How can I tell if the tube is out of shape where the bearings sit, or is it just a judgment call?
Team 'unintentional rat look'
| Author | Subject: beam tube |
clen666
How can I tell if my beam tube is suitable for a rebuild or is Donald ducked?How can I tell if the tube is out of shape where the bearings sit, or is it just a judgment call? ________________________________________ Team 'unintentional rat look' |
Seasoned Pro Location: Reading/parts for sale Registered: 21 Nov 2008 Posts: 4,311 Status: Offline |
Do the outer seals slide on and off by hand? Also check for dimples on the outside and inside of the tube. Failing that measure it________________________________________ Ph2 Black GTI 6!EX black 6 owner But now a Black caged rallye owner Hunting for Go faster bits! SEARCH click here |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
clen666 wrote: How can I tell if the tube is out of shape where the bearings sit look at it. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
Location: somewhere in north wales Registered: 09 Nov 2009 Posts: 3,119 Status: Offline |
better still, take the outer bearings out to make sure they're not covering a bodged previous rebuild________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
clen666
welshpug! wrote: clen666 wrote: How can I tell if the tube is out of shape where the bearings sit look at it. Well I didn't know how precise it needed to be, obviously if it looks out of shape it's knackered, didn't know if small amounts not clearly visible to the eye would affect bearing life ![]() ________________________________________ Team 'unintentional rat look' |
jord294
clen666 wrote: Well I didn't know how precise it needed to be, obviously if it looks out of shape it's knackered, didn't know if small amounts not clearly visible to the eye would affect bearing life ![]() not necessarily! i have 2 tubes here which i thought were perfect. good outer bearings both sides, but when i removed them ready to get tubes shotblasted and powdercoated, i found that the outer bearings had been fitted into a tube which had previously had bearing failure, and had worn into the tube. fit for scrap only ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Its pretty ruddy obvious tbh, if its f**ked its f**ked! if its not worn, its fine!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
