displaying posts 1 to 25 of 41
Author Subject: Engine swaps! (not your usual conversion)
MartinObviously
Hi! I'm new (but most people call me Martin)
I have a 306 XSi 2.0 16V Phase 3 here and basically the engine died Thumbs down
So, got a hold of a phase 1 GTI-6! Thumbs up which was rusted to hell.
We've put the GTI-6 engine in coupled to the XSi 5 speed box into the XSi with the XSi original loom and injectors.
Everything was going fine until it came to fitting the inlet manifold.
Physically it fits, we changed the map sensor (since phase 1 and 3 connectors are different)
naturally we assumed all would be well.
When we started the engine it was as if there is a vacuum leak.
It hunts between 800rpm and 4000!
So, are the other sensors between phase 1 and 3 internally different? (not including the map as we fitted the XSi map sensor to the GTI6 inlet manifold as it was a direct fit)
currently we've got it idling at 1000rpm with the ICV blocked off. there is no EML on either.
The car drives well like this, no noticeable loss in power Hyper
this is turning into a lot of work for not such a great gain! Sad
I'd appreciate any halp Big grin
edit: I've just been looking at the gallery and I remembered something!
Does the vacuum pump have to be connected to the inlet manifold? and does it T off with the brake servo? I don't remember what the GTi-6 bay looked like when the engine was removed - because I didn't remove the engine.
genuine nob
Posted 21st Jan 2013 at 00:34
Ideally, you should have used the 6 ECU and loom, then it would be running fine and you would have a nice increase in power too. The 6 engine is a different compression ratio to the XSi to start with so you can't really run it on the XSi management as it won't be correct.
Posted 21st Jan 2013 at 07:53
wouldn't have even tried using anything xsi related on the 6 engine, surely it'd have been easier to swap the whole lot over Unsure even the box
Posted 21st Jan 2013 at 09:00
barry.rs
Dont "forget" to update the DVLA & your insurance Wink
Posted 21st Jan 2013 at 09:30
It needs 6 management to go run it, you need to install the ECU and loom from the donor car or else this project is never going to run right.
Posted 21st Jan 2013 at 09:41
calibra306
Oh dear.
As mentioned the maps in the xsi ecu will not put anything extra into gaining power because it is mapped for the xsi not knowing it now has a gti engine!
Should of just sold xsi for scrap or got a cheap xsi engine (i have one lol) fitted the xsi engine and then sold it and then used cash to purchase a gti as not much extra to buy over an xsi
V6 Power!
Faster I can go the better!
Posted 21st Jan 2013 at 13:06
MartinObviously
It was running just fine with the XSi inlet on it though and with the XSi management.
Wasn't running lean either! Wink (which I was not expecting)
Just had the problem since fitting the GTI-6 inlet only.
I don't want you to tell me what should have been done - because I know what should have been done, Ideally I would have swapped the looms. I'm not new to engine conversions - well I am on a 306 :p
Shell is too good to scrap and it's all declared. Big grin
genuine nob
Posted 21st Jan 2013 at 14:07
demondriverdan
Any more info on why the looms and ECU weren't swapped as well then? Damaged or something?
Rallye Race Car
Posted 21st Jan 2013 at 14:20
MartinObviously
yup, the GTI6 loom is damaged because it was cut when the engine was removed! Angry
I could fix it but I'd need new wire and patience - I lack both LOL
I just figured that since the XSi is a 2.0 16V, the GTI-6 engine would at least run on XSi management. (a little bit like running a TU5JP4 engine on a J4 loom in a 106!) so we decided to leave the XSi loom in rather than source a GTI-6 one. sounds silly I know, but as I said already it did run fine with the XSi inlet on it.
genuine nob
Posted 21st Jan 2013 at 14:29
swiftyboi006
U need to buy a phase 1 loom mate the reason it was fine with the xsi manifold is because it had the correct sensors for the loom and ecu, the gti6 one is different
Black p3 Love
Posted 21st Jan 2013 at 15:06
MartinObviously
I did wonder that.
The reason I'm asking is because someone was arguing (I love a good argument me) with me that the sensors were the same Razz and I said they were different across the phases probably, because I was a bit unsure myself having never worked on a petrol 306 before.
I think the ICV is the problem since, as you say, the wiring is different. Smile it's stuck open allowing it to rev really high?
Just gonna shove the XSi inlet back on :p
I appreciate the help! Thumbs up
No doubt I will be back! I'll let you know how I get on with it. Probably won't be today as it's not at my house, and the 106 doesn't like the snow so I can't get to it.
