displaying posts 1 to 25 of 84
Pages (4): [1] 2 3 .. last
Author Subject: froze !!!
boost
well its seems as though ive had a bit of a bah bah today come out to take the bairn to nursery checked me water level as i always do in this weather and to my astonishment ive froze my engine dont know how cause there was antifreeze in the system Sad anyone know how i can unfreeze it without causing any damage cause i know water expands when it freezes so im hoping the core plugs have done there job and it hasnt warped te head !!
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 6th Dec 2012 at 13:21
darzmat
Hav you been topping it up with water at all? The antifreeze must be diluted some what.
As you say water expands when it freezes but it also expands a bit more when it thaws.
Hopefully it will be ok but I don't know how you would warm it up gently appart from putting it inside a garage or something and leave it to thaw at its own pace.
Posted 6th Dec 2012 at 13:32
boost
it had a a bit of a water leak doqn to a damaged gasket on the thermostat housing so i replaced that flushed the system bled it off n put 50/50 antifreeze/water i was thinkin about lockin it in the garage unclipping as many hoses as possible and whacking the heater on n let it thaw out for a few hours u think that may work ?
Posted 6th Dec 2012 at 13:38
scotzman
If it was 50/50, no way should it be frozen
Posted 6th Dec 2012 at 13:40
boost
defo 50/50 i was also thinking it was just be the top of the expansion bottle thats froze if say a bit of water has seperated from the antifreeze ? but is that possible ?
Posted 6th Dec 2012 at 13:48
darzmat
I would just be very cautious and not let it thaw too quickely. As above, it should never have froze. 50/50 should protect to at least -26
Posted 6th Dec 2012 at 13:49
Depends if it was pre-mixed or not....
Certainly I would not try and start it, just wait a few days for it to warm up, leave it facing the sun.
Posted 6th Dec 2012 at 13:53
boost
ok cheers lads ill see what happens over the next few days al probs just lock it away take off a pipe or two n leave it be
Posted 6th Dec 2012 at 14:07
LOL
It's getting colder not warmer! December has just started, it'll get a lot colder yet before it gets warmer. If the OP leaves it a few days it'll just freeze again every night.
Posted 6th Dec 2012 at 14:49
if he leaves it for one morning though in the sun to defrost it then just plough a load of antifreeze in there that should do Yes
Posted 6th Dec 2012 at 15:01
If the cooling system is full though he will need to empty some of it to get the extra antifreeze in there. Yes
Posted 6th Dec 2012 at 15:04
i siphoned some out of my HDI the other day with a bit of washer pipe to save messing with the hoses LOL
Posted 6th Dec 2012 at 15:05
boost
could i not just pour boiling water in it ?
Posted 6th Dec 2012 at 15:11
craig-gti6
No, it might crack it
Posted 6th Dec 2012 at 15:14
Waste of time!LOL
Would never make its way around the systemNo
I would get it in the garage with a small electric heater blowing under the front,then just cross your fingers that you don't get coolant leaking out anywhere as it meltsSad
You say you put a 50/50 mix in,how much antifreeze did you use?Dunno
Posted 6th Dec 2012 at 15:17
Crack what?
I think your thinking of putting cold water in a overheating/empty engineWink
That can crack things,rapid cooling.Yes
Posted 6th Dec 2012 at 15:19
stu
It could still crack something though, much like pouring hot water on a frozen windscreen.
Posted 6th Dec 2012 at 15:34
i've done that for years and never cracked a windscreen btw
my brother who fitted windscreens said it was largely a myth and, unless it was an absolutely battered or stonechipped / overly repaired / cracked screen previously where moisture could get in, that was likely to never happen
Posted 6th Dec 2012 at 15:37
beez_neez_gt
LOL
Not according to climate change it isnt.
I always use luke warm water for the screen, which slowly defrosts it so it wont crack. Not on a screen that is anyway damaged though. Using hot water defrosts it too quickly which means it will crack, i never buy de-icer.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 6th Dec 2012 at 15:41
craig-gti6
I was thinking it might crack th plastic part of the rad, just like pouring hot water on a windscreen but as you just said it was a myth I could be wrongDunno
Posted 6th Dec 2012 at 15:43
try it Thumbs up
Posted 6th Dec 2012 at 15:45
boost
i think these are a 5ltr system so based on that when i flushed it i used approx 3ltrs just so it still had sone in when i bled the system n thats what i was thinkin take off the rad hose and the bpttom hose that runs rpund the back and leave a heater goin in the garage
Posted 6th Dec 2012 at 15:46
there's 8 litres in these iirc.
Posted 6th Dec 2012 at 15:49
beez_neez_gt
Androids again.
Pug fee`ver,
Posted 6th Dec 2012 at 15:52
coskev wrote:
Waste of time!LOL
50:50 mix of MrMuscle and Antifreeze you reckon?
Please do not try this.
  • Posted 6th Dec 2012 at 15:55
