Author Subject: annoying wheel wobble
sj.lucas
Have a wobble on steering when braking lightly or hard at 70... have changed brakes, wheels and struts. Any sensible ideas would be great Smile
Team Nile 6 Superman
Posted 27th Nov 2012 at 21:52
Warped front disc 100%
Posted 27th Nov 2012 at 21:56
track rods, P bushes.
Posted 27th Nov 2012 at 21:57
Oh s**t you changed brakes.... discs and pads on both sides?
Interesting.
Think welshpug might be right as i had a similar feeling when i had a loose tre
But it was more present than just at a certain speed when braking.
Posted 27th Nov 2012 at 22:00
swiftyboi006
really? 100% so this man is now going out to buy new discs and pads and it may well be something else..........poor man Sad
Black p3 Love
Yeah missed the bit about already (possibly) changing them.
Although i had an identical issue once
Put it in for mot and low and behold the mechanic fitted discs after doing a quick test as there was imbalance due to the warpage
Posted 27th Nov 2012 at 22:03
sj.lucas
Interesting.
What sort of sane person would change disc and pads only on one side? Haha
Posted 27th Nov 2012 at 22:04
Well it was more the discs and pads i was asking for but hey you get some people on here so i had to check.
After that coil pack thread.... :p
Posted 27th Nov 2012 at 22:06
sj.lucas
Haha. Discs and pads were changed both sides! Green stuff pads which are Bloody awful and brake engineering discs
Posted 27th Nov 2012 at 22:08
Have you changed the rears ?
Posted 27th Nov 2012 at 22:11
Welshpugs got it then i'd say Smile
sj.lucas
Posted 27th Nov 2012 at 22:20
Did you change the rears ?
Posted 27th Nov 2012 at 22:23
jeffers Forum Admin
Where the drive faces cleaned before the discs were fitted?? Only takes a bit of crap behind the disc to cause a wobble.
Team Running Engine again!
Team Negative Camber!
Posted 27th Nov 2012 at 22:38
Either this, or knackered P-Bushes. Yes
Posted 28th Nov 2012 at 07:06
heliosphan
OP, did you change the rears?
The rears where the cause of my braking wobble and I only found out after I'd replaced front brakes, droplinks, whole wishbones, ball joints and some of my sanity.
Posted 28th Nov 2012 at 07:27
swiftyboi006
i think hes saying theres a wobble through the steering wheel so i would suspect p bushes not rear discs
Black p3 Love
Posted 29th Nov 2012 at 15:59
Recently changed the rears?
  • Posted 29th Nov 2012 at 16:02
    heliosphan
    The description doesn't rule out the rear brakes.
    I could feel juddering through the wheel when I was braking and my rears were the cause...
    On a totally unrelated note, have you changed the rear bakes at all OP?
    This might be the cause of the problem and I can't believe that nobody's suggested it yet.
    Posted 29th Nov 2012 at 16:56
    Deffo sounds like a P-Bush issue to me. Yes
    Posted 29th Nov 2012 at 18:43
    Nah it's deff brake related Stan either bad installation or rear brakes shot Yes
    Posted 29th Nov 2012 at 18:46
    Or could be wheel balance issue ?
    I have had this *exact* problem before I got roller bearing wishbones bushes. Yes
    The bushes *looked* ok, but in actual fact they were shot.
    Posted 29th Nov 2012 at 18:49
    mik
    Definitely agree with P-bushes/wishbone bushes, but these sorts of things can have more than one cause on an old car.
    Ball joint bolts torqued up? In fact all bolts?
    Overtightened wheel bolts warping the new front discs? I've had an epidemic of idiots overtightening wheels. Even when (or perhaps because!) I say "please don't over-tighten". Seems they don't want the wheel to fall off so tighten it to 200 ft lb, or they just love those rattle guns a bit too much.
    I'd also definitely clean the mating faces on both wheels and discs before changing any more parts.
    What about cr@p balancing? Cheap/well-worn tyres?
    Cherry Rallye SOLD
    Posted 29th Nov 2012 at 18:55
    The front wishbone securing bolt (18mm head) not being tightened correctly has been known to cause this exact fault as well. Yes
    Posted 29th Nov 2012 at 19:23