I'm only comfortable with the old DTurbo's Big grin
genuine nob
Posted 21st Jan 2013 at 15:15
Sounds like your missing a +12v supply to the icvWink
Posted 21st Jan 2013 at 19:24
rich306
I've put a 1998 Gti6 engine into an XSi shell, i used the same loom and ECU that came with the engine and gained no problems. I'd definitely change the loom over and then you will solve the issue. Thumbs up
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 21st Jan 2013 at 19:31
swiftyboi006
^yessssssss
Black p3 Love
Posted 21st Jan 2013 at 20:03
Its easy to change the loom mate, it sounds daunting but trust me theres not a great deal to it, you have fitted an engine which is harder than the loom, you will find it much easyer to do the loom and ecu.
And seen as you have allready fitted the gti6 engine, for the little tiny bit of extra work you may aswell have it running like it should and get the gains.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 21st Jan 2013 at 20:55
Yep, totally agree here. You need the GTi-6 ECU and loom then it will be fine. Smile
Posted 21st Jan 2013 at 21:51
MartinObviously
Guys, it runs now!!!!!
I freed the multimeter from the tool bag.
GTI-6 ICV was buggered, jammed open.
GTI-6 MAP sensor has higher resistance - so it was running really rich.
All the other sensors are the same as the XSi ones Big grin
Simply fitted the XSi ICV into the GTI-6 inlet housing.
butchered (electrically perfect Wink ) the XSi MAP sensor.
The car now seems to run correctly, only a proper drive will tell. There's no inlet popping on full throttle/load so if it's lean it's not by much. and there's no flames so it's not rich.
I'll get the AFR checked, if it's very wrong then GTI-6 loom time Smile
I know it seems like I'm not taking your advice, but wiring on cars in general is doing my nut in at the moment :p
I do see that the loom is very simply to swap though!
genuine nob
Posted 21st Jan 2013 at 22:41
you wont need to do any "wiring" most gti6 looms will just plug straight in.
your rev limit will be wrong, your ignition timing will be wrong, your fuelling will be wrong.
Posted 21st Jan 2013 at 22:45
MartinObviously
I'm not really worried about the rev limit for now. More concerned for the fuelling.
As for the timing, it's not knocking, so for now it's "safe"
What is the rev limit for the XSi 2.0 16v?
I know the GTI6 is about 7250 ish.
genuine nob
Posted 21st Jan 2013 at 23:09
swiftyboi006
Not the cam timing the fuel-spark timing will be slightly out....... Jus wite up a gti 6 loom and ecu will take u the time of a cup of coffee and a fag
Black p3 Love
Posted 21st Jan 2013 at 23:14
Compression ratio on an XSi lump is 10.4:1, whereas the 6 lump is 10.8:1. As Welshpug says the whole setup will not be correct, doing what you've done is fine but it is not correct the engine will suffer for it in the long term.
You could change the loom and ECU over in 30 minutes and it would be running perfectly.
Posted 21st Jan 2013 at 23:29
MartinObviously
Yeah I was talking about the ignition timing, if it was well out I'd have pre-ignition or no power so it must be damn close.
The cam timing is perfect Thumbs up new belt too.
It's one of these "that'll do for now" things. The priority was getting a 2.0 16V engine in it to replace the broken one. Smile
I'll get a loom for it. I guess I'll need the ECU unlocked as well? Unsure
Are the connectors from engine-interior loom the same on all phases? or will I need a loom for matching phase? My best guess would be I need a loom for the same phase based on other pugs I've seen, ya?
genuine nob
Posted 22nd Jan 2013 at 01:13
rich306
Yes you'll need the ECU unlocked, only so it doesn't lock up straight away with the immobiliser plugged in. (Unplug the immobiliser before you start it, you might need that re-coded?) Maybe some of the more experienced members can help with this.
I can't answer the loom question, my engine and loom was a 98 going into a 98 Xsi, i'd suggest getting a phase 2 loom maybe?
- Top Tip!!!
Posted 22nd Jan 2013 at 07:26
MartinObviously
Oh, so you disable it the same way as a 106? start the car, yank the immobiliser hey presto unlocked ECU?
damn! should have done that when the GTI6 was still running, it has a keypad immobiliser on it for that ECU Sad
genuine nob
Posted 22nd Jan 2013 at 13:29
Yes, on the Phase 1 if you disconnect the keypad when the immobiliser is unlocked it will stay unlocked. Yes
Posted 22nd Jan 2013 at 19:53
