displaying posts 1 to 25 of 33
Author Subject: Longmans inlet manifold
JWP EFi
Turbo Legend!
What exactly do (or did) Longmans do to the inlet?
A brief search suggests they cut it open and alter the trumpets
Is this worth getting done to a road engine, say with PT81's?
Posted 17th Jan 2013 at 21:18
Opened and removed the trumpets
Posted 17th Jan 2013 at 21:33
JWP EFi
Turbo Legend!
so realistically this could be done by any decent welder/fabricator?
what benefit does it give and are there any down sides?
Posted 17th Jan 2013 at 21:38
Was done to increase airflow but they also ran standalone management so the map sensor was also removed and other sensors not needed.
Posted 17th Jan 2013 at 21:43
JWP EFi
Turbo Legend!
ok. so with mild-ish cams and remap, it wouldnt be worth it would it?
Looking at ways to crack 200bhp N/A, 81's,pocketed pistons and map
Posted 17th Jan 2013 at 21:46
eddy_gti6
Wasnt this done and tested before and after mapping by someone on here? Sure i read about someone chopping the inlet open, chopping the trumpets off and welding it up and all he got was abit extra mid range? Not much benefits tho
Posted 17th Jan 2013 at 21:50
JWP EFi
Turbo Legend!
extra mid range would be good as long as there's no loss anywhere else
Posted 17th Jan 2013 at 21:52
boost
i heard when this is done with a new management system it can acheive more power than throttle boddies Confused
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
JWP EFi
Turbo Legend!
if only it was as easy
Posted 17th Jan 2013 at 21:54
Yeah but you need a racing engine to go with it Thumbs up
Posted 17th Jan 2013 at 21:56
JWP EFi
Turbo Legend!
well said
Posted 17th Jan 2013 at 21:58
clen666
That Dave bloke tried it. I think he lost a lot of midrange.
Need a high revving engine to make the most of it
Team 'unintentional rat look'
Posted 17th Jan 2013 at 22:00
boost
suppose youll see more gains running boost like
JWP EFi
Turbo Legend!
i doubt you'd need to do it if your running boost as engine is now - Forced inducted
Posted 17th Jan 2013 at 22:03
eddy_gti6
Posted 17th Jan 2013 at 22:05
JWP EFi
Turbo Legend!
that was an interesting read, seems its not worth doing unless your planning to go daft on other bits,
cams, management, head work etc
Posted 17th Jan 2013 at 22:24
gti6girl
I have a standard engine with a longmans inlet running on management and its 1/2 sec quicker than my other 205 on bodies down the quarter mile
Still prefer the sound of bodies tho
Posted 17th Jan 2013 at 22:33
JWP EFi
Turbo Legend!
im guessing its quicker becuase the standard long runners aid torque, but wait a minute, their shorter
if they've been de-trumpeted! this subject intrigues me
Posted 17th Jan 2013 at 22:37
gti6girl
Yeah there compleatly smooth inside with no trumpets
Posted 17th Jan 2013 at 22:40
JWP EFi
Turbo Legend!
how did it drive normally, ie other than caning it down the 1/4? loss in low to mid range torque?
Posted 17th Jan 2013 at 22:42
Shorter inlet tract to match the cam specs. Probably wouldn't loose quite as much down low as Jim did with a hopped up cam too.
gti6girl
It's absolutely rapid. It really does pull like a train all the way through the rev range
Posted 17th Jan 2013 at 22:44
JWP EFi
Turbo Legend!
so, to summarise, unless cams are uprated then its a pointless move, yes/no?!
Posted 17th Jan 2013 at 22:45
JWP EFi
Turbo Legend!
rest of engine totally standard? other than exhaust
Posted 17th Jan 2013 at 22:46
gti6girl
Here it is having a run up Prescott hill
205 rallye
Posted 17th Jan 2013 at 22:49
