displaying posts 26 to 46 of 46
Pages (2): 1 [2]
Author Subject: Flow Rate pin out
Niall
Im not 100% mate as ive never really dealt with aftermarket ecus. Im sure there must be a spare pin so to speak that your mapping guy can program to give a flow rate reading?
IIRC, on the mechanical injection derv 406s, you can also have this TC so there must be a flow sensor on it somewhere for it to work so i will see if there is anyway i adapt it to work on a gti engine or if there is anywhere else i can take the data from.
Posted 27th Jan 2013 at 21:13
I will ask when I eventually get it done, thanks.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th Jan 2013 at 16:27
Niall
Right me and another guy on OC have now got this Installed and fully working in our cars. You will need to butcher a spare loom for a pin and wire to put Into the ECU plug.
The only thing that isn't quite right is the distance till empty. It's telling us both that with a quarter of a tank, we still have almost 300 miles left! We did leave a wire out from the low fuel bulb on the dials because when it comes on, the display stops reading distance to empty. I reckon it needs this to sort of calibrate so will be trying it later this eve hopefully.
Oh and instantaneous mpg is fun. Got 7mpg with my foot on the floor Sad
Posted 4th Feb 2013 at 10:38
bas_306gti
Which pin on the ECU did you use for the injection flow rate signal ?
Posted 5th Feb 2013 at 19:36
Niall
Pin 5. Will be writing a guide up in a bit and will post it here.
Posted 5th Feb 2013 at 19:45
I guess its working from the resistance being read by the fuel gauge and is calibrated for a 406 fuel tank, which is 10 litres larger.
Posted 5th Feb 2013 at 19:47
Niall
Possible however im pretty sure the estate tank is a different capacity yet the TC is the same part number for both estate and saloon.
Will work it out at some point anyway! It might just need running a full tank from full to orange light to calibrate.....hopefully!
Posted 5th Feb 2013 at 19:54
bas_306gti
Ok, makes sense, pin 5 is not used in the normal cable loom.
Posted 5th Feb 2013 at 19:59
Niall
Post #35
THought i would update this. Got it all installed and working
Who says 306s cant be economical!
Posted 2nd Jun 2013 at 20:06
bas_306gti
Post #36
How did you fix the problem with the 406 fueltank being 10 ltrs. larger ?
Posted 5th Jun 2013 at 12:05
Post #37
Nobody, I did 55mpg in mine the other day Whistle
Posted 5th Jun 2013 at 12:19
Post #38
That looks very well done mate, good work Smile
Posted 5th Jun 2013 at 17:34
mechanical_repairs
Post #39
I do like that, cracking idea.
Carl
Posted 5th Jun 2013 at 21:32
Niall
Post #40
errr i didnt. The fuel left is still wrong. its going the wrong way round. Reads 400ish on a empty tank and down to 100 on a full one. Need to work out some electrical hokey pokey with it!
Posted 5th Jun 2013 at 23:23
daver6
Post #41
Whilst being towed?
Wishbone Polybushes available
Posted 9th Jun 2013 at 09:04
Andy_Bee_1
Post #42
Hi Niall,
I am watching this thread with curiosity, are you able to do a guide that I could follow?
Also, this may be a dumb question, but what/where did you get the clock surround from? it is bulging out right?
Cheers, Andy
Currently undergoing the knife!
Posted 11th Jun 2013 at 15:36
Niall
Post #43
I made the surround my self so its custom. Yes its bulging out probably by about 1cm. if you dont do it this way, the unit is too deep and hits the heater box.
There is a guide over on 306OC for fitting one to a HDi. Its the same except for the flow rate pin which you need to add in your self. That was probably the hardest part, getting the ECU plug apart!!!
When i get a spare half hour, ill write up a guide on fitting it in a gti including how to make the stalk Smile
Posted 11th Jun 2013 at 17:13
Niall
Post #44
http://306oc.co.uk/forum/thread-9957.html
Guide
Be careful when buying the Unit. They all look identical but some are in metric measurements and some are literally just a clock.
Posted 11th Jun 2013 at 17:15
Andy_Bee_1
Post #45
Nice work :-)
Did you get much further with the D9 fitting though? Is it possible?
Posted 11th Jun 2013 at 22:42
Niall
Post #46
Be honest, ive been so busy at work, i havent wanted to come home and look at more wiring diagrams lol
Posted 11th Jun 2013 at 23:07
Pages (2): 1 [2]
