displaying posts 26 to 41 of 41
Pages (2): 1 [2]
Author Subject: Engine swaps! (not your usual conversion)
swiftyboi006
^ learn something new everyday Thumbs up
Black p3 Love
Posted 22nd Jan 2013 at 22:17
rich306
I didn't know how to unlock an ECU, i was just taught that if you yank out the previous engines Immobiliser when it's running, the new 'unlocked' ECU won't lock up unless you plug the immobiliser in without recoding it.
Unless there is a way around this?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 23rd Jan 2013 at 23:41
On Phase 1's it's done with removing the keypad, on Phase 2's and 3's it's achieved by disconnecting the ECU.
Posted 23rd Jan 2013 at 23:46
MartinObviously
On ph2 and 3 I guess there's an immobiliser box which you pull out with the engine running?
I suppose the ECU could be electronically unlocked and the signal pin removed? so it can go straight into any othe 306? Unsure
genuine nob
Posted 24th Jan 2013 at 18:39
i think with the engine running or on ignition position 2 you unplug the ECU and then remove the immobilier box thingy, which is under the dash - at a guess. only done it properly on a p1 with the keypad method. i did unlock my gti6 ecu using the remove on position 2 method but not yet tested it (it's for my 205 gti6 conversion)
Posted 24th Jan 2013 at 18:43
24seven
The ECU I bought to go with the engine I put in my 309 was simply unplugged with the engine running as far as I know. Because it was going into a 309 without an immobiliser setup inside teh car I didn't have to do any more, but from what I gather if you don't remove the "chip reader" from by the ignition barrel on a P2/3 or remove the keypad from a P1, it will re-lock the ECU when you turn the key.
Posted 25th Jan 2013 at 01:09
miles
You only need the ignition and and not the car running, Much safer this way and always works
www.pugracing.com
Posted 25th Jan 2013 at 01:39
^^This
Posted 25th Jan 2013 at 11:45
MartinObviously
I know only the ignition needs to be on :p
but the original GTI-6 loom is buggered, so I can't do that either way Sad
It's certainly faster than a standard XSi anyway. on the old engine it would struggle to keep up with my 106 - apart from about 110 mph onwards.
Organising getting a loom and ECU for it Big grin
genuine nob
Posted 25th Jan 2013 at 18:18
Post #35
Good stuff, then it will be running even better. Thumbs up
Posted 25th Jan 2013 at 20:00
swiftyboi006
Post #36
Had a going with a 106 gti earlier not sure if my gear change was better but when i changed into 2nd i overtook quite easily. Although when my friend had a saxo vts i couldnt overtake him untill 4th gear, dunno why as its the same engine and same sort of weight
Black p3 Love
Posted 26th Jan 2013 at 00:33
RetroPug
Post #37
Doesn't a Saxo VTS have a longer 2nd gear than a 106 GTi?
Posted 26th Jan 2013 at 00:47
MartinObviously
Post #38
Nope, that's a myth used by Saxo owners to make their VTS sound pure sik fast innit blud. Gear boxes are exactly the same ratios. It's the same story with the Furio and Quiksilver.
Paper figures are different because Citroen did tests with half tank of fuel and driver, and Peugeot did it with a full tank and one passenger. Thumbs up Also the Citroen is a s**tter spec Wink
Both cars are identical - I actually think the 106 is slightly heavier empty anyway but there's not much in it.
106 is nicer anyway, doesn't carry the same chav image as a saxo. Big grin
genuine nob
Posted 26th Jan 2013 at 12:59
MartinObviously
Post #39
ECU, loom and immobiliser box fitted, pulls like a train all the way to just over 7k now Wink
genuine nob
Posted 6th Jun 2013 at 22:30
Post #40
Awesome, sounds like you've got it sussed. Thumbs up
Posted 7th Jun 2013 at 07:20
MartinObviously
Post #41
Only 5 months later :p
It's on its second mid section of exhaust as well. after one track day a massive hole formed in the uhh, "silencer".
genuine nob
Posted 7th Jun 2013 at 18:17
Pages (2): 1 [2]
