Team Nile 6
| Author | Subject: annoying wheel wobble |
sj.lucas
Regular Location: Petersfield Registered: 20 Jun 2011 Posts: 174 Status: Offline |
Have a wobble on steering when braking lightly or hard at 70... have changed brakes, wheels and struts. Any sensible ideas would be great ________________________________________ Team Nile 6 |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Warped front disc 100%________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
track rods, P bushes.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Oh s**t you changed brakes.... discs and pads on both sides?Interesting. Think welshpug might be right as i had a similar feeling when i had a loose tre But it was more present than just at a certain speed when braking. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
swiftyboi006
eliotrw wrote: really? 100% so this man is now going out to buy new discs and pads and it may well be something else..........poor man Warped front disc 100% ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Yeah missed the bit about already (possibly) changing them.Although i had an identical issue once Put it in for mot and low and behold the mechanic fitted discs after doing a quick test as there was imbalance due to the warpage ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
sj.lucas
eliotrw wrote: Oh s**t you changed brakes.... discs and pads on both sides? Interesting. Think welshpug might be right as i had a similar feeling when i had a loose tre But it was more present than just at a certain speed when braking. What sort of sane person would change disc and pads only on one side? Haha ________________________________________ Team Nile 6 |
Well it was more the discs and pads i was asking for but hey you get some people on here so i had to check.After that coil pack thread.... :p ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
sj.lucas
Haha. Discs and pads were changed both sides! Green stuff pads which are Bloody awful and brake engineering discs ________________________________________ Team Nile 6 |
Have you changed the rears ? |
Welshpugs got it then i'd say ![]() ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
sj.lucas
Did you change the rears ? |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Where the drive faces cleaned before the discs were fitted?? Only takes a bit of crap behind the disc to cause a wobble. ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
stan_306gti6
jeffers wrote: Where the drive faces cleaned before the discs were fitted?? Only takes a bit of crap behind the disc to cause a wobble. Either this, or knackered P-Bushes. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
heliosphan
Senior User Location: UK Registered: 14 Sep 2007 Posts: 950 Status: Offline |
bigbadbowen wrote: Did you change the rears ? bigbadbowen wrote: Did you change the rears ? OP, did you change the rears? The rears where the cause of my braking wobble and I only found out after I'd replaced front brakes, droplinks, whole wishbones, ball joints and some of my sanity. |
swiftyboi006
sj.lucas wrote: i think hes saying theres a wobble through the steering wheel so i would suspect p bushes not rear discsHave a wobble on steering when braking lightly or hard at 70... have changed brakes, wheels and struts. Any sensible ideas would be great ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Recently changed the rears?________________________________________ ![]() |
heliosphan
swiftyboi006 wrote: sj.lucas wrote: i think hes saying theres a wobble through the steering wheel so i would suspect p bushes not rear discsHave a wobble on steering when braking lightly or hard at 70... have changed brakes, wheels and struts. Any sensible ideas would be great The description doesn't rule out the rear brakes. I could feel juddering through the wheel when I was braking and my rears were the cause... On a totally unrelated note, have you changed the rear bakes at all OP? This might be the cause of the problem and I can't believe that nobody's suggested it yet. |
stan_306gti6
Deffo sounds like a P-Bush issue to me. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6 wrote: Deffo sounds like a P-Bush issue to me. ![]() Nah it's deff brake related Stan either bad installation or rear brakes shot |
Or could be wheel balance issue ? |
stan_306gti6
bigbadbowen wrote: stan_306gti6 wrote: Deffo sounds like a P-Bush issue to me. ![]() Nah it's deff brake related Stan either bad installation or rear brakes shot I have had this *exact* problem before I got roller bearing wishbones bushes. ![]() The bushes *looked* ok, but in actual fact they were shot. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Definitely agree with P-bushes/wishbone bushes, but these sorts of things can have more than one cause on an old car. Ball joint bolts torqued up? In fact all bolts? Overtightened wheel bolts warping the new front discs? I've had an epidemic of idiots overtightening wheels. Even when (or perhaps because!) I say "please don't over-tighten". Seems they don't want the wheel to fall off so tighten it to 200 ft lb, or they just love those rattle guns a bit too much. I'd also definitely clean the mating faces on both wheels and discs before changing any more parts. What about cr@p balancing? Cheap/well-worn tyres? ________________________________________ Cherry Rallye SOLD |
stan_306gti6
The front wishbone securing bolt (18mm head) not being tightened correctly has been known to cause this exact fault as well. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
