14th Feb 2013 at 09:14
Will be fine for going in a 205/309.
  • Posted 14th Feb 2013 at 09:27
    So if you fitted it to another 306 it would lock it and render it useless?
    Or it would lock it onto that car and it would work ok?Dunno
    Thumbs up
    Posted 14th Feb 2013 at 09:56
    moz_gti_6
    how close are you to needing the ecu? you can buy it and i'll offer a full refund if it's no good Thumbs up
    1998 306 GTi 6
    Posted 14th Feb 2013 at 15:07
    pugheaven
    It will be 100% fine to use on a 205/309!
    Coskev- if the ecu was connected to a phase 1 306 all you would have to do is immobilise the car and disconnect the keypad before installing the new "unlocked" ecu.
    If you connected it to a phase 2/3 with out removing the box under the dash and the barrel chip reader (aftermarket alarm would be needed) it would lock the ecu again back to the original car it came from so could be unlocked again! If you remove the box and barrel reader the ecu will work!!
    Or that's what I believe from experimenting!
    Posted 14th Feb 2013 at 15:33
    Ok taThumbs up
    Posted 15th Feb 2013 at 11:05
    moz_gti_6
    still for sale
    1998 306 GTi 6
    Posted 16th Feb 2013 at 03:39
    moz_gti_6
    SOLD!!!
    1998 306 GTi 6
    Posted 26th Feb 2013 at 21:56
