displaying posts 26 to 39 of 39
Pages (2): 1 [2]
Author Subject: Temprature gauge ?
coskev wrote:
scotzman wrote:
coskev wrote:
Two fans are for gaylordsRazz
Presuming the rallye only has the high speed setting for fan?Dunno
The Rallye has a completely different setup, doesn't use the brown plug on the thermostat housing like the GTi does.
Yeah I know thatThumbs up got the fan switch mounted in the rad by top hoseSmile
So its just single speed on the rallye? Dunno
no, its two speed same as a 1.9 205.
Ok ta . don't think my low speed works then.Dunno
Is the switch in rad a twin one then?
Or are the 2 speed's controlled by something else?
Posted 4th Feb 2013 at 23:52
hazz
So i had a look at it yesterday and i found out that only the right fan (if your looking through the grille) works on high speed. Do you think i need a new set of fans ? Cheers !
Moonstone 1.4... Written off!
Astor 6... SOLD !
New owner of a Moonstone 6 !
Posted 19th Feb 2013 at 10:08
hazz
Bumpy ??
Astor 6... SOLD !
Posted 25th Feb 2013 at 14:55
heliosphan
When the one fan is spinning, have you tried tapping the centre of the other fan to see if it momentarily spins up? I had one fan stationary on mine and a quick smack made it work, confirming the motor was shot/sticking. One 2nd hand fan unit later and all was well.
Posted 26th Feb 2013 at 16:47
hazz
Oh okay ill try that thanks mate ! Ill let you know how it goes tommorow ! Cheers pal !
Astor 6... SOLD !
Posted 26th Feb 2013 at 18:05
If only one of your fans is spinning then the fan itself is most likely duff.
You can test this by putting 12v direct to the fan in question and see if it spins up. Yes
Posted 26th Feb 2013 at 19:08
hazz
Okay mate cheers ill try that then ! Smile can you change a single fan or do you have to change both ? Hmm
Astor 6... SOLD !
Posted 26th Feb 2013 at 21:40
hazz
Unplugged the temp sensor to get the fans going, when the one started spinning I tapped the other one and off it went ! So they both work on both speeds now, is it a loose connection in the motor or something ??
Astor 6... SOLD !
Posted 28th Feb 2013 at 12:16
hazz
Astor 6... SOLD !
Posted 3rd Mar 2013 at 14:29
Post #35
More than likely stuck brushes in the fan motor, it will get gradually worse. Best thing to do would be to source a known working second hand item and then when your dodgy fan starts to play up again, swap it out.
Posted 3rd Mar 2013 at 22:43
hazz
Post #36
Okay mate nice one cheers ! When you say item is the meaning both complete fans ? Are they alright to change do you know ? Cheers !
Astor 6... SOLD !
Posted 3rd Mar 2013 at 22:47
Post #37
By 'item' I mean get hold of a second hand fan. They are available separately and it should take you no longer than 1.5 hours to change if you've never done it before, they are not that difficult. Smile
Posted 3rd Mar 2013 at 22:55
hazz
Post #38
Okay mate I will do that Thank you for the help ! Thumbs up
Astor 6... SOLD !
Posted 4th Mar 2013 at 10:31
Post #39
Not a problem. Smile
Posted 4th Mar 2013 at 10:57
Pages (2): 1 [2]
