Author Subject: Drilling out sideskirt rivets
mik
I've drilled out the bottom rivets on the bottom of the LH sill. Problem is, as Coskev said in his thread, that the outer but is alloy and the drill bit goes off centre, even though I centre punched each one. So I pulled the alloy outer off each one with pliers, thinking that one I got the skirt away from the rivets, I'd be able to have more grip to pull them out with pliers or something. When this failed I tried drilling the remains out with a smaller bit, but the rivet metal is hard and the drill doesn't penetrate very well.
As they are solid centre rivets drilling or pulling them with pliers seems to be very difficult. Is there a better technique to get the rivets out entirely?
Cherry Rallye SOLD
Posted 4th Jan 2013 at 16:53
midlife
Grinder, bfh & punchWhistle
Cool
Team 330™Cool
Team "no front end or engine"
Posted 4th Jan 2013 at 17:25
I ended up knocking some of them into the sillWhistle
Plenty of cavity wax in there so they won't rattle around!Big grin
Posted 4th Jan 2013 at 19:46
I jammed a little punch under the river to stop it spinning and drilled the head off which kept the bottom part of the rivet still. I did cut a couple of the heads off with sharp side cutters
Posted 4th Jan 2013 at 19:49
mechanical_repairs
I manipulate the side skirt over the rivet then once the skirt is off grind the s**t out of the bas**rds.
Carl
Posted 4th Jan 2013 at 19:51
I just thought f**k it and left the skirts on the car
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th Jan 2013 at 21:18
Carl
Screwdriver and hammer to force the rivet edge upwards then pinch off so you can manipulate over the reminent of the rivet is how I've done them on breakers but it's a ball ache so normally leave them on as they rarely sell when collection only offered and have had 10 years of use so are s**t anyway.
Rip the f**kers off and use loads of tiger seal to put them back on FTW.
Posted 4th Jan 2013 at 21:27
mik
Laugh my ass off
I was sooo close to that, but stupidly (in hindsight) pressed on anyway.
I was wondering whether I'd overlooked a simple way to sort it, but based on all your comments, it seems not. Getting the skirt off is not too much of a drama, its the dealing with the ****ing rivets sticking out of the sills afterwards. I think bits of most of them are going to end up inside the sill. I'll probably do a Coskev and let the cavity wax prevent a noise happening like jingling change in a pocket every time I go over a bump.
Cherry Rallye SOLD
Posted 4th Jan 2013 at 22:33
Dremel with a cutting disc to cut the heads in half the simply punch reminder into sill
Posted 4th Jan 2013 at 22:58
Posted 4th Jan 2013 at 23:12
aaron6
^^^ This.
I actually used a broken hacksaw blade. Worked okay but a dremel would have been the favorite.
Posted 5th Jan 2013 at 08:23
mik
Sounds like a consensus, that's what I'll do then. Thanks all.
Cherry Rallye SOLD
Posted 5th Jan 2013 at 09:12
Hole saw a one inch hole in the sill and use compressed air to blow the rivit debris out of the hole. Paint/treat the edges if the hole you made and slap in a grommet. Job done.
Posted 5th Jan 2013 at 09:45
i usually attach the car to a jig outside in the road and turn it upside down, but drill multiple holes in the sill first, and wiggle the car around a few times and the rivets drop out usually
Posted 5th Jan 2013 at 10:20
Do you engrave numbers on to the rivets before hand and call the numbers as they drop out to passing pensioners?
  • Posted 5th Jan 2013 at 10:28
