I have oz ultraleggera's et15 16x7j. I know i need tappered bolts m12x 1.25 but what length???
***Breaking*** Ph3 Silver GTI 6 High Boost
| Author | Subject: which wheel bolts |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
Did a search and cant seem to find much.I have oz ultraleggera's et15 16x7j. I know i need tappered bolts m12x 1.25 but what length??? ![]() ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
Do they need a spacer?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
6waysforward
Should'nt do, there et15________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
derp ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
6waysforward
Sorry did you mean spacer on the bolts ![]() ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
Takedown
Senior User Location: Holland Registered: 18 Oct 2012 Posts: 845 Status: Offline |
If youre not using or gonna use a spacer, a normale size bolt will do, around 31mm |
6waysforward wrote: Did a search and cant seem to find much. I have oz ultraleggera's et15 16x7j. I know i need tappered bolts m12x 1.25 but what length??? ![]() Measure from where the taper seats in the alloy, inwards to where bolt goes into flange,allowing enough to go fully through disc/flange, but not with a massive excess out the back of flange You will find most bolts list this length in their specs ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
As ive said before mate ive got the right ones here |
