displaying posts 1 to 25 of 46
Author Subject: Pas relocation brackets
mechanical_repairs
To move the power steering pump to the sump.
Brand new with the fixings £50 delivered.
Carl
Posted 22nd Dec 2012 at 21:42
mechanical_repairs
Bump
Posted 3rd Jan 2013 at 17:27
robthe6
pm phil b hes after some
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 3rd Jan 2013 at 22:37
paulvancraen
Didn't you get my pm Carl?
Posted 4th Jan 2013 at 10:43
mechanical_repairs
My in box has been full for a while, if you want to resend?
Thanks
Posted 4th Jan 2013 at 13:23
phil b
Correction mr ganner I already have one of Carl's brackets (came with the kit), u might need one tho Wink Wink
Just gotta work out the pulleys when I swap the ph1 pulley setup over off the old block Huh?
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 5th Jan 2013 at 08:29
mechanical_repairs
Last one left.
Carl
Posted 11th Jan 2013 at 21:50
boost
this is a stupid question but why would u want to move the pas pump does it make a difference ?
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 11th Jan 2013 at 22:03
phil b
Itb setups or charger setups don't allow placement of the powersteering in normal place
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 11th Jan 2013 at 22:40
robthe6
carl do you use the standard non pas belt with this bracket?
Posted 11th Jan 2013 at 23:03
mechanical_repairs
It all depends on the setup you choose to go down regards the length of the belt?
Carl
Posted 11th Jan 2013 at 23:06
robthe6
just to relocate the pas so there is more room for jenveys. would the stock belt fit that?
Posted 11th Jan 2013 at 23:33
mechanical_repairs
What car will you be doing this too? Obviously a gti6 you'd will be removing the aircon so will require a smaller belt, belts are just off the shelf items you can buy at any required length so is no issue.
As for my own car for instance I have removed the power steering and added it to the sump then fitted a super charger so in effect added an extra pully it never had as original, you just measure the length and buy a belt to suit. My case was a slightly larger unit.
Carl
Posted 11th Jan 2013 at 23:37
robthe6
ph1 gti so non aircon rallye belt setup. being that iv added no extra pulleys wanted to know if the stock belt still works.
Posted 12th Jan 2013 at 01:17
manthos
Try it and you will find out or follow the way the belt goes with some string. Take that into a generic parts stoore and buy one for no more than £10.
I for example have removed all air con and power steering so needed a much smallerl belt.
Team SUPERCHARGED
Old Project thread
Posted 12th Jan 2013 at 01:28
robthe6
Yeah let's waste money to see if it might work or I could just ask Carl who has probably done something similar in the past.
Forums are here for reason bud. If I wanted to buy a belt an start testing I would. But I rather ask to see if someone's done it before.
Posted 12th Jan 2013 at 11:15
nobody has, so you'll be the one trying it and reporting back.
no need to buy a belt, just measure up.
or actually use that brain, you aren't adding a pulley, nor removing one...
Posted 12th Jan 2013 at 12:55
mechanical_repairs
In theory to your post as you are not adding a pulley you should be able to re use the original belt but as a few have said just measure it up with a piece of string, work out the length and there you go, so it would be a 6pk (6 ribbed belt) by the length you have measured ie 6pk 1100 for example.
Still one left
Carl
Posted 23rd Jan 2013 at 16:45
phil b
Carl could u add some pics of it fitted?? Just so I got an idea which fitting goes where?? I'm swapping sumps this week/end..prob simple meccano rules but best been safe Wink
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 24th Jan 2013 at 09:39
midlife
In place
But you'll need these
Cool
Team 330™Cool
Team "no front end or engine"
Posted 24th Jan 2013 at 10:53
phil b
Cheers Wayne I got 6 of them from current sump and 2 given with kit x
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 24th Jan 2013 at 11:19
Status: Online
Does this include the pipes carl?
Posted 25th Jan 2013 at 11:02
midlife
Careful there are 2 different spacers, 2 steel & 2 alloy, part numbers on receipt.
Cool
Team 330™Cool
Posted 25th Jan 2013 at 13:32
phil b
Yeah I got 4 solid an the 2 split ones are still in the old sump I will try n gently remove them to swap
Em over
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 25th Jan 2013 at 16:29
mechanical_repairs
Just re route the oriniginal pipes, if you slacken them you can re route with no need to cut and splice etc.
Carl
Posted 25th Jan 2013 at 18:05
