displaying posts 1 to 25 of 39
Author Subject: Temprature gauge ?
hazz
Is it normal to go upto about 110 and then the fans kick in ? :s help !
Moonstone 1.4... Written off!
Astor 6... SOLD !
New owner of a Moonstone 6 !
Posted 3rd Feb 2013 at 00:04
My rallye doesYes
Posted 3rd Feb 2013 at 10:23
jamiek_uk2000
I was s**tting myself when I first got my 6 and it started to get to 105 in traffic, I used to turn it off because I thought it was going to pop. Checked the forum and it seems they love to run hot!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 3rd Feb 2013 at 10:34
honestly3k
They do run hot but if your fans are working properly they shouldn't really ever get to 110 degrees. Both fans should kick in at 95 degrees at slow speed and should cool the engine down.
Worth checking the coolant level too and topping up if needed. Even if your fans kick in at 95 as they should it won't cool the engine if your coolant is low. Also check your radiator for leaks
Posted 3rd Feb 2013 at 10:44
swiftyboi006
Stat opens at 88deg i think, both fans should come on slow speed at 97deg then both high speed at 107deg.
Black p3 Love
Posted 3rd Feb 2013 at 11:19
swiftyboi006
Mine cools from 97 quite well and will sit just below 90 if moving
Black p3 Love
Posted 3rd Feb 2013 at 11:20
Thermostat is an 83 degrees one. Yes
Both fans should come on at 97c at half speed and then full speed at 107c. If your fans aren't coming on until the later setting then your low speed isn't working.
Posted 3rd Feb 2013 at 11:48
swiftyboi006
Thought it was either 83 or 88.
Black p3 Love
Posted 3rd Feb 2013 at 12:33
Nope, all of them are 83. Yes
Posted 3rd Feb 2013 at 14:42
hazz
Ahh okay tha ks everyone ! Thought it was going to blow up ! Thanks for the adivse ! High speed deffinatly works but not to sure on low speed ! Is it bad if low speed doesn't work ? Smile
Astor 6... SOLD !
Posted 3rd Feb 2013 at 16:30
What do you think?
Posted 3rd Feb 2013 at 16:55
Two fans are for gaylordsRazz
Presuming the rallye only has the high speed setting for fan?Dunno
Posted 3rd Feb 2013 at 17:21
Guess so but hey whose engines are cooler....
Posted 3rd Feb 2013 at 17:26
hazz
thugpuggin wrote:
What do you think?
Well I know its there for a reason I was just wondering if I would be damaging anything while its not working, does any one know why slow speed stops working ? Is it the actual fan or a relay ?
Astor 6... SOLD !
Posted 3rd Feb 2013 at 17:29
Slow speed operation of fans are wired in series so it could be any part of the circuit. Usually one of the fans themselves or the Bitron unit are most common.
As for it being bad, Peugeot set the fans up so that the engine would start to be cooled when the coolant temp reached 97c. They added the secondary function as an emergency back up to stop the HG being cooked in case of an issue with the fan system.
Let's put it this way, if you were jumping out of a plane and had a parachute and a reserve parachute in your rucksack...
You discovered the main chute didn't work, how many times would you jump out knowing you're only relying on the reserve? Dunno
Posted 3rd Feb 2013 at 18:16
What you need is 2 slim line fans one that works as normal kicks in about 97 but also activate off the cars ac button at high speed to keep the temps right down Big grin
Posted 3rd Feb 2013 at 18:19
scotzman
The Rallye has a completely different setup, doesn't use the brown plug on the thermostat housing like the GTi does.
Posted 3rd Feb 2013 at 18:21
Yeah I know thatThumbs up got the fan switch mounted in the rad by top hoseSmile
So its just single speed on the rallye? Dunno
Posted 3rd Feb 2013 at 18:29
hazz
Right I understand now ! Haha thanks mate ! I will have a look tommorow if the fan is working or not, ill get the old power probe out ! Haha cheers for the help mate ! But yes I would deffinatly want my main shute working ! ;-)
Astor 6... SOLD !
Posted 3rd Feb 2013 at 19:08
306xsi
I think I'm right in saying if you unplug the temp sensor on the thermostat housing (the brown one) the fans should kick in. They should start at low speed - if that works, before going to high speed soon after.
Had a problem with the fans on one car, never sorted it because I took the engine out, but the problem was one of the fans wasn't working. If you have the same problem, I have one fan that works!
Posted 3rd Feb 2013 at 22:35
Yep, this is exactly right.
Posted 4th Feb 2013 at 07:27
hazz
Hello,
Thank you for the input! I went out there today and to start with I checked the coolant, which was quite low so I topped it right up ! thought this was it but then I disconnected the brown temp sensor plug (thankyou 306xsi) and waited for the fans but the did not come on slow speed they only came on fast speed. So I ran the car up to temp and Stan you are correct slow speed is not working at 97c so am just relying on my reserve chute at the moment I So would where would be the best place to start checking what is wrong ? You said it may be the fan should I just check if it has power going to it when I unplug the brown temp sensor ? Cheeersss Thumbs up
Astor 6... SOLD !
Posted 4th Feb 2013 at 17:15
no, its two speed same as a 1.9 205.
Posted 4th Feb 2013 at 18:19
Hazz - When you pulled the brown sensor plug off and you say the "fans" came on full speed, are you sure both came on or just one?
Posted 4th Feb 2013 at 19:19
hazz
Sorry about that Stan ! I meant to say fan... Typo !
Astor 6... SOLD !
Posted 4th Feb 2013 at 23:16
